Mazda OBD-II Diagnostics Trouble codes
The common trouble codes for Mazda vehicle, The service and repair manual complement. P1110 Intake Air Temperature Sensor Signal (Dynamic Chamber) Circuit P1112 Intake Air Temperature Sensor Circuit Intermittent P1113 Intake Air Temperature Sensor Signal (Dynamic Chamber) Circuit P1114 Intake Air Temperature Sensor Circuit Low Input P1116 ECT Sensor Circuit Out of Self Test Range P1117 ECT Sensor Signal Intermittent P1120 Throttle Position Sensor out of Range Low P1121 Throttle Position Sensor Signal Not Consistent with Mass Airflow Signal P1122 Throttle Position Stuck Closed P1123 Throttle Position Stuck Open P1124 Throttle Position Sensor Signal Out of Self Test Range P1125 Throttle Position Sensor Signal Intermittent. P1358 Ignition Diagnostic Monitor Signal Out Of Self Test Range P1359 SPOUT Signal Lost To Powertrain Control Module Or Out Of Range P1360 Ignition Coil ‘A’ Secondary Circuit P1361 Ignition Coil ‘B’ Secondary Circuit P1362 Ignition Coil ‘C’ Secondary Circuit P1364 Ignition Coil Primary Circuit P1365 Ignition Coil Secondary Circuit P1390 Octane Adjust Shorting Bar Out or Circuit Open P1400 DPFE Sensor Circuit Low Input P1401 DPFE Sensor Circuit High Input P1402 EGR Valve Position Sensor Circuit.
http://www.tdm-trx.nl/Manuals/4TX_97_Suppl.Manual10.pdf
- Mazda BT-50 2007 Workshop Repair Manual
- Mazda CX-5 2013 Workshop Manual
- Mazda CX-5 2012 Workshop Repair Manual
- Mazda 6 (GG) (2002-2007) Wiring diagrams
- Mazda 6 2010 Workshop Repair Manual
- Mazda BT-50 2012 Service Repair Manual
- MAZDA R2, RF (MZR-CD), WL, WL-T-guidance on repair, maintenance and operation of the engine. RUS
- Mazda CX-5 2016 4WD 2.0-2.5 Wiring Diagram
- Mazda 2 [2002-2014] Workshop Manual
- Mazda BT-50 2009 Workshop Repair Manual
- Mazda PREMACY WorkShop Manual 2001
- Mazda 3 2014 Workshop &Repair Service Manual
- Mazda RX-8 Service Manual - Engine Repair and Mechanical
- Mazda 2 2003 Workshop Manual
- Mazda 6 2014 Wiring Diagram & Workshop Manual
