Mitsubishi Diesel Engine S16R Series Kohler D1600 D1820 D2000 Service Parts Manual TP-6259
Brand: Mitsubishi
Type of Machine: Diesel Engine
Type of Manual: Service Parts Manual
Model: Mitsubishi S16R-Y1PTA, S16R-Y2PTAW/2, S16R-Y1PTAA2
Kohler D1600, D1820, D2000
Publication Number: TP-6259
Number of Pages: 120 Pages
Introduction
Number System Significance
Illustrations
How to Find Part Numbers
Hardware References
Specification Number Index
Group 1: Cylinder Head
Group 4: Valve Mechanism and Rocker Cover
Group 5: Camshaft
Group 7.1: Crankcase Assembly
Group 7.2: Crankcase Bearings
Group 7.3: Crankcase Covers
Group 11: Timing Gear Case
Group 13: Oil Pan
Group 14: Engine Mounting
Group 17: Piston and Connecting Rod
Group 20: Crankshaft, Flywheel, and Damper
Group 23: Timing Gear
Group 25.1: Accessory Drive, Front
Group 25.2: Accessory Drive, Rear
Group 25.3: Hourmeter Cover
Group 30.1: Intake Tubes
Group 30.2: Air Box
Group 32.1: Exhaust System
Group 32.2: Exhaust Elbow
Group 32.3: Exhaust Cover
Group 33.1: Turbocharger Mounting
Group 33.2: Turbocharger
Group 35: Oil Pump
Group 36.1: Oil Strainer
Group 36.2: Oil Thermostat
Group 36.3: Oil Pipes
Group 39: Oil Cooler
Group 40.1: Oil Filter
Group 40.2: Oil Filter Assembly
Group 40.3: Bypass Filter Piping
Group 42: Oil Filler and Dipstick
Group 43: Breather
Group 45: Water Pump
Group 46.1: Thermostat and Covers
Group 46.2: Cooling System
Group 47.1: Radiator
Group 47.2: Radiator Piping
Group 48: Fan Drive
Group 51.1: Intercooler Thermostat
Group 51.2: Intercooler Outer Piping
Group 51.3: Intercooler Inner Piping
Group 53: Intercooler Water Pump
Group 55: Air Cooler
Group 61.1: Fuel Injection Pump
Group 61.2: Fuel Rack Control
Group 61.3: Nozzle Assembly
Group 61.4: Fuel Injection Lines
Group 61.5: Fuel Leakoff Pipes
Group 61.6: Injection Pump, Right
Group 61.7: Injection Pump, Left
Group 61.8: Fuel Feed Pump
Group 62.1: Fuel Filter Piping
Group 62.2: Fuel Filter
Group 63.1: Governor Control
Group 63.2: Boost Sensor
Group 66: Starter
Group 68.1: Alternator Mounting
Group 68.2: Alternator
Group 71: Turning Gear
Group 87: Stop System
Group 94.1: Overhaul Gasket Kit
Group 94.2: Overhaul Gasket Kit
Group 94.3: Oil Seal Kit 118
Brand: Mitsubishi
Introduction
Illustrations
Hardware References
Group 5: Camshaft
Group 13: Oil Pan
Group 30.2: Air Box
Group 35: Oil Pump
Group 43: Breather
Group 48: Fan Drive
Group 66: Starter
- Mitsubishi Tractor BD2F BD2G BD2J (bulldozer) Parts Catalogue
- Mitsubishi Diesel Engine K3B,K3D,K3E Parts List
- Mitsubishi Diesel Engine 4DR5 6DR5 Shop Manual
- Mitsubishi Diesel Engine L3A L3C L3E Parts Catalog EN JP
- MITSUBISHI DIESEL ENGINE KE75,K2B,K2C Parts List
- MITSUBISHI DIESEL ENGINE K4C,K4D Parts List
- Mitsubishi S4S, S6S Diesel Engine Service Manual
- MITSUBISHI DIESEL ENGINE S4S-61SD S4S-Y162SD S4S-Y262SD S4S-DT61SD S4S-Z263SD S4S-Z2DT62SD S4S-Y362
- Mitsubishi Diesel Engine L-Series L2A,L2C,L2E,L3A,L3C,L3E Service Manual
- Mitsubishi Engine K3M K4M Maintenance Manual
- MITSUBISHI TRACTOR BD2G BS3G WIRING DIAGRAM
- Mitsubishi Tractor MT210,MT210D,MT250,MT250D, Parts Catalogue
- Need Part Book Mitsubishi MG430 Motor Grader
- MITSUBISHI DIESEL ENGINE L2A L2C L2E - L3A L3C L3E SERVICE MANUAL
- Mitsubishi Tractor MT180D Parts Catalogue
