Mitsubishi Forklift FB20TBCBJ Europe Parts Catalog 12-P-2801-M-J
Brand: Mitsubishi
Type of Machine: Forklift
Region: Europe
Model: Mitsubishi FB20TBCBJ Europe
Part Number: 12-P-2801-M-J
Number of Pages: 381 Pages
10100 FRAME
10110 COVER
10111 PANEL
10112 PAD & FLOOR PLATE
10113A BATTERY COVER 350-565Ah
10113B BATTERY COVER 645Ah,730Ah
10290 LAMP COVER
10400 COUNTER BALANCE WEIGHT
10500 SEAT
10600A OVERHEAD GUARD Division type
10600B OVERHEAD GUARD Welding unify type
10950 NAME PLATE FIT.
10951 NAME PLATE
10952 NAME PLATE FIT. [SF]
10954 NAME PLATE FIT. LASER POINTER
11300 FRONT AXLE 1
11301A1 FRONT AXLE 2 (-288E00642,-283E00016)
11301A2 FRONT AXLE 2 (288E00643-,283E00017-)
11400A FRONT WHEEL
11400B FRONT WHEEL Snow tire
11400C FRONT WHEEL Color tire, Cushion tire
11500 FRONT AXLE FIT.
12300 REAR AXLE 1
12301 REAR AXLE 2
12400A REAR WHEEL
12400B REAR WHEEL Color tire
13100 STEERING LINKAGE 1 STEERING WHEEL
13101 STEERING LINKAGE 2
13102 STEERING LINKAGE 3
13103 STEERING LINKAGE 4
13210 FOOT BRAKE LINKAGE 1
13211 FOOT BRAKE LINKAGE 2 MASTER CYLINDER
13300 PARKING BRAKE LINKAGE 1
13301 PARKING BRAKE LINKAGE 2
13400A VALVE LINKAGE 1 2 SPOOLS
13400B VALVE LINKAGE 1 3 SPOOLS
13400C VALVE LINKAGE 1 4 SPOOLS
13401A VALVE LINKAGE 2 2 SPOOLS
13401B VALVE LINKAGE 2 3 SPOOLS
13401C VALVE LINKAGE 2 4 SPOOLS
13500 ACCELERATOR LINKAGE
15000A OIL TANK RESIN OIL TANK
15000B OIL TANK IRON OIL TANK
15100 OIL PUMP
15200A CONTROL VALVE 2 SPOOLS
15200B CONTROL VALVE 3 SPOOLS
15200C CONTROL VALVE 4 SPOOLS
15510A FRAME PIPING 2 SPOOLS
15510B FRAME PIPING 3,4 SPOOLS
15560 BRAKE PIPING
20520A LIFT CYLINDER [Pm]
20520B LIFT CYLINDER [Pm] CS_RP
20540 TILT CYLINDER [Pm]
20560A MAST PIPING [Pm]
20560B MAST PIPING [Pm] CS_RP
20580A MAST PIPING [Pm][SF] w.o_LASER POINTER
20580B MAST PIPING [Pm][SF] w_LASER POINTER
20610A OUTER MAST [Pm] w.o_LASER POINTER
20610B OUTER MAST [Pm] w_LASER POINTER
20630 INNER MAST [Pm]
20640 CHAIN WHEEL [Pm]
20900 WIRING MAST [Pm] LASER POINTER
21520A LIFT CYLINDER(1st) [Mm]
21530A LIFT CYLINDER(2nd) [Mm] [STD_MLH_6500]
21530B LIFT CYLINDER(2nd) [Mm] [STD_MLH_=6500], CS_RP
21540 TILT CYLINDER [Mm]
21560A MAST PIPING [Mm] [STD_MLH_6500]
21560B MAST PIPING [Mm] [STD_MLH_=6500], CS_RP
21580A MAST PIPING [Mm][SF] w.o_LASER POINTER
21580B MAST PIPING [Mm][SF] w_LASER POINTER
21610 OUTER MAST [Mm]
21620 MIDDLE MAST [Mm]
21630 INNER MAST [Mm]
21640 CHAIN WHEEL(MAST) [Mm]
21650 CHAIN WHEEL(LIFT) [Mm]
