Mitsubishi Forklift FBS13 24V Chassis Mast Europe Parts Catalog WEBN2730-01
Brand: Mitsubishi
Type of Machine: Forklift
Region: Europe
Model: Mitsubishi FBS13 24V Chassis Mast Europe
Part Number: WEBN2730-01
Number of Pages: 285 Pages
HARNESS GP (WIRING)
01-04-02A PANEL GP CONTROL PART 1 OF 2
01-04-02B PANEL GP CONTROL PART 2 OF 2
01-04-02C PANEL GP CONTROL PART 1 AND 2 OF 3
01-04-02D PANEL GP CONTROL PART 3 OF 3
01-04-02E PANEL GP CONTROL (BOARD GP DRIVER)
01-04-02F PANEL GP CONTROL (CONTACTOR ASSY.-DIRECTIONAL)
01-04-02G PANEL GP CONTROL (CONTACTOR ASSY.-LINE)
01-04-02H PANEL GP CONTROL (CONTACTOR ASSY.-BYPASS)
01-04-02I PANEL GP CONTROL (CONTACTOR ASSY.-LIFT)
01-04-03A CONNECTOR GP BATTERY (SBE - 24 VOLT)
01-04-03B CONNECTOR ASSY. BATTERY (24 VOLT)
SWITCH GP ELECTRICAL
HORN GP ELECTRICAL
01-04-07A INSTRUMENT GP
01-04-07B INSTRUMENT GP
01-20-01A MOTOR GP DRIVE (24 VOLT)
01-20-01B MOTOR GP MAIN DRIVE (24 VOLT)
01-20-03A MOTOR GP ELECTRIC POWER STEER PUMP (24 VOLT)
01-20-03B MOTOR GP ELECTRIC POWER STEER PUMP (24 VOLT)
01-20-05A MOTOR GP HYDRAULIC PUMP (24 VOLT)
01-20-05B MOTOR GP HYDRAULIC PUMP (24 VOLT)
AXLE GP DRIVE R.H.
AXLE GP DRIVE L.H.
MOUNTING GP DRIVE AXLE
TIRE GP SOLID PNEUMATIC
MOUNTING GP DRIVE WHEEL
AXLE GP STEER
MOUNTING GP STEER
PANEL GP TOP
PANEL GP SIDE
RESTRAINT GP BATTERY
FLOOR PLATE GP
01-11-05A COUNTERWEIGHT GP
01-11-05B COUNTERWEIGHT GP
CONSOLE GP
GUARD GP OVERHEAD
PAINT & LUBE GP
SEAT GP - SUSPENSION
01-51-01A CONTROL GP ACCELERATION
01-51-01B CONTROL GP ACCELERATION
CONTROL GP BRAKE
CONTROL GP SERVICE BRAKE
BRAKE GP SERVICE
BRAKE GP PARKING
LINES GP BRAKE
STEERING WHEEL & GEAR GROUP
CONTROL GP FORWARD & REVERSE
01-75-01A PUMP GP POWER STEERING PART 1 OF 2
01-75-01B PUMP GP POWER STEERING PART 2 OF 2
PUMP GROUP HYDRAULIC
LINES GROUP POWER STEER
FILTER GP HYDRAULIC OIL
01-75-05A TANK GP HYDRAULIC
01-75-05B TANK GP HYDRAULIC (LARGE)
LINES GP MAST OPERATING
CONTROL GP MAST OPERATING VALVE (3 - WAY)
01-75-08A VALVE GP CONTROL (3-WAY)
01-75-08B VALVE GP CONTROL (3-WAY)
01-75-08C VALVE GP CONTROL (3-WAY)
01-75-08D VALVE GP CONTROL (3-WAY)
MOUNTING GP MAST OPERATING VALVE
CONTROL VALVE FLOW
1200791 CYLINDER GP - TILT - SIMPLEX - DUPLEX - TRIPLEX 1 REQUIRED
1200792 CYLINDER GP - TILT - SIMPLEX - TRIPLEX 1 REQUIRED
