Hyundai
86
176,684
Mecalac Backhoe Loader TLB890 TIER 4 Parts Catalog 1310-0
Language: English, French, German, Spanish
Brand: Mecalac
Model: Mecalac TLB890 TIER 4 Backhoe Loader
Reference Number: 1310-0
Pulication Date: 2018
Number of Pages: 1608 Pages
Chassis - Centremount 2 Wheel Steer - Short
Chassis - Centremount 2 Wheel Steer - Long
Chassis - Sideshift 2 Wheel Steer - Short
Chassis - Sideshift 2 Wheel Steer - Long
Bonnet - White
Bonnet - Yellow
Wheels & Tyres - Mitas - 20F 30R - White
Wheels & Tyres - Mitas - 20F 30R - Yellow
Wheels & Tyres - Mitas - 18F 24R - White
Wheels & Tyres - Mitas - 18F 24R - Yellow
Wheels & Tyres - Mitas - 20F 26R - White
Wheels & Tyres - Mitas - 20F 26R - Yellow
Front Axle - Short Drop - 16.5:1
Front Axle - Short Drop - 16.5:1 - Axle Housing
Front Axle - Short Drop - 16.5:1 - Swivel Housing & Steering Cylinder
Front Axle - Short Drop - 16.5:1 - Bevel Gear Set
Front Axle - Short Drop - 16.5:1 - Differential
Front Axle - Short Drop - 16.5:1 - Double Universal Joint
Front Axle - Short Drop - 16.5:1 - Wheel Hub
Front Axle - Short Drop - 16.5:1 - Final Reduction
Steering System - Gear Pump
Steering System - Gear Pump - Hoses
Steering System - Piston Pump
Steering System - Piston Pump - Hoses
Hard Nose - White
Hard Nose - Yellow
Engine - 100HP
Fuel System - Fuel Tank
Fuel System - Fuel Pipes
Exhaust System
Induction Air Cleaner
Cooling System - Radiator Assembly
Cooling System - Charge Air Tubes
Torque Converter
Driveline Bolting
Transmission - Synchro - Mechanical Parking Brake
Transmission - Oil Pump
Transmission - Oil Filters
Transmission - Housing
Transmission - Input & PTO Shafts
Transmission - Reverse & Primary Shafts
Transmission - Secondary Shaft
Transmission - 4WD Shaft
Transmission - Brake
Transmission - Speeed Control
Transmission - Control Valve
Transmission - Solenoid Valve
Transmission - Servo Power Synchro - Mechnical Parking Brake
Transmission - Servo Power Synchro - Mechnical Parking Brake - Oil Pump
Transmission - Servo Power Synchro - Mechnical Parking Brake - Oil Filters
Transmission - Servo Power Synchro - Mechnical Parking Brake - Housing
Transmission - Servo Power Synchro - Mechnical Parking Brake - Input & PTO Shafts
Transmission - Servo Power Synchro - Mechnical Parking Brake - Reverse & Primary Shafts
Transmission - Servo Power Synchro - Mechnical Parking Brake - Secondary Shaft
Transmission - Servo Power Synchro - Mechnical Parking Brake - 4WD Shaft
Transmission - Servo Power Synchro - Mechnical Parking Brake - Brake
Transmission - Servo Power Synchro - Mechnical Parking Brake - Speed Control
Transmission - Servo Power Synchro - Mechnical Parking Brake - Control Valve
Consumables - White Paint
Consumables - Yellow Paint
Consumables - Sundries - Synchro - Cab - with Air Con
Consumables - Sundries - Synchro - Cab - without Air Con
Consumables - Sundries - Synchro - Canopy - without Air Con
Consumables - Sundries - Powershift Servo Synchro - Cab - with Air Con
Consumables - Sundries - Powershift Servo Synchro - Cab - without Air Con
Consumables - Sundries - Powershift Servo Synchro - Canopy - without Air Con
Gearshift - Synchro - 2 Wheel Steer - 4 Speed
Gearshift - Synchro - 2 Wheel Steer - 3 Speed
Gearshift - Servo Power Synchro - 2 Wheel Steer - 4 Speed
Gearshift - Servo Power Synchro - 2 Wheel Steer - 3 Speed
Rear Axle
Rear Axle - Axle Housing
Rear Axle - Bevel Gear Set
Rear Axle - Differential
Rear Axle - Differential Locking
