Hyundai
86
176,684
McCloskey Crushers J6 Parts Manual 2023
Brand: McCloskey
Type of Machine: Crushers
Model: McCloskey J6 Crushers
Publication Date: 2023
Number of Pages: 370 Pages
01-01-A Filters (Cat C13 Tier 3)
01-01-A Filters (Cat C13b Stage 5)
01-01-B Filters (Volvo D13 Stage 5)
01-02-A Crusher Wear Plates
02-01-A Chassis Overview 1-2
02-01-B Chassis Overview 2-2
02-01-C Chassis Valves
02-02-A Toolbox
02-02-B Dust Suppression
02-03-A Crusher Jacking Legs - Check Valve
02-03-B Crusher Jacking Legs - Check Valve Breakdown
02-03-C Screen Flow Control Valve
02-03-D Screen Flow Control Valve Breakdown
03-01-A Tracks
04-01-A Hopper
04-01-B Hopper Wearplates And Extensions
04-02-A Pan Feeder (Standard Feeder Option)
04-02-B Pan Feeder Chute (Standard Feeder Option)
04-02-C Pan Feeder Wearplates (Standard Feeder Option)
04-02-D Pan Feeder Vibrator 1-2 (Standard Feeder Option)
04-02-E Pan Feeder Vibrator 2-2 (Standard Feeder Option)
04-02-F Muck Chute (Standard Feeder Option)
04-02-G Muck Chute Rear Exit (Standard Feeder Option)
04-03-A Prescreen Overview
04-03-B Short Pan Feeder (Prescreen Option)
04-03-C Pan Feeder Vibrator - Drive Side (Prescreen Option)
04-03-D Pan Feeder Vibrator - Non Drive Side (Prescreen Option)
04-03-E Prescreen
04-03-F Screening Media
04-03-G Prescreen Wearplates
04-03-H Prescreen Shaft (Drive Side)
04-03-I Prescreen Shaft (Non Drive Side)
04-03-J Prescreen Chute
04-03-K Muck Chute (Prescreen Option)
05-01-A Powerunit Overview
05-01-C Powerunit Front Door
05-01-D Powerunit Back Door
05-01-E Powerunit Top Doors
05-01-F Powerunit Door Lh
05-01-G Powerunit Door Rh (Cat C13)
05-01-H Powerunit Door Rh (Volvo D13)
05-02-A Oil Cooler
05-02-B Battery Box Assembly
05-02-C Suction Manifold
05-02-D Return Line Manifold
05-02-E Accumulators
05-02-F Snorkle (Option)
05-03-A Control Panel Overview
05-03-B Control Panel Valves 1-2
05-03-C Control Panel Valves 2-2
05-03-D Crusher Control Valve Block
05-03-E Crusher Control Valve Block Breakdown
05-03-F Toggle Ram Control Block
05-03-G Toggle Ram Control Block Breakdown
05-03-H Pilot Manifold 2 Speed - Brake Valve
05-03-I Pilot Manifold 2 Speed - Brake Valve Breakdown
05-03-J Pressure Relief Valve (Rock Breaker Option)
05-04-A Hydraulic Oil Water Filter
05-05-A Engine Overview (Cat C13 Tier 3)
05-05-B Air Intake (Cat C13 Tier 3)
05-05-C Exhaust (Cat C13 Tier 3)
05-05-D Engine Filters (Cat C13 Tier 3)
05-05-E Engine Pumps (Cat C13 Tier 3)
05-06-A Air Intake (Cat C13b Stage 5)
05-06-B Exhaust (Cat C13b Stage 5)
05-06-C Engine Filters (Cat C13b Stage 5)
05-06-D Engine Pumps (Cat C13b Stage 5)
05-06-E Adblue Tank (Cat C13b Stage 5)
05-07-A Air Intake (Volvo D13 Stage 5)
05-07-B Exhaust (Volvo D13 Stage 5)
05-07-C Engine Filters (Volvo D13 Stage 5)
05-07-D Engine Pumps (Volvo D13 Stage 5)
05-07-E Adblue Tank (Volvo D13 Stage 5)
05-07-F Adblue Pump (Volvo D13 Stage 5)
05-08-A Pump Drive
05-08-B Pump 12 9t