21900 WIRING MAST [Mm] LASER POINTER
22520A LIFT CYLINDER(1st) [Fm]
22520B LIFT CYLINDER(1st) [Fm] CS_RP
22530A LIFT CYLINDER(2nd) [Fm]
22530B LIFT CYLINDER(2nd) [Fm] CS_RP
22540 TILT CYLINDER [Fm]
22560 MAST PIPING [Fm]
22580A MAST PIPING [Fm][SF] w.o_LASER POINTER
22580B MAST PIPING [Fm][SF] w_LASER POINTER
22610 OUTER MAST [Fm]
22630 INNER MAST [Fm]
22640 CHAIN WHEEL [Fm]
22900 WIRING MAST LASER POINTER [Fm]
36200B LIFT BRACKET [Mm]
36200C LIFT BRACKET [Fm]
36200D LIFT BRACKET [Pm]
36201A LIFT BRACKET [Pm][SF] CASCADE SF
36201B LIFT BRACKET [Mm][SF] CASCADE SF, w_LASER POINTER
36201C LIFT BRACKET [Fm][SF] CASCADE SF, w_LASER POINTER
36300 FORK
36400A BACKREST
36400B BACKREST [SF] CASCADE SF
36500A SIDESHIFT [Pm][SF] INTEGRAL SF
36500B SIDESHIFT [Mm][SF] INTEGRAL SF
36500C SIDESHIFT [Fm][SF] INTEGRAL SF
36500D SIDESHIFT [Pm][SF] CASCADE SF
36500E SIDESHIFT [Mm][SF] CASCADE SF
36500F SIDESHIFT [Fm][SF] CASCADE SF
36900 SHIFT CYLINDER BOOT [SF]
40710 TRACTION MOTOR
40720 HYDRAULIC MOTOR
40730 EPS MOTOR [EIKOU]
44000A CONTROL UNIT 1
44000B CONTROL UNIT 1 Australia Spec
44001A CONTROL UNIT 2
44001B CONTROL UNIT 2 Australia Spec
44002A CONTROL UNIT 3
44002B CONTROL UNIT 3 Australia Spec
44003A1 CONTROL UNIT 4 WIRE HARNESS,(-288E01-283E00024)
44003A2 CONTROL UNIT 4 WIRE HARNESS,(288E01068-_283E00025-)
44003B CONTROL UNIT 4 WIRE HARNESS Australia Spec
44004A CONTROL UNIT 5 FAN
44004B CONTROL UNIT 5 FAN Australia Spec
44300 DIRECTIONAL SWITCH
44760 FORK LEVELING
45000A EPS CONTROLLER
45000B EPS CONTROLLER Australia Spec
48000A BATTERY (48V)
48000B BATTERY (48V)
48100A CHARGER(BC) AC200V
48100B CHARGER(BC) AC400V
48110A TRANSFORMER AC200V
48110B TRANSFORMER AC400V
48250 DISPLAY PANEL
48430 PLUG(BC)
48510A1 WIRE HARNESS (BODY) 20PN(-288E00101),20PBN(-283E0005)
48510A2 WIRE HARNESS (BODY) 20PN(288E00102-),20PBN(283E0006-)
48510B WIRE HARNESS (BODY) Australia Spec
48511 WIRE HARNESS (BATTERY)
48512 WIRE HARNESS Australia Spec
48600 ELECTRIC PARTS 1
48601 ELECTRIC PARTS 2
48850 LASER POINTER 1 LASER
48851 LASER POINTER 2 SWITCH & NAME PLATE
48890 HEAD LAMP
50000A ACCESSORY REAR LAMP
50000B ACCESSORY REVOLVING LAMP
50000C ACCESSORY REVOLVING LAMP(LED)
50000D ACCESSORY WORKING LAMP
50000E ACCESSORY HEAD LAMP GUARD
50000F ACCESSORY EXTINGUISHER
50000G ACCESSORY EARTH CHAIN
50000H ACCESSORY BACK MIRROR
50000I ACCESSORY ROOM MIRROR
50000J ACCESSORY CHIME
50660 HEADGUARD ROOF
59160 PROTECTOR
54710 LIFT LIMIT 1