Rear Axle - Brakes
Rear Axle - Wheel Hub & Final Reduction
Digger Valve - Sideshift - Mechanical - Standard Dipper - without Quick Attach
Digger Valve - Sideshift - Mechanical - Standard Dipper - with Quick Attach
Digger Valve - Sideshift - Mechanical - Extending Dipper - without Quick Attach
Digger Valve - Sideshift - Mechanical - Extending Dipper - with Quick Attach
Digger Valve - Sideshift - Servo - Standard Dipper - without Quick Attach
Digger Valve - Sideshift - Servo - Standard Dipper - with Quick Attach
Digger Valve - Centremount - Servo - Standard Dipper - without Quick Attach
Digger Valve - Centremount - Servo - Standard Dipper - with Quick Attach
Digger Valve - Sideshift - without Digger - Mechanical
Digger Valve - without Digger - Servo
Digger Valve - Sideshift - Servo - Extending Dipper - without Quick Attach
Digger Valve - Sideshift - Servo - Extending Dipper - with Quick Attach
Digger Valve - Centremount - Mechanical - Standard Dipper - without Quick Attach
Digger Valve - Centremount - Mechanical - Standard Dipper - with Quick Attach
Digger Valve - Centremount - Mechanical - Extending Dipper - without Quick Attach
Digger Valve - Centremount - Mechanical - Extending Dipper - with Quick Attach
Digger Valve - Centremount - Servo - Extending Dipper - without Quick Attach
Digger Valve - Centremount - Servo - Extending Dipper - with Quick Attach
Digger Valve - Sideshift - Servo - Without Dipper
Torque Converter Hydrauclics - Synchro Shuttle
Torque Converter Hydrauclics - Powershift Servo Synchro
Torque Converter Hydrauclics - Tank
Main Hydraulics - Piston Pump & Filter
Main Hydraulics - Gear Pump & Filter
Main Hydraulics - Piston Pump - Closed Centre (2WS)
Main Hydraulics - Piston Pump - Closed Centre (4WS)
Throttle Controls
Service Brakes - 2 Wheel Steer
Handbrake - Overcentre
Cab - Glazed Structure - Mounts
Cab - Door Assemblies
Cab - Side Windows
Cab - Rear Window
Cab - Front Windows
Cab - Structure
Cab - Roof Liner
Cab - Wipers
Cab - Electrics
Cab - without windscreen - Structure - Mounts
Canopy - without windscreen - Electrics
Canopy - with windscreen - Structure - Mounts
Canopy - with windscreen - Front Windows
Canopy - with windscreen - Electrics
Cab - Front Window
Cab - Headliner
Cab - Structure - Plastic Roof
Cab Trim - Front Console
Cab Trim - Side Console - Right Hand
Cab Trim - Side Console - Left Hand
Cab Trim - Floor Plate Seals
Canopy Trim - Front Console
Canopy Trim - Side Console - Right Hand
Canopy Trim - Side Console - Left Hand
Floormat - Cab - Mechnical Controls
Floormat - Cab - Servo Controls
Floormat - Canopy - Anti-slip
Heater - Cab - without Air Con
Heater - Cab - without Air Con - Air Ducts
Heater - Cab - with Air Con
Heater - Cab - with Air Con - Air Ducts
Heater - Cab - with Air Con - Compressor
Heater - Cab - Climate Control
Heater - Cab - Climate Control - Air Ducts
Heater - Cab - Climate Control - Compressor
Heater - Canopy - None
Electrics - Cab - Main Harness
Electrics - Canopy - Main Harness
Front Console - without Speedometer
Front Console - with Speedometer
Front Console - with Speedometer Synchro
Front Console - without Speedometer - Canopy
Front Console - with Speedometer Servo Power Shuttle - Canopy
Front Console - with Speedometer Synchro - Canopy
Side Console - Centremount - Cab
Side Console - Sideshift - Cab
Side Console - Sideshift - Canopy
Side Console - Centremount - Canopy
Battery - Single
Battery - Dual
Rear Lights - Sideshift - 4 Work Lights
