Mitsubishi Forklift FBC55N Chassis Mast Options Internal Hosing Europe Parts Catalog WEBN8474-01
Brand: Mitsubishi
Type of Machine: Forklift
Region: Europe
Model: Mitsubishi FBC55N Chassis Mast Options Internal Hosing Europe
Part Number: WEBN8474-01
Number of Pages: 538 Pages
01-040-01 CHASSIS WIRE HARNESS - MAIN
01-042-01 CONSOLE BOX
01-042-02 DISPLAY
01-043-01 DC_DC CONVERTER
01-043-02 BACK-UP ALARM (SMART)
01-044-01 HORN ASSEMBLY
01-045-01 POWER CABLE
01-111-01 BATTERY COVER
01-111-02 BATTERY RETAINER
01-114-01 FLOOR PLATES
01-115-01 STANDARD CHASSIS PARTS
01-115-02 STANDARD EUROPEAN CHASSIS PARTS
01-116-01 PLASTIC PARTS
01-120-01 COUNTERWEIGHTS
01-140-01 SEAT
01-150-01 HEAD GUARD ASSEMBLY
01-200-01 TRACTION MOTOR (PART-1)
01-200-02 TRACTION MOTOR (PART-2)
01-201-01 PUMP MOTOR (PART-1)
01-201-02 PUMP MOTOR (PART-2)
01-2POWER STEERING MOTOR (PART-1)
01-202-02 POWER STEERING MOTOR (PART-2)
01-220-01 TRACTION MOTOR CONTROLLER & CONTACTOR PANEL
01-221-02 HYDRAULIC PUMP MOTOR CONTROLLER
01-222-01 CONTACTOR PANEL
01-222-02 CONTACTOR HYD
01-222-03 CONTACTOR LINE
01-222-04 CONTACTOR POWER STEERING
01-270-01 TRANSFER CASE
01-310-01 REDUCTION & DIFFERENTIAL
01-330-01 FRONT AXLE
01-340-01 FRONT TIRES
01-430-01 REAR AXLE (PART-1)
01-430-02 REAR AXLE (PART-2)
01-430-03 STEERING CYLINDER
01-440-01 REAR AXLE MTG
01-450-01 REAR TIRE
01-460-01 WHEEL BRAKE ASSY (L.H.)
01-460-03 WHEEL BRAKE ASSY (R.H.)
01-470-01 BRAKE LINES
01-470-02 MASTER CYLINDER
01-510-01 BRAKE CONTROL
01-511-01 PARKING BRAKE
01-511-02 HAND BRAKE
01-520-01 ACCELERATOR PEDAL AND FNR LEVER
01-540-01 STEERING CONTROL
01-540-02 STEER GEAR ASSY
01-710-01 HYDRAULIC PUMP (PART-1)
01-710-02 HYDRAULIC PUMP (PART-2)
01-711-01 POWER STEERING PUMP (PART-1)
01-711-02 POWER STEERING PUMP (PART-2)
01-720-01 HYDRAULIC CONTROL - 3V
01-720-02 HYD HAND LEVER - 4V
01-720-03 HYDRAULIC CONTROL VALVE - 3V
01-720-04 HYD CONTROL VALVE - 4V
01-740-01 HYDRAULIC TANK
01-750-01 HYDRAULIC LINES-3V
01-750-02 HYDRAULIC LINES -4V
01-751-01 FLOW REGULATOR VALVE
01-811-01A LABELS
01-811-01B LABELS
LIFT BRACKET COMMON PARTS
LIFT BRACKET & BACKRET
TILT CYLINDER (L.H.)
TILT CYLINDER (R.H.)
02-06 FORK
MAST COMMON PARTS (PART-1) (FOR SIMPLEX MAST)
MAST COMMON PARTS (PART-2) (FOR SIMPLEX MAST)
MAST COMMON PARTS (PART-1) (FOR TRIPLEX MAST)
MAST COMMON PARTS (PART-2) (FOR TRIPLEX MAST)
MAST COMMON PARTS (PART-3) (FOR TRIPLEX MAST)
MAST COMMON PARTS (PART-1) (FOR DUPLEX MAST)
MAST COMMON PARTS (PART-2) (FOR DUPLEX MAST)
DUPLEX MAST MODEL B40A32 - B40A36
LIFT CYLINDER (1ST) (FOR B40A32-36)
LIFT CYLINDER (2ND) (FOR B40A32-36)
SIMPLEX MAST MODEL A40A33-45
LIFT CYLINDER (FOR A40A33-45)
SIMPLEX MAST MODEL A55A28-40
LIFT CYLINDER (FOR A55A28-40)
TRIPLEX MAST MODEL C40A50-55
LIFT CYLINDER (1ST) (FOR C40A50-55)
TRIPLEX MAST MODEL C45A47-53
LIFT CYLINDER (1ST) (FOR C45A47-53)
LIFT CYLINDER (2ND) (FOR C45A47-53)
TRIPLEX MAST MODEL C55A47-53
