che_slav
240
McCormick XTX Series Tractors Service/Diagnostic Manual SM 8-15002
Download this document, you need 400 Gallons
Type: PDF
Pages: 1540
Table of Contents:
1 GENERAL
Safety Rules, General Information and Torque Specifications .........................................................................................1001 SM
2 ENGINE
NOTE: For Service and Overhaul procedures refer to your Engine Service Manual. SM
Error Codes: Tier 2 Tier 3
3 FUEL
4 ELECTRICAL
Electrical Troubleshooting and Schematics..............................................................................................................................4001 SM
Instrument Cluster Programming................................................................................................................................................4002 SM
Battery Servicing and Testing........................................................................................................................................................4004 SM
5 STEERING
Steering Column and Steering Hand Pump Removal ..........................................................................................................5001 SM
Rexroth Steering Hand Pump.........................................................................................................................................................5002 SM
6 TRANSMISSION
Transmission How it Works ............................................................................................................................................................6
Guidelines for Separating the Speed and Range Transmissions ........................................................................................6003 SM
8 Speed Powershift Transmission Servicing ..............................................................................................................................6006 SM
Range Transmission Servicing .......................................................................................................................................................6007 SM
Differential and Differential Lock Servicing ..............................................................................................................................6012 SM
MFD Clutch Servicing ........................................................................................................................................................................6017 SM
Rear Axle Removal .............................................................................................................................................................................6018 SM
PTO Servicing - shiftable/reversible .............................................................................................................................................6019 SM
MFD Front Axle (20.29 Rigid Axle) ................................................................................................................................................6021 SM
MFD Front Axle (20.43 Rigid Axle) .......................................................................................................................................... 6021-A SM
MFD Front Axle (20.29 Suspended Axle) .....................................................................................................................................6022 SM
MFD Front Axle (20.43 Suspended Axle) ............................................................................................................................... 6022-A SM
7 BRAKES
Brakes How it Works.......................................................................................................................................................................... 7
Service Brakes ...................................................................................................................................................................................... 7002 SM
8 HYDRAULICS
Hydraulics How it Works .................................................................................................................................................................. 8
Hydraulic Troubleshooting and Schematic ................................................................................................................................ 8001 SM
Charge/Lubrication Pump ............................................................................................................................................................... 8003 SM
Remote Valves....................................................................................................................................................................................... 8008 SM
9 CHASSIS
Pedal, Lever and Switch Adjustments ........................................................................................................................................... 9001 SM
10 CONTROLLER SYSTEMS
Electrical Controllers How it Works.............................................................................................................................................. 10
Auxiliary/Remote Valve Controller - Error Codes,Troubleshooting and Schematics ................................................. 10001 SM
Hitch/PTO Controller - Error Codes,Troubleshooting and Schematics ........................................................................... 10002 SM
Independent Front Suspension Axle Controller - Calibration,Error Codes, Troubleshooting and Schematics... 10003 SM
Transmission and Cab Controller - Calibration, Error Codes, Troubleshooting and Schematics .......................... 10006 SM
Instrument Cluster Controller - Error Codes, Troubleshooting and Schematics .......................................................... 10009 SM
Controller Reprogramming (Using The McCormick Diagnostic Centre) ........................................................................ 10010 SM
Cab Suspension Controller - Calibration, Error Codes, Troubleshooting and Schematics ....................................... 10011 SM
Automatic Temperature Control - Error Codes, Troubleshooting and Schematics ..................................................... 10012 SM
NOTE: Information contained in this manual may cover features that are not available in all markets
worldwide.
NOTE: References throughout this manual may be made to sections currently not available. These
Sections will be made available at a later date.
