Mitsubishi Forklift FB18KT Chassis Mast Options Europe Parts Catalog 98714-30030
Brand: Mitsubishi
Type of Machine: Forklift
Region: Europe
Model: Mitsubishi FB18KT Chassis Mast Options Europe
Part Number: 98714-30030
Number of Pages: 286 Pages
ELECTRIC SYSTEM (MAIN CABLE)
ELECTRIC SYSTEM (MAIN HARNESS)
ELECTRIC SYSTEM (CONSOLE BOX)
ELECTRIC EQUIPMENT
JOYSTICK BOX (FC MODEL)
POWER RELAY (FC MODEL)
POWER RELAY (MC MODEL)
FRAME & BODY (PART-1)
SEAT (OLD TYPE)
SEAT (NEW TYPE)
HEAD GUARD
01-20-01A TRACTION MOTOR (OLD TYPE) (PRESTOLITE MAKE)
01-20-01B TRACTION MOTOR (NEW TYPE) (SCHABMULLER MAKE)
01-20-02A PUMP MOTOR (OLD TYPE) (OLDHAM COUPLING)
01-20-02B PUMP MOTOR (NEW TYPE) (SPLINED MUFF)
01-20-03A POWER STEERING MOTOR (OLD TYPE)
01-20-03B POWER STEERING MOTOR(NEW TYPE)
MOTOR CONTROLLER
MAIN CONTROLLER ASSY (PART-1) (PRESTOLITE MOTOR)
MAIN CONTROLLER ASSY (PART-2) (PRESTOLITE MOTOR)
MAIN CONTROLLER ASSY (PART-3) (PRESTOLITE MOTOR)
MAIN CONTROLLER ASSY (PART-1) (SCHABMULLER MOTOR)
MAIN CONTROLLER ASSY (PART-2) (SCHABMULLER MOTOR)
MAIN CONTROLLER ASSY (PART-3) (SCHABMULLER MOTOR)
CONTACTOR
TRANSFER & DIFFERENTIAL (L.H.)
TRANSFER & DIFFERENTIAL (R.H.)
FRONT AXLE
REAR AXLE
REAR AXLE ASSY
BRAKE PIPING
PARKING BRAKE
CALIPER ASSY
01-51-01A BRAKE PEDAL ASSY (OLD TYPE)
01-51-01B BRAKE PEDAL ASSY (NEW TYPE)
ACCEL PEDAL
HAND BRAKE
TILT STEERING
01-54-01A STEERING GEAR (OLD TYPE) (W_O RELIEF VALVE)
01-54-01B STEERING GEAR (NEW TYPE) (W_O RELIEF VALVE)
01-54-01C STEERING GEAR (W_RELIEF VALVE)
STEERING WHEEL
01-71-01A HYDRAULIC PUMP (OLD TYPE) (OLDHAM COUPLING)
01-71-01B HYDRAULIC PUMP (NEW TYPE) (SPLINE SHAFT)
01-71-02A STEERING PUMP (OLD TYPE) (W_RELIEF VALVE)
01-71-02B STEERING PUMP (NEW TYPE) (W_O RELIEF VALVE)
HYDRAULIC CONTROL (MC MODEL)
CONTROL VALVE (3 VALVES) (PART-1) (MC MODEL)
CONTROL VALVE (3 VALVES) (PART-2) (MC MODEL)
CONTROL VALVE (4 VALVES) (MC MODEL)
CONTROL VALVE (3 VALVES) (PART-1) (FC MODEL)
HYDRAULIC LINE (PART-1)
HYDRAULIC LINE (PART-2)
FLOW REGULATOR VALVE
ATTACHMENT VALVE PIPING
LIFT BRACKET COMMON PARTS
LIFT BRACKET
BACKREST
02-04-01A TILT CYLINDER (L.H.)(OLD TYPE) (6DEGREE-5DEGREE, 6DEGREE-7DEGREE, 6DEGREE-3DEGREE)
02-04-01B TILT CYLINDER (L.H.)(NEW TYPE) (6DEGREE-5DEGREE, 6DEGREE-7DEGREE, 6DEGREE-3DEGREE)
02-04-02A TILT CYLINDER (R.H.)(OLD TYPE) (6DEGREE-5DEGREE, 6DEGREE-7DEGREE, 6DEGREE-3DEGREE)
02-04-02B TILT CYLINDER (R.H.)(NEW TYPE) (6DEGREE-5DEGREE, 6DEGREE-7DEGREE, 6DEGREE-3DEGREE)
FORK (FOR 2G15A,2H15A,2J15A)
FORK (FOR 1G20A,1H20A,1J20A)
MAST COMMON PARTS (PART-1) (FOR SIMPLEX MAST)
MAST COMMON PARTS (PART-2) (FOR SIMPREX MAST)
MAST COMMON PARTS (PART-1) (FOR TRIPLEX MAST)
MAST COMMON PARTS (PART-2) (FOR TRIPLEX MAST)
MAST COMMON PARTS (PART-3) (FOR TRIPLEX MAST)
MAST COMMON PARTS (PART-4) (FOR TRIPLEX MAST)
MAST COMMON PARTS (PART-2) (FOR DUPLEX MAST)
MAST COMMON PARTS (PART-3) (FOR DUPLEX MAST)
DUPLEX MAST MODEL 2H15A 28-40,1H20A28-40
LIFT CYLINDER (1ST) (FOR 2H15A,1H20A)
02-18-01A LIFT CYLINDER (2ND) (OLD TYPE) (FOR 2H15A,1H20A)
02-18-01B LIFT CYLINDER (2ND) (NEW TYPE) (FOR 2H15A,1H20A)
LIFT CYLINDER (1ST) (FOR 2J15A,1J20A)
LIFT CYLINDER (2ND) (FOR 2J15A,1J20A)
LIFT CYLINDER (FOR 2G15A,1G20A)
TM1010 FIRE EXTINGUISHER (5 LB DRY) 9040105317
TM5190 SEAT RELOCATION GROUP 9040105533
TM5190 HEADGUARD GROUP, DRIVE-IN-RACK 9040105922
TM5190 HEADGUARD GROUP, DRIVE-IN-RACK 9040106679
TM5190 HEADGUARD GROUP, DRIVE-IN-RACK 9040113190
TIRE KIT (NONMARKING CUSHION)
TIRE KIT (FOR FB16KT,FB18KT)
TIRE KIT (FOR FB20KT)
TIRE KIT
FOOT DIRECTION CONTROL KIT
TM3320 INSTALLATION GROUP - 1 FUNCTION CASCADE MAST 9040105013