LIFT CYLINDER (1ST) (FOR C55A47-53)
LIFT CYLINDER (2ND) (FOR C55A47-53)
03-043-01 LIGHT KIT 2 FWD_1 REV & TAIL
03-043-02 LIGHT KIT 2 FWD_1 REV
03-043-03 12V LAMP
03-043-04 STROBE LAMP KIT
03-043-05 STROBE LAMP
03-114-01 BATTERY SLIDE KIT
03-115-01 REAR VIEW MIRROR KIT
03-115-02 DRAW BAR PIN KIT
03-115-03 FIRE EXTINGUISHER KIT
03-115-04 BATTERY BOX
03-140-01 CLOTH SEAT KIT
03-140-02 STATIC SEAT CLOTH
03-200-01 SEAT OPERATED PARK BRAKE
03-200-02 ELECTROMAGNETIC BRAKE
03-340-01 DRIVE TIRE, NON-MARKING
03-450-01 STEER TIRE KIT NON-MARKING
03-520-01 FOOT DIR CONTROL KIT
03-720-01 HYD HAND LEVER KIT - 4V
03-811-01A LABELS SPANISH
03-811-02A LABELS FRENCH
03-811-02B LABELS FRENCH
03-811-03A LABELS PORTUGUESE
03-811-03B LABELS PORTUGUESE
MAST PIPING 3-WAY SIMPLEX (STD 3_8 IN) (A40A MAST MODEL)
MAST PIPING 3-WAY SIMPLEX (HIGH 1_2 IN) (A40A MAST MODEL)
MAST PIPING 4-WAY SIMPLEX (STD 3_8 IN) (A40A MAST MODEL)
MAST PIPING 4-WAY SIMPLEX (HIGH 1_2 IN) (A40A MAST MODEL)
MAST PIPING 3-WAY DUPLEX (STD 3_8 IN) (B40A MAST MODEL)
MAST PIPING 4-WAY DUPLEX (HIGH 1_2 IN) (B40A MAST MODEL)
MAST PIPING 3-WAY, 4-WAY DUPLEX (HIGH 1_2 IN, STD 3_8 IN) (B40A MAST MODEL)
MAST PIPING 3-WAY TRIPLEX (STD 3_8 IN) (C40A MAST MODEL)
MAST PIPING 3-WAY TRIPLEX (HIGH 1_2 IN) (C40A MAST MODEL)
MAST PIPING 4-WAY TRIPLEX (STD 3_8 IN) (C40A MAST MODEL)
MAST PIPING 4-WAY TRIPLEX (HIGH 1_2 IN) (C40A MAST MODEL)
MAST PIPING 3-WAY, 4-WAY TRIPLEX (HIGH 1_2 IN, STD 3_8 IN) (C40A MAST MODEL)
1 MAST PIPING KIT 3-WAY SIMPLEX (STD 3_8 IN) A45A
3 MAST PIPING KIT 3-WAY SIMPLEX (HIGH 1_2 IN) A45A
5 MAST PIPING KIT 4-WAY SIMPLEX (STD 3_8 IN) A45A
7 MAST PIPING KIT 4-WAY SIMPLEX (HIGH 1_2 IN) A45A
9 MAST PIPING KIT 3-WAY DUPLEX (STD 3_8 IN) A45A
11 MAST PIPING KIT 3-WAY DUPLEX (HIGH 1_2 IN) B45A
13 MAST PIPING KIT 4-WAY DUPLEX (STD 3_8 IN) B45A
21 MAST PIPING KIT 3-WAY, 4-WAY DUPLEX (HIGH 1_2 IN, STD 3_8 IN) B45A
25 MAST PIPING KIT 3-WAY TRIPLEX (STD 3_8 IN) C45A
29 MAST PIPING KIT 3-WAY TRIPLEX (HIGH 1_2 IN) C45A
33 MAST PIPING KIT 4-WAY TRIPLEX (STD 3_8 IN) C45A
37 MAST PIPING KIT 4-WAY TRIPLEX (HIGH 1_2 IN) C45A
41 MAST PIPING KIT 3-WAY, 4-WAY TRIPLEX (HIGH 1_2 IN, STD 3_8 IN) C45A
1 MAST PIPING KIT 3-WAY SIMPLEX (STD 3_8 IN) A55A
3 MAST PIPING KIT 3-WAY SIMPLEX (HIGH 1_2 IN) A55A
5 MAST PIPING KIT 4-WAY SIMPLEX (STD 3_8 IN) A55A
7 MAST PIPING KIT 4-WAY SIMPLEX (HIGH 1_2 IN) A55A
9 MAST PIPING KIT 3-WAY DUPLEX (STD 3_8 IN) B55A
11 MAST PIPING KIT 3-WAY DUPLEX (HIGH 1_2 IN) B55A
13 MAST PIPING KIT 4-WAY DUPLEX (STD 3_8 IN) B55A
17 MAST PIPING KIT 4-WAY DUPLEX (HIGH 1_2 IN) B55A
21 MAST PIPING KIT 3-WAY, 4-WAY DUPLEX (HIGH 1_2 IN, STD 3_8 IN) B55A
25 MAST PIPING KIT 3-WAY TRIPLEX (STD 3_8 IN) C55A
29 MAST PIPING KIT 3-WAY TRIPLEX (HIGH 1_2 IN) C55A
33 MAST PIPING KIT 4-WAY TRIPLEX (STD 3_8 IN) C55A
37 MAST PIPING KIT 4-WAY TRIPLEX (HIGH 1_2 IN) C55A
41 MAST PIPING KIT 3-WAY, 4-WAY TRIPLEX (HIGH 1_2 IN, STD 3_8 IN) C55A
