Mitsubishi Forklift FB16CN2 Chassis Mast Options Internal Hosing Europe Parts Catalog DOC00050172
Brand: Mitsubishi
Type of Machine: Forklift
Region: Europe
Model: Mitsubishi FB16CN2 Chassis Mast Options Internal Hosing Europe
Part Number: DOC00050172
Number of Pages: 873 Pages
ACCESSORIES
SMART BACK-UP ALARM
BUZZER
STORAGE UNIT
HYDRAULIC ACCUMULATOR
TILT ANGLE SENSOR
ROAD LIGHT KIT
ROAD LIGHT
ACCESSORY RACK
EXTERNAL MIRRORS, WITHOUT DOOR
AMBER STROBE, UP POSITION
AMBER STROBE, DOWN POSITION
WARNING LIGHT, BLUE LIGHT (FRONT AND REAR)
WARNING LIGHT, BLUE LIGHT (FRONT)
WARNING LIGHT, BLUE LIGHT (REAR)
WARNING LIGHT, RED LIGHT (FRONT AND REAR)
WARNING LIGHT, RED LIGHT (FRONT)
WARNING LIGHT, RED LIGHT (REAR)
WARNING LIGHT, RED STRIPES
BACK-UP HANDLE
BACK-UP NARROW OHG
WASHER TANK, FRONT WINDOW
WASHER TANK, FRONT+REAR WINDOW
DRIVING SEAT, MSG65, W_ VINYL BACK REST
DRIVING SEAT, MSG65, W_ CLOTH BACK REST
DRIVING SEAT, MSG65, W_ LEFT ARM REST
BRACKET D-SERIES
SCANNER HOLDER
A4 CLIPBOARD
SUN VISOR
MIRROR, REAR VIEW
MIRROR, WIDE VIEW
MIRROR, WIDE VIEW ANGLE
HOOK ON SIDE SHIFTER
HOOK ON SIDE SHIFTER, SPARE PART KIT
USB POWER SUPPLY, 5V
ATTACHMENT SET, 3V
ATTACHMENT SET, 4V
SWIVEL SEAT ASSEMBLY
WIRE HARNESS, CABIN HEATER
WIRE HARNESS, SUPPLY CABLE
BATTERY RACK (SWE)
BATTERY CHANGING DEVICE (SWE)
COMPUTER RACK
DUST COVER, FRONT
LI-ION KIT
READING LIGHT
FAN
FAN & READING LIGHT
FAN (RL652480)
FAN (RL637676)
EL-PANEL ASSEMBLY
ADDITIONAL FAN
VOLTAGE CONVERTER, 1 DC POS. 1
VOLTAGE CONVERTER, 1 DC POS. 2
VOLTAGE CONVERTER, 2 DC
VOLTAGE CONVERTER, RELAY BRACKET
BATTERY CONNECTOR, STANDARD _ DIN
CONTACTOR PANEL, BRACKET
CABLE HARNESS
FORK ASSEMBLY
LOAD SUPPORT
LOAD SUPPORT, IFP
LOAD SUPPORT, DELETION
COUNTERWEIGHT ASSEMBLY
PIN, DRAWBAR ASSY
CHASSIS ASSEMBLY, CRANE
CHASSIS ASSEMBLY, SWE
SIDE PLATE, BASIC
SIDE PLATE, COMPACT
SIDE PLATE, LI-ION, BASIC
SIDE PLATE, LI-ION, COMPACT
HATCH, WO_ SWITCH
BATTERY DOOR, BASIC (CRANE)
BATTERY DOOR, COMPACT (CRANE)
BATTERY DOOR, BASIC (SWE)
BATTERY DOOR, COMPACT (SWE)
FLOOR ASSEMBLY, BASIC
FLOOR ASSEMBLY, OPP PEDAL
FLOOR ASSEMBLY, DUAL PEDAL
DUAL PEDAL
COVER, FRONT
COVER, BACK
COVER, RIGHT SIDE, WO_ PVC DOORS
COVER, RIGHT SIDE, W_ PVC DOORS
COVER, FELT
COVER, NARROW REAR LIGHT
FENDER, WIDE