Rear Lights - Centremount - 4 Work Lights - Low Level
Rear Lights - Centremount - 4 Work Lights - High Level
Headlights - Left Hand Dip
Headlights - Right Hand Dip
Mirror - Standard
Seat - PVC - Mechanical Suspension
Seat - Fabric - Mechanical Suspension
Seat - Fabric - Air Suspension - with Heater
Front Fenders
Ride Control - None
Ride Control - ISO
Ride Control - ANSI
Loader Beam - White
Loader Beam - Links - White
Loader Beam - Return to Dig - White
Loader Beam - Yellow
Loader Beam - Links - Yellow
Loader Beam - Return to Dig - Yellow
Loader Beam - None
Loader Bucket - 1.0 cu M. Standard for Forks
Loader Bucket - 1.2 cu M. Standard for Forks
Loader Bucket - 1.0 cu M. MP 7in1 for Forks
Loader Bucket - 1.0 cu M. MP 7in1 for Forks - Pipework
Loader Bucket - 1.0 cu M. MP 7in1 for Forks - Cylinder
Loader Bucket - 1.2 cu M. MP 7in1 for Forks
Loader Bucket - 1.2 cu M. MP 7in1 for Forks - Pipework
Loader Bucket - 1.2 cu M. MP 7in1 for Forks - Cylinder
Loader Bucket - Less Bucket
Loader Hydraulics - without Hose Burst - Standard Bucket - Bucket Cylinder
Loader Hydraulics - without Hose Burst - Standard Bucket - Lift Cylinder
Loader Hydraulics - with Hose Burst - Standard Bucket - Bucket Cylinder
Loader Hydraulics - with Hose Burst - Standard Bucket - Lift Cylinder
Loader Hydraulics - without Hose Burst - MP 7in1 Bucket - Bucket Cylinder
Loader Hydraulics - without Hose Burst - MP 7in1 Bucket - Lift Cylinder
Loader Hydraulics - with Hose Burst - MP 7in1 Bucket - Bucket Cylinder
Loader Hydraulics - with Hose Burst - MP 7in1 Bucket - Lift Cylinder
Loader Hydraulics - without Hose Burst - without MP 7in1 Bucket - Bucket Cylinder
Loader Hydraulics - without Hose Burst - without MP 7in1 Bucket - Lift Cylinder
Loader Hydraulics - with Hose Burst - without MP 7in1 Bucket - Bucket Cylinder
Loader Hydraulics - with Hose Burst - without MP 7in1 Bucket - Lift Cylinder
Loader Controls - Electro - Hydraulic Clam
Loader Controls - Electro - Hydraulic Clam - with Lock
Loader Controls
Transport Lock - 15ft
Stabilisers - Centremount - White
Stabilisers - Centremount - Yellow
Stabilisers - None
Swing System - Centremount - 15ft
Swing System - Sideshift - 15ft
Swing System - None
Boom - Standard - 15ft - White
Boom - Standard - 15ft - Yellow
Boom - None
Dipper - Standard - 15ft - White
Dipper - Standard - 15ft - Yellow
Dipper - Extending - 15ft - White
Dipper - Outer - 15ft - White
Dipper - Inner - 15ft - White
Dipper - Extending - 15ft - Yellow
Dipper - Outer - 15ft - Yellow
Dipper - Inner - 15ft - Yellow
Dipper - None - 15ft
Digger Bucket Linkage - 15ft
Digger Bucket Linkage - None
Digger Bucket - Standard - 300mm
Digger Bucket - Standard - 450mm
Digger Bucket - Standard - 600mm......................................................................................................................
Digger Bucket - Standard - 750mm......................................................................................................................
Digger Bucket - Standard - 900mm......................................................................................................................
Digger Bucket - Heavy Duty - 300mm..................................................................................................................
Digger Bucket - Heavy Duty - 450mm..................................................................................................................
