Mitsubishi Forklift FB28CA1J Europe Parts Catalog 98724-30000-M-J
Brand: Mitsubishi
Type of Machine: Forklift
Region: Europe
Model: Mitsubishi FB28CA1J Europe
Part Number: 98724-30000-M-J
Number of Pages: 967 Pages
1010 FRAME
1011 COVER 1
1012 COVER 2
1014A PAD & FLOOR PLATE 20CA1_25CA1_28CA1
1014B PAD & FLOOR PLATE 30CA1
1015A BATTERY COVER 20CA1_25CA1_28CA1
1030 BATTERY CASE
1040 COUNTER BALANCE WEIGHT
1050 SEAT
1060 OVERHEAD GUARD
10931 NAME PLATE FIT. MIT brand
10932 NAME PLATE MIT brand
1094B NAME PLATE [SF]
1095 KNOB PLATE [SF]
1130 FRONT AXLE 1
1131 FRONT AXLE 2
1132 FRONT AXLE 3
1133 FRONT AXLE 4
1134 FRONT AXLE 5
1135A FRONT AXLE 6 WHEEL BRAKE, 20CA1_25CA1_28CA1
1135B FRONT AXLE 6 WHEEL BRAKE, 30CA1
1140A FRONT WHEEL [Pst_Pnst]
1140B FRONT WHEEL Double tire, 20CA1_25CA1_28CA1
1140C FRONT WHEEL Double tire, 30CA1
1150 FRONT AXLE FIT.
1230 REAR AXLE 1
1231 REAR AXLE 2
1240A REAR WHEEL 20CA1_25CA1_28CA1,[Pst_Pnst]
1240B REAR WHEEL 30CA1,[Pst_Pnst]
1310 STEERING LINKAGE 1 STEERING WHEEL
1311 STEERING LINKAGE 2
1312 STEERING LINKAGE 3
1313 STEERING LINKAGE 4 ACTUATOR
1320 FOOT BRAKE LINKAGE 1
1321 FOOT BRAKE LINKAGE 2 MASTER CYLINDER
1330 PARKING BRAKE LINKAGE
1340A VALVE LINKAGE 1 2 Spools
1340B VALVE LINKAGE 1 3 Spools
1340C VALVE LINKAGE 1 4 Spools
1340D VALVE LINKAGE 1 Finger tip 3 Spools
1340E VALVE LINKAGE 1 Finger tip 4 Spools
1340F VALVE LINKAGE 1 A. O. S, 2 Spools
1340G VALVE LINKAGE 1 A. O. S, 3 Spools
1341A VALVE LINKAGE 2 2 Spools
1341B VALVE LINKAGE 2 3 Spools
1341C VALVE LINKAGE 2 4 Spools
1350 ACCELERATOR LINKAGE
1500A OIL TANK RESIN OIL TANK
1500B OIL TANK IRON OIL TANK
1500C OIL TANK MIL STANDARD OIL TANK
1510 OIL PUMP
1520A CONTROL VALVE 2 Spools
1520B CONTROL VALVE 3 Spools
1520C CONTROL VALVE 4 Spools
1551 FRAME PIPING 1
1552 FRAME PIPING 2
1553A JOINT PIPING [SF] 3,4 Spools(1_4)
1553B JOINT PIPING [SF] 3,4 Spools(3_8)
1556 BRAKE PIPING
2053A LIFT CYLINDER [Pm] 20CA1_25CA1,MLH_3000,3300
2053B LIFT CYLINDER [Pm] 20CA1_25CA1,MLH_3500-5000
2053C LIFT CYLINDER [Pm] 20CA1_25CA1,CS_FCS_RP_DRP
2053D LIFT CYLINDER [Pm] 28CA1_30CA1
2053E LIFT CYLINDER [Pm] 28CA1_30CA1,CS_FCS_RP_DRP
