Mitsubishi Forklift FB18NT Chassis Mast Options Internal Hosing Europe Parts Catalog 98754-36010
Brand: Mitsubishi
Type of Machine: Forklift
Region: Europe
Model: Mitsubishi FB18NT Chassis Mast Options Internal Hosing Europe
Part Number: 98754-36010
Number of Pages: 414 Pages
ELECTRIC SYSTEM
LIGHTING SYSTEM
SENSING SYSTEM
HARNESS & POWER CABLES (PART-1)
HARNESS & POWER CABLES (PART-2)
FRAME
CHASSIS ACCESSORY (PART-1)
CHASSIS ACCESSORY (PART-2)
INTERIOR PARTS
CONTROLLER COVER
COUNTER WEIGHT
SEAT (FOR FC MODEL)
SEAT (FOR MC MODEL)
HEAD GUARD
MOTOR
TRACTION MOTOR
PUMP MOTOR
CONTROLLER ACCESSORY
TRANSFER & DIFF (L.H.)
TRANSFER & DIFF (R.H.)
FRONT AXLE
FRONT TIRE
REAR AXLE (PART-1)
REAR AXLE (PART-2)
REAR TIRE
BRAKE SYSTEM (PART-1)
BRAKE SYSTEM (PART-2)
CALIPER ASSY
BRAKE CONTROL (PART-1)
BRAKE CONTROL (PART-2)
BRAKE CONTROL (PART-3)
ACCELERATOR PEDAL
STEERING SYSTEM
STEERING WHEEL
CONTROLLER
LOGICS UNIT
INVERTER (PART-1)
INVERTER (PART-2)
CONTACTOR ASSY
CONTACTOR
HYDRAULIC PUMP
CONTROL VALVE (3 VALVES)PART-1 (FOR FC MODEL)
CONTROL VALVE (3 VALVES)PART-2 (FOR FC MODEL)
CONTROL VALVE (4 VALVES) (FOR FC MODEL)
CONTROL VALVE (3 VALVES)PART-1 (FOR MC MODEL)
CONTROL VALVE (3 VALVES)PART-2 (FOR MC MODEL)
CONTROL VALVE (4 VALVES) (FOR MC MODEL)
ADJUSTER ASSY (FOR FC MODEL)
LEVER (FOR FC MODEL)
HYDRAULIC LEVER (FOR MC MODEL)
HYDRAULIC TANK
HYDRAULIC LINE (PART-1)
HYDRAULIC LINE (PART-2)
HYDRAULIC LINE (PART-3)
FLOW REGULATOR VALVE
ATTACHMENT VALVE PIPING
NAME-PLATE
LIFT BRACKET COMMON PARTS
LIFT BRACKET
BACKREST
02-04-01A TILT CYLINDER (L.H.) (OLD) (FOR 6DEGREES-7DEGREES,-5DEGREES,-3DEGREES)
02-04-01B TILT CYLINDER (L.H.) (NEW) (FOR 6DEGREES-7DEGREES,-5DEGREES,-3DEGREES)
02-04-02A TILT CYLINDER (R.H.) (OLD) (FOR 6DEGREES-7DEGREES,-5DEGREES,-3DEGREES)
02-04-02B TILT CYLINDER (R.H.) (NEW) (FOR 6DEGREES-7DEGREES,-5DEGREES,-3DEGREES)
FORK
MAST COMMON PARTS (PART-1) (FOR 2G15A & 1G20A)
MAST COMMON PARTS (PART-2) (FOR 2G15A & 1G20A)
MAST COMMON PARTS (PART-1) (FOR 2J15A & 1J20A)
MAST COMMON PARTS (PART-2) (FOR 2J15A & 1J20A)
MAST COMMON PARTS (PART-3) (FOR 2J15A & 1J20A)
MAST COMMON PARTS (PART-4) (FOR 2J15A & 1J20A)
MAST COMMON PARTS (PART-1) (FOR 2H15A & 1H20A)
MAST COMMON PARTS (PART-2) (FOR 2H15A & 1H20A)
MAST COMMON PARTS (PART-3) (FOR 2H15A & 1H20A)
DUPLEX MAST MODEL 2H15A30-40
02-18-01A LIFT CYLINDER (1ST) (OLD) (FOR 2H15A & 1H20A)
02-18-01B LIFT CYLINDER (1ST) (NEW) (FOR 2H15A & 1H20A)
LIFT CYLINDER (2ND) (FOR 2H15A & 1H20A)
