Mitsubishi Diesel Engine S12R Series Parts Catalog 98240-31970 EN JP
Language: English, Japanese
Brand: Mitsubishi
Type of Machine: Diesel Engine
Model: Mitsubishi S12R-PTA S12R-PTK S12R-MPTA S12R-MPTK Diesel Engine
Engine Number: 10001 and up
Publication Number: 98240-31970
Publication Date: 1999
Number of Pages: 373 Pages
GUIDE FOR USE OF PARTS CATALOGUE
SAMPLE OF PARTS CATALOGUE
TABLE OF SYMBOLS & ABBREVIATIONS
TABLE OF MAKER'S NAME
LIST OF SPECIFICATION CODES
CONTENTS
ENGINE BODY
01 CYLINDER HEAD
04 VALVE MECHANISM & ROCKER COVER
05 CAMSHAFT
07-01 CRANKCASE ASSY
07-02 CRANKCASE (PART-1)
07-03 CRANKCASE (PART-2)
11 TIMING GEAR CASE
13 OIL PAN
14 ENGINE MOUNTING
17 PISTON & CONNECTING-ROD
20 CRANKSHAFT, FLYWHEEL & DAMPER
23 TIMING GEAR
25-01 ACCESSORY DRIVE (FRONT)
25-02 ACCESSORY DRIVE (REAR)
INLET & EXHAUST SYSTEM
30-01 INLET SYSTEM
30-02 AIR HEATER
32-01 EXHAUST SYSTEM (PART-1)
32-02 EXHAUST SYSTEM (PART-2)
32-03 EXHAUSTCOVER
33-01 TURBOCHARGER GENERAL
33-02 TURBOCHARGER (MODEL TD15-60B-59)
33-03 TURBOCHARGER (MODEL TD15-55B-49)
33-04 TURBOCHARGER (MODEL TD13L-47F-47)
33-05 TURBOCHARGER (MODEL TD13L-45QV55)
OIL SYSTEM
35 OIL PUMP
36-01 OIL STRAINER
36-02 OIL PIPE (PART-1)
36-03 OIL PIPE (PART-2)
39 OIL COOLER
40-01-A OIL FILTER (UP TO @E/# 10025)
40-01-B OIL FILTER (FROM E/# 10026@)
40-02 OIL FILTER ASSY (SWITCHOVER /PAPER-ELEMENT TYPE)
42 OIL FILLER & LEVEL GAGE
43 BREATHER
COOLING SYSTEM
45 WATER PUMP
46-01 COOLING SYSTEM (PART-1)
46-02 COOLING SYSTEM (PART-2)
48 FAN DRIVE
55 AIR COOLER
FUEL SYSTEM
61-01 FUEL INJECTION PUMP GENERAL
61-02-A FUEL SYSTEM (PART-1) (UP TO @E/# 10543)
61-02-B FUEL SYSTEM (PART-1) (FROM E/# 10544@)
61-03 FUEL SYSTEM (PART-2)
61-04-A NOZZLE ASSY (SPRAY HOLE DIAMETER: 0.35MM)
61-04-B NOZZLE ASSY (SPRAY HOLE DIAMETER: 0.33MM)
61-04-C NOZZLE ASSY (SPRAY HOLE DIAMETER:0.31MM)
61-05 FUEL RACK CONTROL
61-06-A INJECTION PUMP R.H (UP TO @E/# 10543)
61-06-B INJECTION PUMP R.H (FROM E/# 10544@)
61-07-A INJECTION PUMP L.H (UP TO @E/# 10543)
61-07-B INJECTION PUMP L.H (FROM E/# 10544@)
61-08 FEED PUMP
61-09-A INJECTION PUMP R.H (MARINE USE) (UP TO @E/# 10543)
61-09-B INJECTION PUMP R.H (MARINE USE) (FROM E/# 10544@)
61-10-A INJECTION PUMP L.H (MARINE USE) (UP TO @E/# 10543)
61-10-B INJECTION PUMP L.H (MARINE USE) (FROM E/# 10544@)
62-01 FUEL FILTER PIPING
62-02 FUEL FILTER (DIESEL FUEL & DOMESTIC FURNACE OIL)