Digger Bucket - Heavy Duty - 600mm
Digger Bucket - Heavy Duty - 750mm
Digger Bucket - Heavy Duty - 900mm
Digger Bucket - Heavy Duty - 12 inch
Digger Bucket - Heavy Duty - 18 inch
Digger Bucket - Heavy Duty - 24 inch
Digger Bucket - Heavy Duty - 30 inch
Digger Bucket - Heavy Duty - 36 inch
Digger Bucket - Ditch - 1500mm
Digger Bucket - Ditch - 1800mm
Digger Bucket - Trapezoidal
Digger Bucket - None
Digger Bucket - None with Slave Link
Digger Hydraulics - None
Digger Hydraulics - Centremount - Standard Dipper - without Hose Burst - 15ft
Digger Hydraulics - Centremount - Extending Dipper - without Hose Burst - 15ft
Digger Hydraulics - Centremount - Standard Dipper - with Hose Burst - 15ft
Digger Hydraulics - Centremount - Extending Dipper - with Hose Burst - 15ft
Digger Hydraulics - Sideshift - Standard Dipper - 15ft - without Hose Burst
Digger Hydraulics - Sideshift - Extending Dipper - 15ft - without Hose Burst
Digger Hydraulics - Sideshift - Standard Dipper - 15ft - with Hose Burst
Digger Hydraulics - Sideshift - Extending Dipper - 15ft - with Hose Burst
Digger Controls - ISO or SAE
Digger Controls - X Pattern
Digger Controls - SAE
Digger Controls - Servo
Stab Controls - Sideshift
Stab Controls - Centremount
Pedal Box - Extending Dipper - Mechanical - without Auxilliary Hydraulics
Pedal Box - Extending Dipper - Mechanical - with Auxilliary Hydraulics
Pedal Box - Standard Dipper - Mechanical - with Auxilliary Hydraulics
Pedal Box - Standard Dipper - Mechanical - without Auxilliary Hydraulics
Pedal Box - Standard Dipper - Servo - without Auxilliary Hydraulics
Loader Valve - Mechanical Controls
Loader Valve - Servo Controls
Rear Fenders - 2 Wheel Steer - Sideshift
Rear Fenders - 2 Wheel Steer - Centremount
Stabiliser Hydraulics - Centremount - with Lock Out
Stabiliser Hydraulics - Sideshift - without Lock Out
Stabiliser Hydraulics - Sideshift - with Lock Out
Extender Hydraulics - Centremount
Extender Hydraulics - Sideshift
Extender Hydraulics - None - Servo
Auxilliary Hydraulics - None
Auxilliary Hydraulics - Centremount - Extending Dipper - 15ft
Auxilliary Hydraulics - Sideshift - Extending Dipper - 15ft
Auxilliary Hydraulics - Centremount - Standard Dipper - 15ft
Auxilliary Hydraulics - Sideshift - Standard Dipper - 15ft
Transport Lock Hydraulics - Centremount
Transport Lock Hydraulics - Sideshift
Transport Lock Hydraulics - None
Swing Hydraulics - Centremount
Swing Hydraulics - Sideshift
Swing Hydraulics - None
Tool Kit - Standard
Digger Quick Attach - Mechanical
Digger Quick Attach - Hydraulic
Digger Quick Attach - Hydraulics Only - No Unit
Digger Quick Attach - None
Digger Quick Attach Hydraulics - Centremount - Standard Dipper
Digger Quick Attach Hydraulics - Centremount - Extending Dipper
Digger Quick Attach Hydraulics - Sideshift - Standard Dipper
Digger Quick Attach Hydraulics - Sideshift - Extending Dipper
Machine Identity Decals - TLB890
Decals - Cab - English - ISO - CE - Instructions
Decals - Cab - English - ISO - CE - Warning
Decals - Cab - English - ISO - CE - Miscellaneous
Decals - Cab - French - ISO - CE - Instructions
Decals - Cab - French - ISO - CE - Warning
Decals - Cab - French - ISO - CE - Miscellaneous
Decals - Cab - German - ISO - CE - Instructions
Decals - Cab - German - ISO - CE - Warning
Decals - Cab - German - ISO - CE - Miscellaneous
Decals - Cab - Italian - ISO - CE - Instructions
Decals - Cab - Italian - ISO - CE - Warning
Decals - Cab - Italian - ISO - CE - Miscellaneous
Decals - Cab - Austrian - ISO - CE - Instructions
Decals - Cab - Austrian - ISO - CE - Warning
Decals - Cab - Austrian - ISO - CE - Miscellaneous
Decals - Cab - English - ISO - Non CE - Instructions
Decals - Cab - English - ISO - Non CE - Warning
Decals - Cab - English - ISO - Non CE - Miscellaneous
Decals - Cab - Costa Rica - ISO - Non CE - Instructions