1200793 CYLINDER GP - TILT - SIMPLEX - DUPLEX - TRIPLEX 1 REQUIRED
1200796 CYLINDER GP - TILT - SIMPLEX - TRIPLEX 1 REQUIRED
1200794 CYLINDER GP - TILT - SIMPLEX - DUPLEX - TRIPLEX 1 REQUIRED
1200795 CYLINDER GP - TILT - SIMPLEX - TRIPLEX 1 REQUIRED
CYLINDER GP - TILT
MOUNTING GP - CYLINDER - TILT REAR
FORKS
LIFT BRACKET
02-45-01A MAST COMMON PARTS (SIMPLEX) G15A20-60
02-45-01B MAST COMMON PARTS (SIMPLEX) G15A20-60
SIMPLEX MAST G15A20-60
LIFT CYLINDER (SIMPLEX) G15A20-60
02-52-01A MAST COMMON PARTS (DUPLEX) H15A27-40
02-52-01B MAST COMMON PARTS (DUPLEX) H15A27-40 PART 1 OF 2
02-52-01C MAST COMMON PARTS (DUPLEX) H15A27-40 PART 2 OF 2
DUPLEX MAST H15A27-40
LIFT CYLINDER (DUPLEX) H15A27-40 (1ST)
LIFT CYLINDER (DUPLEX) H15A27-40 (2ND)
02-50-01A MAST COMMON PARTS (TRIPLEX) J15B37-70
02-50-01B MAST COMMON PARTS (TRIPLEX) J15B37-70
02-50-01C MAST COMMON PARTS (TRIPLEX) J15B37-70 PART 1 OF 3
02-50-01D MAST COMMON PARTS (TRIPLEX) J15B37-70 PART 2 OF 3
02-50-01E MAST COMMON PARTS (TRIPLEX) J15B37-70 PART 3 OF 3
TRIPLEX MAST J15B37-70
LIFT CYLINDER (TRIPLEX) J15B37-70 (1ST)
LIFT CYLINDER (TRIPLEX) J15B37-70 (2ND)
192 LIFT TRUCK OPTIONS CHASSIS OPTION AR.
194 LIFT TRUCK OPTIONS CHASSIS OPTION AR. 4 WAY
196 LIFT TRUCK OPTIONS CHASSIS OPTION AR. VALVE GP
198 LIFT TRUCK OPTIONS MIRROR KIT
200 LIFT TRUCK OPTIONS DRAW BAR PIN KIT
202 LIFT TRUCK OPTIONS LIGHT GROUP ROAD
206 LIFT TRUCK OPTIONS BACKUP WARNING KIT
208 LIFT TRUCK OPTIONS WARNING LAMP KIT (AMBER)
210 LIFT TRUCK OPTIONS LIGHT GROUP 2F_1B (24V)
212 LABEL KIT (FRENCH)
214 LABEL KIT (SPANISH)
216 LABEL KIT (ITALIAN)
218 LABEL KIT (GERMAN)
220 LABEL KIT (DUTCH)
222 LABEL KIT (PORTUGUESE)
224 LABEL KIT (DANISH)
226 LABEL KIT (GREEK)
228 LIFT TRUCK OPTIONS CONNECTOR AS - SBE (24 VOLT)
230 LIFT TRUCK OPTIONS CONNECTOR AS - SBE (24 VOLT)
233 LIFT TRUCK OPTIONS BATTERY CONTAINER
234 LIFT TRUCK OPTIONS TIRE GROUP CUSHION
236 LIFT TRUCK OPTIONS SPARE WHEEL CUSHION
238 LIFT TRUCK OPTIONS SPARE WHEEL (SOLID PNEUMATIC)
240 LIFT TRUCK OPTIONS 3 - WAY SIMPLEX G15A20-60
246 LIFT TRUCK OPTIONS 4 - WAY SIMPLEX G15A20-60
248 LIFT TRUCK OPTIONS 3 - WAY DUPLEX H15A27-40
254 LIFT TRUCK OPTIONS 4 - WAY DUPLEX H15A27-40
258 LIFT TRUCK OPTIONS 3 - WAY TRIPLEX J15B37-70
264 LIFT TRUCK OPTIONS 4 - WAY TRIPLEX J15B37-70