2054A TILT CYLINDER [Pm]
2054B TILT CYLINDER [Pm] FCS
2058A MAST PIPING[Pm] [SF] 20CA1_25CA1, w.o_LASER POINTER
2058B MAST PIPING[Pm] [SF] 20CA1_25CA1, w_LASER POINTER
2058C MAST PIPING[Pm] [SF] 28CA1_30CA1, w.o_LASER POINTER
2058D MAST PIPING[Pm] [SF] 28CA1_30CA1, w_LASER POINTER
2059A MAST PIPING [Pm] 20CA1_25CA1,[Std_MLH33300]
2059B MAST PIPING [Pm] 20CA1_25CA1 , [Std_MLH3500-5000],[CS_FCS_RP_DRP]
2059C MAST PIPING [Pm] 28CA1_30CA1
2059D MAST PIPING [Pm] 28CA1_30CA1,CS_FCS_RP_DRP
2059E MAST PIPING [Pm] 20CA1_25CA1,[MLH_=3500]
2061A OUTER MAST [Pm] 20CA1_25CA1
2061B1 OUTER MAST [Pm] 28CA1_30CA1
2061B2 OUTER MAST [Pm] 28CA1_30CA1, For MHI
2063A INNER MAST [Pm] 20CA1_25CA1
2063B1 INNER MAST [Pm] 28CA1_30CA1
2063B2 INNER MAST [Pm] 28CA1_30CA1, For MHI
2064A CHAIN WHEEL [Pm] 20CA1_25CA1
2064B1 CHAIN WHEEL [Pm] 28CA1_30CA1
2064B2 CHAIN WHEEL [Pm] 28CA1_30CA1, For MHI
2080A MAST PIPING[Pm] For MHI , w.o_LASER POINTER
2080B MAST PIPING[Pm] For MHI , w_LASER POINTER
2152A LIFT CYLINDER(1st) [Mm] 20CA1_25CA1
2152B LIFT CYLINDER(1st) [Mm] 20CA1_25CA1,CS_FCS_RP_DRP
2152C LIFT CYLINDER(1st) [Mm] 28CA1_30CA1
2152D LIFT CYLINDER(1st) [Mm] 28CA1_30CA1,CS_FCS_RP_DRP
2153A LIFT CYLINDER(2nd) [Mm] 20CA1_25CA1
2153B LIFT CYLINDER(2nd) [Mm] 20CA1_25CA1,CS_FCS_RP_DRP
2153C LIFT CYLINDER(2nd) [Mm] 28CA1_30CA1
2153D LIFT CYLINDER(2nd) [Mm] 28CA1_30CA1,CS_FCS_RP_DRP
2154A TILT CYLINDER [Mm]
2154B TILT CYLINDER [Mm] FCS
2157A MAST PIPING[Mm] 1[SF] CASCADE SF, w.o_LASER POINTER
2157B MAST PIPING[Mm] 1[SF] CASCADE SF, w_LASER POINTER
2157C MAST PIPING[Mm] 1[SF] INTEGRAL SF, w.o_LASER POINTER
2157D MAST PIPING[Mm] 1[SF] INTEGRAL SF, w_LASER POINTER
2158A MAST PIPING [Mm]1 20CA1_25CA1
2158B MAST PIPING [Mm]1 20CA1_25CA1,CS_FCS_RP_DRP
2158C1 MAST PIPING [Mm]1 28CA1_30CA1
2158C2 MAST PIPING [Mm]1 28CA1_30CA1, For MHI
2158D1 MAST PIPING [Mm]1 28CA1_30CA1,CS_FCS_RP_DRP
2158D2 MAST PIPING [Mm]1 28CA1_30CA1,CS_FCS_RP_DRP, For MHI
2159A MAST PIPING [Mm]2 20CA1_25CA1
2159B MAST PIPING [Mm]2 20CA1_25CA1,CS_FCS_RP_DRP
2159C1 MAST PIPING [Mm]2 28CA1_30CA1
2159C2 MAST PIPING [Mm]2 28CA1_30CA1, For MHI
2159D1 MAST PIPING [Mm]2 28CA1_30CA1,CS_FCS_RP_DRP