05-08-C Pump 36 (Rockbreaker Option)
05-08-D Pump 56 36
05-08-E Pump 36 23 (Cat C13b Stage 5)
05-08-F Pump 28 19 (Volvo D13 Stage 5)
06-01-A Hydraulic Tank
06-01-B Hydraulic Tank Fittings
06-01-C Return Filter Manifold
06-01-D Hydraulic Tank (Rockhammer Option)
06-01-E Hydraulic Tank (Heater Option)
07-01-A Diesel Tank
08-01-A Flywheel Cover
08-01-B V Belt Cover
08-01-C Hydraulic Crusher Motor
08-01-D Hydraulic Crusher Motor Mount
08-01-E Jaw Bolt Tensioner
08-01-F Jaw Motor Test Block
08-01-G Jaw Motor Support
08-02-A Jaw Feedbox
08-02-B Jaw Side Rubber
08-02-C Jaw Speed Sensor
08-02-D Deflector Plate (Option)
08-02-E Jaw Feet
08-03-A Mounting
08-03-B Tri-Nut
08-03-C Installation Parts
08-03-D Jaw Dies And Cheek Plates
08-04-A Service Platform 1 Part 1
08-04-B Service Platform 1 Part 2
08-04-C Adaptor 1
08-04-D Serivce Platform 2 Part 1
08-04-E Service Platform 2 Part 2
08-04-F Adjustment Piece
08-04-G Adaptor 2
08-05-A Basic Assembly
08-05-B Pitman Assembly
08-05-C Frame Assembly
08-05-D Toggle Seat Holder
08-05-E Hydraulic Wedge Adjustment
08-05-F Cylinder
08-05-G Flywheel Installation
08-05-H Counterweight Installation
08-05-I Support Installation
08-05-J Damper
08-06-A Tool And Equipment
08-06-B Lifting Link 1
08-06-C Lifting Link 2
08-06-D Shackle
08-07-A Bracket Installation
08-07-B Box Assembly
08-07-C Terminal Box 1
08-07-D Terminal Box 2
08-07-E Terminal Box 3
08-08-A Sensor Installation
10-01-A Main Conveyor Overview
10-01-B Main Conveyor Upper
10-01-C Main Conveyor Drive
10-01-D Main Conveyor Belt Scraper
10-01-E Main Conveyor Mid Section
10-01-F Main Conveyor Lower 1-2
10-01-G Main Conveyor Lower 2-2
10-02-A Side Conveyor Overview
10-02-B Side Conveyor Upper
10-02-C Side Conveyor Drive
10-02-D Side Conveyor Mid Section
10-02-E Side Conveyor Lower
10-02-F Side Conveyor Feedboot
11-01-A Powerunit Walkway
11-02-A Cross Platform Walkway
11-02-B Divider Valve
11-03-A Side Walkway
11-04-A Prescreen Walkway (Option)
12-01-A Powerunit Kit
12-01-B Powerpack Sensor Pack
12-02-A Chassis Electric Kit
12-02-B Chassis Sensor Pack
12-03-A Volvo D13 Stage V Engine Harness Kit
12-04-A C13b Stage V Engine Kit
12-05-A Control Panel Breakdown
13-01-A Magnet Fixtures
13-01-B Magnet
13-02-A Rock Hammer
13-02-B Rock Hammer Main Body
13-02-C Rock Hammer Main Body Seal Kit
13-02-D Rock Hammer Frame Assembly
13-02-E Rock Hammer Back Head Charging Kit
13-03-A Rock Hammer Modules
13-03-B Rock Hammer Pedestal Module
13-03-C Rock Hammer Lift Boom Module
13-03-D Rock Hammer Stick Boom Module
13-03-E Rock Hammer Mounting Bracket
13-03-F Rock Hammer Pins Set
13-03-G Rock Hammer Cylinders
13-03-H Rock Hammer Lift Cylinder
13-03-I Rock Hammer Stick Cylinder
13-03-J Rock Hammer Tilt Cylinder
13-03-K Rock Hammer Cylinder Spare Parts
13-03-L Rock Hammer Boom Piping (Oc)
13-03-M Rock Hammer Boom Piping (Cc)
13-03-N Valve Assembly (Oc)
13-03-O Valve Fittings
13-03-P Valve Spare Parts
Back Page