Decals - Cab - Costa Rica - ISO - Non CE - Warning
Decals - Cab - Costa Rica - ISO - Non CE - Miscellaneous
Decals - Canopy - English - ISO - CE - Instructions
Decals - Canopy - English - ISO - CE - Warning
Decals - Canopy - English - ISO - CE - Miscellaneous
Decals - Canopy - English - ISO - Non CE - Instructions
Decals - Canopy - English - ISO - Non CE - Warning
Decals - Canopy - English - ISO - Non CE - Miscellaneous
Decals - Canopy - Costa Rica - ISO - Non CE - Instructions
Decals - Canopy - Costa Rica - ISO - Non CE - Warning
Decals - Canopy - Costa Rica - ISO - Non CE - Miscellaneous
Decals - Cab - English - ANSI - Non CE - Instructions
Decals - Cab - English - ANSI - Non CE - Warning
Decals - Cab - English - ANSI - Non CE - Miscellaneous
Decals - Canopy - English - ANSI - Non CE - Instructions
Decals - Canopy - English - ANSI - Non CE - Warning
Decals - Canopy - English - ANSI - Non CE - Miscellaneous
Forks - 1.0 Cubic Metre Loader Bucket
Forks - 1.2 Cubic Metre Loader Bucket
Loader Quick Attach - None
Tooth Guard - Multi-Purpose Bucket - Wide
Tooth Guard - Multi-Purpose Bucket - Narrow
Tooth Guard - Standard Bucket - Narrow
Tooth Guard - Standard Bucket - Wide
Licence Plate Holder - Rear
Wheel Wedge
Transport Chain - Digger
Transport Chain - Loader
Transport Side Plate - Loader Bucket
Fan Guard - Without Air Con
Fan Guard - With Air Con
Seat Belt - 3 inch
Transport Height Decal
Stabiliser Leg Lock Up - Sideshift
Reverse Alarm
Stabiliser Leg Warning - Centremount
Literature Pack - Arabic
Literature Pack - Bulgarian
Literature Pack - Croation
Literature Pack - Czech
Literature Pack - Danish
Literature Pack - English
Literature Pack - Estonian
Literature Pack - Finnish
Literature Pack - Flemish / Dutch
Literature Pack - Flemish / Dutch (Non EU)
Literature Pack - French
Literature Pack - French (Non EU)
Literature Pack - German
Literature Pack - Greek
Literature Pack - Hungarian
Literature Pack - Italian
Literature Pack - Latvian
Literature Pack - Lithuanian
Literature Pack - Norwegian
Literature Pack - Polish
Literature Pack - Portuguese
Literature Pack - Portuguese (Non EU)
Literature Pack - Romanian
Literature Pack - Russian
Literature Pack - Slovakian
Literature Pack - Slovenian
Literature Pack - Spanish
Literature Pack - Spanish (Non EU)
Literature Pack - Turkish
Digger Bucket Pin Kit - Single
Digger Bucket Pin Kit - Double
Loader Bucket Tooth Kit - Standard
Loader Bucket Tooth Kit - Multi-Purpose
Blade - MP - Wide
Blade - MP - Narrow
Beacon - Twin
Beacon - Single
Toolkit - Service
Shipping Kit - 2WS Wood Blocks
Oil - Biodegradeable Hydraulic
Loader Bucket Pin Kit
Spare Wheel - Front - White
Spare Wheel - Front - Yellow
Blade - Narrow - 3 Piece
Blade - Wide - 3 Piece
Street Pad - Sideshift
CESAR Datatag
Hose Burst - Loader - Bucket Cylinder
Hose Burst - Loader - Lift Cylinder
Digger Bucket Pin Kit - 3 Sets
Digger Bucket Pin Kit - 4 Sets
Guard Kit - Hydraulic Hoses
Manual Quick Coupler - Loader
High Tip Bucket - LC/HD
Pallet Fork - 1200mm
Sweeper Collector - 2500mm - Bucket
Sweeper Collector - 2500mm - Broom
Sweeper Collector - 2500mm - Decals
Dust Suppression Kit
Gutter Brush
Fork & Grapple
Spare Wheel - Rear - White
Spare Wheel - Rear - Yellow
Spinnner Knob Kit - Steering Wheel
Fuel Strainer Kit
Bump Stop Kit - Hard Nose
Rear Worklamp Kit - 2 Lamps
Rear Worklamp Kit - 4 Lamps
Anti-Vandal Covers
Counterweight
Hose Burst - Digger - Sideshift - Mechanical
Hose Burst - Digger - Centremount - Servo
Hose Burst - Digger - Sideshift - Servo
Hose Burst - Digger - Centremount - Mechnical
Object Handling Kit - Sideshift - Standard Dipper - ISO
Object Handling Kit - Sideshift - Standard Dipper - ANSI
Object Handling Kit - Sideshift - Extending Dipper - ISO
Object Handling Kit - Sideshift - Extending Dipper - ANSI
Object Handling Kit - None
Stab Leg Rock Guard - OPTION