DECALS
DECAL, LIFTING POINTS
SIDE DECALS
DECAL, BATTERY COVER
VEHICLE LIGHT
MAST LIGHTS
CABIN HEATER, RELAY & WIRING
STEERING UNIT, W_ FNR
STEERING UNIT, W_ FNR-LEVER NON-LOCKING
STEERING UNIT, W_ LIGHTS
STEERING UNIT, W_ FNR + LIGHTS
STEERING UNIT, W_ FNR-LEVER NON-LOCKING AND ROAD LIGHT
STEERING UNIT, WO_ FNR + LIGHTS
STEERING COLUMN
STEERING WHEEL
STEERING UNIT, MINISTEERING W_ LIGHTS
STEERING UNIT, MINISTEERING, WO_ FNR + LIGHTS
MINI STEERING COLUMN
MINI STEERING WHEEL
BATTERY COVER, MSG65-75 (FC)
BATTERY COVER, MSG20 (FC)
BATTERY COVER, MSG65-75 (MC)
BATTERY COVER, MSG20 (MC)
BATTERY COVER ASSEMBLY
BATTERY COVER WELDING ASSEMBLY
BATTERY COVER ASSEMBLY PARTS
BASE, MSG65-75 (FC)
BASE, MSG65-75 (MC)
BASE, MSG20 (FC)
BASE, MSG20 (MC)
SINGLE JOYSTICK ASSEMBLY
SINGLE JOYSTICK
SINGLE JOYSTICK, DECAL, HANDLE
SINGLE JOYSTICK, DECAL, TRIGGER
SINGLE JOYSTICK, DECAL, ROLLER
DUAL JOYSTICK ASSEMBLY, W_ FR
DUAL JOYSTICK, W_ FR
DUAL JOYSTICK ASSEMBLY, WO_ FR
DUAL JOYSTICK DECALS
DUAL JOYSTICK DECALS, Y AXIS RIGHT
DASHBOARD, STANDARD
DASHBOARD, LI-ION
DASHBOARD, ZAPI ECOSMART, STANDARD
DASHBOARD, ZAPI ECOSMART, LI-ION
DISPLAY UNIT, ZAPI ECOSMART
KNOB, LIFT
KNOB, TILT
KNOB, BLANCO
KNOB, SIDE SHIFT
KNOB, CLAMP
KNOB, SPREADER POSITIONER
KNOB, ROTATE
KNOB, EXTEND
LEVERS
SWITCHES
ARM REST (FC)
DRIVING SEAT, MSG20, VINYL, W_ SEAT BELT & SEAT BELT SWITCH
DRIVING SEAT, MSG65, VINYL, W_ FULL SUSPENSION & SEAT BELT SWITCH
DRIVING SEAT, MSG65, CLOTH, W_ FULL SUSPENSION & SEAT BELT SWITCH
DRIVING SEAT, MSG65, VINYL, W_ HEATER & SEAT BELT SWITCH
DRIVING SEAT, MSG65, CLOTH, W_ HEATER & SEAT BELT SWITCH
DRIVING SEAT, MSG75, VINYL, W_ AIR SUSPENSION & SEAT BELT SWITCH
DRIVING SEAT, MSG75, CLOTH, W_ AIR SUSPENSION & SEAT BELT SWITCH
DRIVING SEAT, MSG75, VINYL, W_ AIR SUSPENSION & HEATER & SEAT BELT SWITCH
DRIVING SEAT, MSG75, CLOTH, W_ AIR SUSPENSION & HEATER & SEAT BELT SWITCH
DRIVING SEAT, MSG75, VINYL, WO_ LEFT ARMREST (SPECIAL FOR LOW OHG)
DRIVING SEAT, MSG65, VINYL, W_ FULL SUSPENSION & SEAT BELT SWITCH & ORANGE SEAT BELT
DRIVING SEAT, MSG65, CLOTH, W_ FULL SUSPENSION & SEAT BELT SWITCH & ORANGE SEAT BELT
COVER, FOR MC LEVERS
AXLE, REAR, 4W
BATTERY POSITIONER (CRANE)
BATTERY POSITIONER (SWE)
BATTERY LOCKING (CRANE)
BATTERY LOCKING (SWE)