62-03 FUEL FILTER (SWITCHOVER TYPE)
63-01 GOVERNOR DRIVE
63-02 GOVERNOR OIL PIPE
63-03 GOVERNOR CONTROL (PART-1)
63-04 GOVERNOR CONTROL (PART-2)
63-05 GOVERNOR ASSY (MODEL PSG)
63-06 GOVERNOR ASSY (MODEL EG-3P)
STARTING SYSTEM
66-01-A STARTER (24V-7.5KW)
66-01-B STARTER (24V-7.5KW) (MARINE USE)
66-02 AIR STARTER
68-01 ALTERNATOR GENERAL
68-02-A ALTERNATOR (24V-30A) (UP TO @E/# 10293)
68-02-B ALTERNATOR (24V-30A) (FROM E/# 10294@)
68-03-A ALTERNATOR (24V-30A W/JG) (UP TO @E/# 10281)
68-03-B ALTERNATOR (24V-30A W/JG) (FROM E/# 10282@)
71 TURNING GEAR
74-01 AIR START SYSTEM (PART-1)
74-02 AIR START SYSTEM (PART-2)
74-03 AIR START PIPING
AIR COMPRESSOR
75-01 AIR COMPRESSOR
75-02 AIR COMPRESSOR ASSY
STOP SYSTEM
87 STOP SYSTEM
TOOL
91-01 TOOLS (STD)
91-02 TOOLS (SPECIAL)
ACCESSORY
92 ACCESSORY
REPAIR PARTS
94-01 OVERHAUL GASKET KIT (PART-1)
94-02 OVERHAUL GASKET KIT (PART-2)
94-03 OIL SEAL KIT
NUMERICAL PARTS INDEX
TABLE OF BOLT, W/WASHER
TABLE OF COMBINATION FOR REPLACEABILlTY-"G"-
Brand: Mitsubishi
CONTENTS
ENGINE BODY
01 CYLINDER HEAD
05 CAMSHAFT
11 TIMING GEAR CASE
13 OIL PAN
14 ENGINE MOUNTING
23 TIMING GEAR
30-01 INLET SYSTEM
30-02 AIR HEATER
32-03 EXHAUSTCOVER
OIL SYSTEM
35 OIL PUMP
36-01 OIL STRAINER
39 OIL COOLER
43 BREATHER
COOLING SYSTEM
45 WATER PUMP
48 FAN DRIVE
55 AIR COOLER
FUEL SYSTEM
61-08 FEED PUMP
STARTING SYSTEM
66-02 AIR STARTER
71 TURNING GEAR
AIR COMPRESSOR
STOP SYSTEM
87 STOP SYSTEM
TOOL
91-01 TOOLS (STD)
ACCESSORY
92 ACCESSORY
REPAIR PARTS
94-03 OIL SEAL KIT
- Mitsubishi Tractor BD2F BD2G BD2J (bulldozer) Parts Catalogue
- Mitsubishi Diesel Engine K3B,K3D,K3E Parts List
- Mitsubishi Diesel Engine 4DR5 6DR5 Shop Manual
- Mitsubishi Diesel Engine L3A L3C L3E Parts Catalog EN JP
- MITSUBISHI DIESEL ENGINE KE75,K2B,K2C Parts List
- MITSUBISHI DIESEL ENGINE K4C,K4D Parts List
- Mitsubishi S4S, S6S Diesel Engine Service Manual
- MITSUBISHI DIESEL ENGINE S4S-61SD S4S-Y162SD S4S-Y262SD S4S-DT61SD S4S-Z263SD S4S-Z2DT62SD S4S-Y362
- Mitsubishi Diesel Engine L-Series L2A,L2C,L2E,L3A,L3C,L3E Service Manual
- Mitsubishi Engine K3M K4M Maintenance Manual
- MITSUBISHI TRACTOR BD2G BS3G WIRING DIAGRAM
- Mitsubishi Tractor MT210,MT210D,MT250,MT250D, Parts Catalogue
- Need Part Book Mitsubishi MG430 Motor Grader
- MITSUBISHI DIESEL ENGINE L2A L2C L2E - L3A L3C L3E SERVICE MANUAL
- Mitsubishi Tractor MT180D Parts Catalogue