2159D2 MAST PIPING [Mm]2 28CA1_30CA1,CS_FCS_RP_DRP, For MHI
2161A OUTER MAST [Mm] 20CA1_25CA1
2161B1 OUTER MAST [Mm] 28CA1_30CA1
2161B2 OUTER MAST [Mm] 28CA1_30CA1, For MHI
2162A MIDDLE MAST [Mm] 20CA1_25CA1
2162B1 MIDDLE MAST [Mm] 28CA1_30CA1
2162B2 MIDDLE MAST [Mm] 28CA1_30CA1, For MHI
2163A INNER MAST [Mm] 20CA1_25CA1
2163B1 INNER MAST [Mm] 28CA1_30CA1
2163B2 INNER MAST [Mm] 28CA1_30CA1, For MHI
2164A CHAIN WHEEL(MAST) [Mm] 20CA1_25CA1
2164B1 CHAIN WHEEL(MAST) [Mm] 28CA1_30CA1
2164B2 CHAIN WHEEL(MAST) [Mm] 28CA1_30CA1, For MHI
2165A CHAIN WHEEL(LIFT) [Mm] 20CA1_25CA1
2165B1 CHAIN WHEEL(LIFT) [Mm] 28CA1_30CA1
2165B2 CHAIN WHEEL(LIFT) [Mm] 28CA1_30CA1, For MHI
2252A LIFT CYLINDER(1st) [Fm] 20CA1_25CA1
2252B LIFT CYLINDER(1st) [Fm] 20CA1_25CA1,CS_FCS_RP_DRP
2252C LIFT CYLINDER(1st) [Fm] 28CA1_30CA1
2252D LIFT CYLINDER(1st) [Fm] 28CA1_30CA1,CS_FCS_RP_DRP
2252E LIFT CYLINDER(1st)[Fm] MHI
2252F LIFT CYLINDER(1st) [Fm] MHI, CS_FCS_RP_DRP
2253A LIFT CYLINDER(2nd) [Fm] 20CA1_25CA1
2253B LIFT CYLINDER(2nd) [Fm] 20CA1_25CA1,CS_FCS_RP_DRP
2253C LIFT CYLINDER(2nd) [Fm] 28CA1_30CA1
2253D LIFT CYLINDER(2nd) [Fm] 28CA1_30CA1,CS_FCS_RP_DRP
2253E LIFT CYLINDER(2nd)[Fm] MHI
2253F LIFT CYLINDER (2nd) [Fm] MHI,CS_FCS_RP_DRP
2254A TILT CYLINDER [Fm]
2254B TILT CYLINDER [Fm] FCS
2257 MAST PIPING[Fm] 1[SF] w_LASER POINTER
2258A MAST PIPING[Fm] 2[SF] CASCADE SF, w.o_LASER POINTER
2258B MAST PIPING[Fm] 2[SF] CASCADE SF, w_LASER POINTER
2258C MAST PIPING[Fm] 2[SF] INTEGRAL SF, w.o_LASER POINTER
2259A1 MAST PIPING [Fm]
2259A2 MAST PIPING [Fm] For MHI
2261A OUTER MAST [Fm] 20CA1_25CA1
2261B OUTER MAST [Fm] 28CA1_30CA1
2261C OUTER MAST [Fm] For MHI
2263A INNER MAST [Fm] 20CA1_25CA1
2263B INNER MAST [Fm] 28CA1_30CA1
2263C INNER MAST[Fm] For MHI
2264A CHAIN WHEEL [Fm] 20CA1_25CA1
2264B CHAIN WHEEL [Fm] 28CA1_30CA1
2264C CHAIN WHEEL[Fm] For MHI
3620A LIFT BRACKET [Pm] 20CA1_25CA1
3620B LIFT BRACKET [Mm] 20CA1_25CA1
3620C LIFT BRACKET [Fm] 20CA1_25CA1
3620D1 LIFT BRACKET [Pm] 28CA1_30CA1
3620D2 LIFT BRACKET [Pm] 28CA1_30CA1, For MHI
3620E1 LIFT BRACKET [Mm] 28CA1_30CA1
3620E2 LIFT BRACKET [Mm] 28CA1_30CA1, For MHI