BATTERY ROLLER PALLET, 500Ah DIN A
BATTERY ROLLER PALLET, 625Ah DIN A
BATTERY ROLLER PALLET, 625Ah WIDE
BATTERY ROLLER PALLET, 750Ah WIDE
BATTERY ROLLER BED, WIDE
BATTERY ROLLER BED, DIN A
BATTERY ROLLER BED, COLD STORAGE
SENSOR, BATTERY LOCK ASSEMBLY
BASE, MSG65-75, FC, CE
BASE, MSG65-75, MC, CE
TILTING CYLINDER (5-3,5°)
TILTING CYLINDER (5-5°)
TILTING CYLINDER (5-6°)
TILTING CYLINDER (5-7,5°)
TILTING CYLINDER (RIGHT)
TILTING CYLINDER (LEFT)
HOSE ASSEMBLY, 3V
HOSE ASSEMBLY, 4V
HOSE ASSEMBLY, CLAMP RELEASE 3V (MC)
HOSE ASSEMBLY, CLAMP RELEASE 4V (MC)
VALVE BLOCK ASSEMBLY, 3V (FC)
VALVE BLOCK, 3V (FC)
VALVE BLOCK ASSEMBLY, 4V (FC)
VALVE BLOCK, 4V (FC)
VALVE BLOCK ASSEMBLY, 3V (MC)
VALVE BLOCK, 3V (MC)
VALVE BLOCK ASSEMBLY, 4V (MC)
VALVE BLOCK, 4V (MC)
VALVE ASSEMBLY 5V, 1.4-1.8T STANDARD SIMPLEX
VALVE ASSEMBLY 5V, 1.4-1.8T STANDARD DUPLEX
VALVE ASSEMBLY 5V, 1.4-1.8T STANDARD TRIPLEX
VALVE ASSEMBLY 5V, 2.0T STANDARD SIMPLEX
VALVE ASSEMBLY 5V, 2.0T STANDARD DUPLEX
VALVE ASSEMBLY 5V, 2.0T STANDARD TRIPLEX
VALVE ASSEMBLY 5V, IFP SIMPLEX
VALVE ASSEMBLY 5V, IFP DUPLEX
VALVE ASSEMBLY 5V, IFP TRIPLEX
VALVE ASSEMBLY 5V, ISS SIMPLEX
VALVE ASSEMBLY 5V, ISS DUPLEX
VALVE ASSEMBLY 5V, ISS TRIPLEX
VALVE BLOCK (RL630579)
VALVE BLOCK (RL630580)
VALVE BLOCK (RL630581)
VALVE BLOCK (RL630582)
VALVE, POPPET VALVE
FREELIFT PIPE, DUPLEX
FREE LIFT CYLINDER, DUPLEX & TRIPLEX (SERVICE KITS)
LIFTING CYLINDER, SIMPLEX & TRIPLEX (SERVICE KITS)
LIFTING CYLINDER, DUPLEX (REPAIR KITS)
OIL TANK
OIL TANK FILTER
GASKET KIT
OPERATOR COMPARTMENT, BASIC OHG
OPERATOR COMPARTMENT, PLEXI ROOF
OPERATOR COMPARTMENT, OHG ROOF, W_ WINDSCRN
OPERATOR COMPARTMENT, OHG ROOF, W_ WINDSCRN, WIPER, BATTERY HATCH
OPERATOR COMPARTMENT, OHG ROOF, W_ WINDSCRN, WIPER, BATTERY HATCH, REAR SCREEN, REAR WIPER
OPERATOR COMPARTMENT, OHG ROOF, W_ ... , STEEL DOORS
OPERATOR COMPARTMENT, OHG ROOF, W_ ... , PVC DOORS
OPERATOR COMPARTMENT, OHG ROOF, W_ ... , STEEL DOORS, HEATER
OPERATOR COMPARTMENT, OHG ROOF, W_ ... , STEEL DOORS, INTERIOR PACK
OPERATOR COMPARTMENT, OHG ROOF, W_ ... , PVC DOORS, INTERIOR PACK
OPERATOR COMPARTMENT, OHG ROOF, W_ ... , STEEL DOORS, HEATER, INTERIOR PACK
OPERATOR COMPARTMENT, OHG ROOF, W_ ... , INTERIOR PACK
OPERATOR COMPARTMENT, NARROW OHG
