Mitsubishi Engine S12A2 Service Manual 29302-00220
Brand: Mitsubishi
Model: Mitsubishi S12A2 Engine
Part Number: 29302-00220
Publication Date: 2017
Number of Pages: 365 Pages
Chapter 1 GENERAL
Brand: Mitsubishi
Chapter 1 GENERAL
1. External View
2. Outline of Systems
3. Indications of Plate and Label
4. Specifications
Chapter 2 SERVICE DATA1. Maintenance Service Data
2. Tightening Torque Table
Chapter 3 SERVICE TOOLS1. Special Tools
Chapter 4 OVERHAUL INSTRUCTIONS1. Determining Overhaul Timing
2. Compression Pressure - Measure
Chapter 5 DISASSEMBLY OF BASIC ENGINE1. Cylinder Head and Valve Mechanism - Disassemble and Inspect
2. Rear Mechanism - Disassemble and Inspect
3. Front Mechanism - Disassemble and Inspect
4. Cylinder Liner, Piston, and Connecting Rod - Disassemble and Inspect
5. Crankcase, Crankshaft, and Main Bearing - Disassemble and Inspect
Chapter 6 INSPECTION AND REPAIR OF BASIC ENGINE1. Cylinder Head and Valve Mechanism - Inspect and Repair
2. Rear Mechanism - Inspect and Repair
3. Front Mechanism - Inspect and Repair
4. Piston and Connecting Rod - Inspect and Repair
5. Crankcase and Crankshaft - Inspect and Repair
Chapter 7 ASSEMBLY OF BASIC ENGINE1. Crankshaft and Main Bearing - Install
2. Cylinder Liner, Piston, and Connecting Rod - Assemble
3. Front Mechanism - Assemble
4. Rear Mechanism - Assemble
5. Cylinder Head and Valve Mechanism - Assemble
Chapter 8 FUEL SYSTEM1. Fuel System - Remove and Inspect
2. Fuel System - Disassemble, Inspect, and Assemble
3. Fuel System - Install
Chapter 9 LUBRICATION SYSTEM1. Lubrication System - Remove and Inspect
2. Lubrication System - Disassemble, Inspect, and Assemble
3. Lubrication System - Install
Chapter 10 COOLING SYSTEM1. Cooling System - Remove and Inspect
2. Cooling System - Disassemble, Inspect, and Assemble
3. Cooling System - Install
Chapter 11 INLET AND EXHAUST SYSTEMS1. Inlet and Exhaust Systems - Remove and Inspect
2. Inlet and Exhaust Systems - Disassemble, Inspect, and Assemble
3. Inlet and Exhaust Systems - Install
Chapter 12 AIR START SYSTEM1. Air Start System - Remove and Inspect
2. Air Start System - Disassemble, Inspect and Assemble
3. Air Start System - Install
Chapter 13 ADJUSTMENT AND OPERATION1. Engine - Adjust
2. Break-In Operation
3. Engine - Test and Adjustment
Engine inspection record sheet
- Mitsubishi Tractor BD2F BD2G BD2J (bulldozer) Parts Catalogue
- Mitsubishi Diesel Engine K3B,K3D,K3E Parts List
- Mitsubishi Diesel Engine 4DR5 6DR5 Shop Manual
- Mitsubishi Diesel Engine L3A L3C L3E Parts Catalog EN JP
- MITSUBISHI DIESEL ENGINE KE75,K2B,K2C Parts List
- MITSUBISHI DIESEL ENGINE K4C,K4D Parts List
- Mitsubishi S4S, S6S Diesel Engine Service Manual
- MITSUBISHI DIESEL ENGINE S4S-61SD S4S-Y162SD S4S-Y262SD S4S-DT61SD S4S-Z263SD S4S-Z2DT62SD S4S-Y362
- Mitsubishi Diesel Engine L-Series L2A,L2C,L2E,L3A,L3C,L3E Service Manual
- Mitsubishi Engine K3M K4M Maintenance Manual
- MITSUBISHI TRACTOR BD2G BS3G WIRING DIAGRAM
- Mitsubishi Tractor MT210,MT210D,MT250,MT250D, Parts Catalogue
- Need Part Book Mitsubishi MG430 Motor Grader
- MITSUBISHI DIESEL ENGINE L2A L2C L2E - L3A L3C L3E SERVICE MANUAL
- Mitsubishi Tractor MT180D Parts Catalogue