3620F1 LIFT BRACKET [Fm] 28CA1_30CA1
3620F2 LIFT BRACKET [Fm] 28CA1_30CA1, For MHI
3620G LIFT BRACKET [Pm][SF] w_LASER POINTER, 20CA1_25CA1
3620H LIFT BRACKET [Mm][SF] w_LASER POINTER, 20CA1_25CA1
3620I LIFT BRACKET [Fm][SF] w_LASER POINTER, 20CA1_25CA1
3620J LIFT BRACKET [Pm][SF] w_LASER POINTER, 28CA1_30CA1
3620K LIFT BRACKET [Mm][SF] w_LASER POINTER, 28CA1_30CA1
3620L LIFT BRACKET [Fm][SF] w_LASER POINTER, 28CA1_30CA1
3630A FORK 20CA1_25CA1
3630B FORK 20CA1_25CA1,DRP
3630C FORK 28CA1_30CA1
3630D FORK 28CA1_30CA1,DRP
3640A BACKREST 20CA1_25CA1
3640B BACKREST 20CA1_25CA1,DRP
3640C BACKREST 28CA1_30CA1
3640D BACKREST 28CA1_30CA1,DRP
3650A SIDESHIFT [SF] 20CA1_25CA1, CASCADE SF
3650B SIDESHIFT [SF] 28CA1_30CA1, CASCADE SF
3650C SIDESHIFT [Pm][SF] INTEGRAL SF
3650D SIDESHIFT [Mm][SF] INTEGRAL SF
3650E SIDESHIFT [Fm][SF] INTEGRAL SF
3690 SHIFT CYLINDER BOOT [SF]
4071 TRACTION MOTOR
4072A HYDRAULIC MOTOR 20CA1_25CA1_28CA1
4072B HYDRAULIC MOTOR 30CA1
4072C HYDRAULIC MOTOR 20HCA1_25HCA1
4073 EPS MOTOR
4400A MAIN CONTROLLER 1
4400B MAIN CONTROLLER 1 AS
4401A MAIN CONTROLLER 2
4401B MAIN CONTROLLER 2 AS
4403A MAIN CONTROLLER 3 WIRE HARNESS
4403B MAIN CONTROLLER 3 WIRE HARNESS, AS
4410 CONTACTOR
4500A EPS CONTROLLER
4500B EPS CONTROLLER AS
4800A BATTERY Hitachi Chemical Company
4800B BATTERY GS Yuasa
4810A CHARGER(BC) 1 AC200V
4810B CHARGER(BC) 1 AC400V
4810C CHARGER Stationary charger
4811A CHARGER(BC) 2 AC200V
4811B CHARGER(BC) 2 AC400V
4823 DISPLAY PANEL
4824 DISPLAY PANEL
4825 DIRECTIONAL SWITCH
4851A WIRE HARNESS (BODY)
4851B WIRE HARNESS (BODY) AS
4852A WIRE HARNESS (MAIN) 20CA1_25CA1_28CA1,(-565Ah)
4852B WIRE HARNESS (MAIN) 20CA1_25CA1_28CA1 (600Ah-)
4852C WIRE HARNESS (MAIN) 30CA1
4853 WIRE HARNESS AS
4858 WIRE HARNESS (CHARGER)
4860 ELECTRIC PARTS 1
4861 ELECTRIC PARTS 2
4862 ELECTRIC PARTS 3 A.O.S
4865 MICROSWITCH
4875 WATER REPLENISHING SIGNAL
4877A BUZZER
4877B BUZZER BACK LEAD
4889A HEAD LAMP
4889B HEAD LAMP LED
4895 HORN
5000A ACCESSORY [REAR LAMP_BACKUP LAMP]
5000B ACCESSORY [SPOT LAMP]
5000C ACCESSORY [WORKING LAMP]
5000D ACCESSORY [REVOLVING LAMP]
5000E ACCESSORY [REVOLVING LAMP(LED)]