OHG, SUMMER DOORS
OHG, SUMMER DOORS - NEW
OHG, SUMMER DOORS, PLEXI ROOF
OHG, SUMMER DOORS, PLEXI ROOF, WINDSCRN
OHG, SUMMER DOORS, PLEXI ROOF, WINDSCRN, WIPER
OHG, SUMMER DOORS, PLEXI ROOF, WINDSCRN, WIPER, REAR SCRN
OHG, SUMMER DOORS, PLEXI ROOF, WINDSCRN, WIPER, REAR SCRN, INTERIOR PACK
WINDSCREEN, ROOF, INSTALLATION
WINDSCREEN, ROOF
WINDSCREEN, ROOF, INSTALLATION, W_ WINDSHIELD WIPER
WINDSCREEN, ROOF
WINDSHIELD WIPER, 197x748x503
WINDSHIELD WIPER, 97x750x168
HATCH, INSTALLATION
HATCH, ASSEMBLY
REAR WINDOW, INSTALLATION
REAR WINDOW, ASSEMBLY
ROOF WINDOW, INSTALLATION
ROOF WINDOW, ASSEMBLY
DOOR, LEFT, INSTALLATION
DOOR, LEFT, ASSEMBLY
DOOR, RIGHT, INSTALLATION
DOOR, RIGHT, ASSEMBLY
STOPPER
DOOR, RIGHT, W_ HEATER, INSTALLATION
DOOR, RIGHT, W_ HEATER, ASSEMBLY
DOOR, SUMMER DOOR, LEFT, INSTALLATION
DOOR, SUMMER DOOR, LEFT, ASSEMBLY
DOOR, 139x1485x1314, LEFT, INSTALLATION
DOOR, 142x1485x1314, LEFT, ASSEMBLY
DOOR, SUMMER DOOR, RIGHT, INSTALLATION
DOOR, SUMMER DOOR, RIGHT, ASSEMBLY
DOOR, 326x1414x1300, RIGHT, W_ HEATER, INSTALLATION
DOOR, 326x1415x1300, RIGHT, W_ HEATER, ASSEMBLY
MAST UNIT, SIMPLEX, 3V
MAST UNIT, SIMPLEX, 4V
MAST UNIT, SIMPLEX, 5V
INSTALLATION KIT, RIGHT FORK
INSTALLATION KIT, LEFT FORK
LIFT CHAIN, SIMPLEX (1.5T)
LIFT CHAIN, SIMPLEX (2.0T)
LIFT CHAIN, DUPLEX, TRIPLEX (1.5T)
LIFT CHAIN, DUPLEX, TRIPLEX (2.0T)
LIFT CHAIN, DUPLEX W_ FREE LIFT, TRIPLEX W_ FREE LIFT (1.5T)
LIFT CHAIN, DUPLEX W_ FREE LIFT, TRIPLEX W_ FREE LIFT (2.0T)
PERFORMANCE REDUCTION SENSOR, SIMPLEX
PERFORMANCE REDUCTION SENSOR, SIMPLEX (FOR LH_3.5M)
PERFORMANCE REDUCTION SENSOR, DUPLEX & TRIPLEX
PERFORMANCE REDUCTION SENSOR, DUPLEX & TRIPLEX (FOR LH_3.5M)
CHAIN YOKE ASSEMBLY
HOSE HOLDER, 3V
HOSE HOLDER, 4V
HOSE HOLDER, 5V
PULLEY, 5V FREE-LIFT PULLEY
PULLEY, 5V CABLE PULLEY
PULLEY, 5V SIDE CYLINDER
DRIVE UNIT, LEFT
DRIVE UNIT, RIGHT
DRIVING MOTOR
TRANSMISSION UNIT, LEFT
TRANSMISSION UNIT, RIGHT
PUMP MOTOR ASSEMBLY (1.4T & 1.6T)
PUMP MOTOR ASSEMBLY (1.8T & 2.0T)
SEAL KIT (FOR PUMP RL639237)
WHEEL SETS, 4W
WHEEL, SOLID ELASTIC, FRONT (1.4-1.8T)
WHEEL, SOLID ELASTIC, FRONT (2.0T)
WHEEL, SOLID ELASTIC, REAR
WHEEL, NON-MARKING, FRONT (1.4-1.8T)
WHEEL, NON-MARKING, FRONT (2.0T)
WHEEL, NON-MARKING, REAR
WHEEL, NON-MARKING, REAR_1
