Martin Welker
104
230,310
Mitsubishi Diesel Engine S6A3 Service Manual 29402-00120
Brand: Mitsubishi
Type of Machine: Diesel Engine
Model: Mitsubishi S6A3 Diesel Engine
Publication Number: 29402-00120
Publication Date: 2017
Number of Pages: 355 Pages
COVER
Foreword
HOW TO USE THIS MANUAL
Safety Cautions
GENERAL CONTENTS
Chapter 1 GENERAL
1. External View
2. Outline of Systems
3. Indications of Plate and Label
4. Specifications
Chapter 2 SERVICE DATA
1. Maintenance Service Data
2. Tightening Torque Table
Chapter 3 SERVICE TOOLS
1. Special Tools
Chapter 4 OVERHAUL INSTRUCTIONS
1. Determining Overhaul Timing
2. Compression Pressure - Measure
Chapter 5 DISASSEMBLY OF BASIC ENGINE
1. Cylinder Head and Valve Mechanism - Disassemble and Inspect
2. Rear Mechanism - Disassemble and Inspect
3. Front Mechanism - Disassemble and Inspect
4. Cylinder Liner, Piston, and Connecting Rod - Disassemble and Inspect
5. Crankcase, Crankshaft, and Main Bearing - Disassemble and Inspect
Chapter 6 INSPECTION AND REPAIR OF BASIC ENGINE
1. Cylinder Head and Valve Mechanism - Inspect and Repair
2. Rear Mechanism - Inspect and Repair
3. Front Mechanism - Inspect and Repair
4. Piston and Connecting Rod - Inspect and Repair
5. Crankcase and Crankshaft - Inspect and Repair
Chapter 7 ASSEMBLY OF BASIC ENGINE
1. Crankshaft and Main Bearing - Install
2. Cylinder Liner, Piston, and Connecting Rod - Assemble
3. Front Mechanism - Assemble
4. Rear Mechanism - Assemble
5. Cylinder Head and Valve Mechanism - Assemble
Chapter 8 FUEL SYSTEM
1. Fuel System - Remove and Inspect
2. Fuel System - Disassemble, Inspect, and Assemble
3. Fuel System - Install
Chapter 9 LUBRICATION SYSTEM
1. Lubrication System - Remove and Inspect
2. Lubrication System - Disassemble, Inspect, and Assemble
3. Lubrication System - Install
Chapter 10 COOLING SYSTEM
1. Cooling System - Remove and Inspect
2. Cooling System - Disassemble, Inspect, and Assemble
3. Cooling System - Install
Chapter 11 INLET AND EXHAUST SYSTEMS
1. Inlet and Exhaust Systems - Remove and Inspect
2. Inlet and Exhaust Systems - Disassemble, Inspect, and Assemble
3. Inlet and Exhaust Systems - Install
Chapter 12 AIR START SYSTEM
1. Air Start System - Remove and Inspect
2. Air Start System - Disassemble, Inspect and Assemble
3. Air Start System - Install
Chapter 13 ADJUSTMENT AND OPERATION
1. Engine - Adjust
2. Break-In Operation
3. Engine - Test and Adjustment
Engine inspection record sheet
REAR COVER
BACK COVER