5000F ACCESSORY CHIME
5000G ACCESSORY CHIME(with Switch)
5000H ACCESSORY [MAGIC EYE]
5064 HEADGUARD ROOF
5173 SEAT HEATER
5471 LIFT LIMIT 1 1 STAGE TYPE
5472 LIFT LIMIT 2 2 STAGES TYPE
5473A LIFT LIMIT 3 [SWITCH & HARNESS], 1 STAGE TYPE
5473B LIFT LIMIT 3 [SWITCH & HARNESS], 2 STAGES TYPE
5862 POWERMETER
5863 CHARGE OVERHEAT WARNING 1
5864 CHARGE OVERHEAT WARNING 2
6000A LASER POINTER 1[Pm] WIRE HARNESS, 20CA1_25CA1
6000B LASER POINTER 1[Pm] WIRE HARNESS, 28CA1_30CA1
6000C LASER POINTER 1[Mm] WIRE HARNESS
6000D LASER POINTER 1[Fm] WIRE HARNESS
6010 LASER POINTER 2 SENSOR & SWITCH
6011 LASER POINTER 3 LASER
Brand: Mitsubishi
Region: Europe
1010 FRAME
1011 COVER 1
1012 COVER 2
1030 BATTERY CASE
1050 SEAT
1060 OVERHEAD GUARD
1130 FRONT AXLE 1
1131 FRONT AXLE 2
1132 FRONT AXLE 3
1133 FRONT AXLE 4
1134 FRONT AXLE 5
1230 REAR AXLE 1
1231 REAR AXLE 2
1510 OIL PUMP
1551 FRAME PIPING 1
1552 FRAME PIPING 2
1556 BRAKE PIPING
4071 TRACTION MOTOR
4073 EPS MOTOR
4410 CONTACTOR
4823 DISPLAY PANEL
4824 DISPLAY PANEL
4865 MICROSWITCH
4877A BUZZER
4889A HEAD LAMP
4889B HEAD LAMP LED
4895 HORN
5064 HEADGUARD ROOF
5173 SEAT HEATER
5862 POWERMETER
- Mitsubishi Forklift Trucks FB20CA,FB25CA,FB28CA,FB30CA Parts Manual
- Mitsubishi Lift Trucks Diesel Engines S4E S4E2 S6E S6E2 42080-Up Parts Catalog
- MITSUBISHI S4K, S6K Engine Service Manual
- Mitsubishi Diesel Engines 4DQ3 4DQ3-T 4DQ5 03044-up 09658-up Parts Catalog
- Mitsubishi Forklift Trucks FB10TCA,FB14TCA,FB15TCA,FB18TCA Parts Manual
- MITSUBISHI S4S, S6S Engine Service Manual
- Mitsubishi Forklift Trucks FBP16 FBP18 FBP20 FBP25 FBP30 WEBN2685 Parts Catalog
- Mitsubishi Engine К21 К25 Repair Manual (used with Nissan forklift Mitusbishi Forklift)
- Misubishi Forklift GM 4.3L (G6) Engine Service Manual
- Mitsubishi Forklift FD25 Service Manual
- Mitsubishi Diesel Engines FD20 FD25 FD30 FD35A 11405-Up Parts Catalog
- Mitsubishi FG20K FD20K FG25K FD25K EF17B-15001-up EF18B-65001-up Parts Catalog
- Mitsubishi Forklift FG15 Service Manual
- Mitsubishi Forklift FGC25 Service Manual
- Mitsubishi Lift Trucks FG 20_23_25 FD 20_23_25 10001-Up_60001-Up Parts Catalog