DUPLEX MAST MODEL 1H20A30-40
TRIPLEX MAST MODEL 2J15A37-70
02-20-01A LIFT CYLINDER (1ST) (OLD) (FOR 2J15A & 1J20A)
02-20-01B LIFT CYLINDER (1ST) (NEW) (FOR 2J15A & 1J20A)
02-20-02A LIFT CYLINDER (2ND) (OLD) (FOR 2J15A & 1J20A)
02-20-02B LIFT CYLINDER (2ND) (NEW) (FOR 2J15A & 1J20A)
TRIPLEX MAST MODEL 1J20A37-70
SIMPLEX MAST MODEL 2G15A20-60
02-60-01A LIFT CYLINDER (OLD) (FOR 2G15A & 1G20A)
02-60-01B LIFT CYLINDER (NEW) (FOR 2G15A & 1G20A)
SIMPLEX MAST MODEL 1G20A20-60
PUMP MOTOR FAN KIT
TRACTION MOTOR FAN KIT
ARMREST FNR SWITCH KIT (FC MODEL)
BATTERY BOX
CONNECTOR KIT
DC_DC CONVERTER KIT
FIRE EXTINGUISHER KIT
WORKING LAMP 12V KIT
AMBER STROBE KIT
ROAD LIGHT KIT
TM1990 POWER TAP 9040106168
TM2070 FAST CHARGE GROUP 9040111158
CLOTH SEAT (FOR FC MODEL)
CLOTH SEAT (FOR MC MODEL)
TM1870 - OPTION ARMREST FOLD DOWN RH SEAT BELT RETRACT (UP TO 2018-02)
TM5190 HEADGUARD GROUP, DRIVE-IN-RACK 9040105922
TM5190 HEADGUARD GROUP, DRIVE-IN-RACK 9040106679
TM5190 HEADGUARD GROUP, DRIVE-IN-RACK 9040113190
FRONT TIRE KIT (NONMARKING)
FRONT TIRE KIT (NONMARKING) (FB16NT, FB18NT)
FRONT TIRE KIT (PNEUMATIC) (FB16NT, FB18NT)
FRONT TIRE KIT (CUSHION)
REAR TIRE KIT (PNEUMATIC) (FB16NT, FB18NT)
REAR TIRE KIT (CUSHION)
BRAKE PEDAL ASSY (FOR FOOT DIRECTION KIT)
FOOT DIRECTION CONTROL KIT
TM3320 INSTALLATION GROUP - 1 FUNCTION CASCADE MAST 9040105013
TM3320 INSTALLATION GROUP - 2 FUNCTION MAST 9040105014
TM3330 INSTALLATION GROUP - 1 FUNCTION CASCADE MAST 9040105013
TC3330 INSTALLATION GROUP - 2 FUNCTION MAST 9040105014
TM3340 INSTALLATION GROUP - 1 FUNCTION CASCADE MAST 9040105013
TM3340 INSTALLATION GROUP - 2 FUNCTION MAST 9040105014
FORK STOPPER (FOR BACKREST-LESS)
MAST HOOK KIT (2G15A, 1G20A20-60)
MAST HOOK KIT (2J15A, 1J20A37-70)
MAST HOOK KIT (2H15A, 1H20A30-40)
04-23 MAST PIPING KIT(3-WAY SIMPLEX) (FOR 2G15CA20-60)
04-24 MAST PIPING KIT(4-WAY SIMPLEX) (FOR 2G15CA20-60)
04-25 MAST PIPING KIT (3-WAY DUPLEX) (FOR 2H15CA30-40)
04-26 MAST PIPING KIT (4-WAY DUPLEX) (FOR 2H15CA30-40)
04-27 MAST PIPING KIT (3-WAY TRIPLEX) (FOR 2J15CA37-70)
04-28 MAST PIPING KIT (4-WAY TRIPLEX) (FOR 2J15CA37-70)
MAST PIPING KIT (3-WAY SIMPLEX) INTEGRAL SIDESHIFTER
MAST PIPING KIT (4-WAY SIMPLEX) INTEGRAL SIDESHIFTER
MAST PIPING KIT (3-WAY DUPLEX) INTEGRAL SIDESHIFTER
MAST PIPING KIT (4-WAY DUPLEX) INTEGRAL SIDESHIFTER
04-43 MAST PIPING KIT(3-WAY TRIPLEX) INTEGRAL SIDESHIFTER
04-43 MAST PIPING KIT(4-WAY TRIPLEX) INTEGRAL SIDESHIFTER
