Hyundai
86
176,834
Manitowoc Carrydeck Crane CD15 Operator Manual
Brand: Manitowoc
Type of Machine: Carrydeck Crane
Model: Manitowoc CD15 Carrydeck Crane
Publication Date: 2022
Number of Pages: 168 Pages
Introduction
The Manual​
Directional Reference​
Serial Number Plate​
Reports​
Disclaimer​
Customer Support​
Distributor​
Safety Information​
New Owners​
Nomenclature​
Safety Information
Safety Messages​
General​
Safety Alert Symbol​
Signal Words​
General​
Safety Decals​
Accidents​
Operator Information​
Operator Qualifications​
Operational Aids​
Rated Capacity Limiter (RCL) Systems (If Equipped)​
Anti-Two-Blocking Device​
Working Area Limiter (If Equipped)​
Crane Stability/Structural Strength​
Load Charts​
Work Site​
Wind Forces​
Wind Speeds​
Lifting Operations​
Multiple Crane Lifts​
Lifting Multiple Loads​
Tilt-Up Panel Lifting​
Counterweight​
Outrigger Lift Off​
Electrocution Hazard​
Set-Up and Operation​
Electrocution Hazard Devices​
Electrical Contact​
Special Operating Conditions and Equipment​
Grounding the Crane​
Personnel Handling​
Environmental Protection​
Maintenance​
Service and Repairs​
Lubrication​
Tires​
Hoist Rope​
Synthetic Hoist Rope​
Wire Rope​
Sheaves​
Batteries​
Super Capacitor (If Equipped)​
General Maintenance​
Transporting the Crane​
Travel Operation​
Work Practices​
Personal Considerations​
Crane Access​
Job Preparation​
Working​
Lifting​
Hand Signals​
Boom Extension​
Parking and Securing​
Shut-Down​
Cold Weather Operation​
Temperature Effects on Hook Blocks​
Temperature Effects on Hydraulic Cylinders​
Overload Inspection​
Boom Inspection​
Mast Inspection​
Carrier Inspection​
Operating Controls And Procedures
Controls, Switches, and Gauges​
Crane Controls​
Warning Alarms​
Panel Switches, Gauges, and Indicators​
Ignition Switch​
Operator Aids​
Rated Capacity Limiter (RCL)​
Operational Aid Malfunction​
Operator’s Cab​
Seat Belt​
Seat Adjustment​
Cab Door (Enclosed Cab)​
Heater, A/C, and Defroster​
Fire Extinguisher​
Crane Operation​
Starting the Engine​
Jump Starting Hazard​
Charging the Batteries​
Traveling the Crane​
Cold Climate Engine Operation​
Crane Warm-up Procedures​
Operating Outrigger Controls​
Raise and Lower the Outriggers​
Outrigger Monitoring System (OMS)​
Operating Crane Controls​
Anti-Two Blocking System​
Boom Swing Operation​
Boom Telescope Operation​
Boom Lift Operation​
Hoist Operation​
Operating Optional Controls​
Auxiliary Winch Operation​
Operating Practices​
Handling A Load​
Attaching the Load​
Holding the Load​
Moving the Load​
Traveling with a Load (Pick and Carry)​
Turning Clearances​
Crane Shutdown​
Unattended Crane​
Towing A Disabled Crane​
Switching LP/Gasoline Fuel (Dual Fuel Engines)​
Capacity Chart
Using the Capacity Chart​
Determine Operating Status​
Determining Lift Capacity​
Things to Observe When Using the Capacity Chart​
Determining Lift Capacity at the Boom Extension​
Pick and Carry Ranges​
Hook Block​
Removing the Hook Block​
Installing the Hook Block​
Downhaul Weight​
Installing the Downhaul Weight​
Removing the Downhaul Weight​
Boom Extension (Jib)​
Installing the Boom Extension​
Stowing the Boom Extension​
Pivoting Boom Head​
Boom Head Positions​
Changing the Boom Head Position (without Boom Extension)​
Changing the Boom Extension Offset​
Searcher Hook Assembly​
Installation​
Removal​
Installing Cable On The Hoist​
Wire Rope Wedge Socket​
4 Part Wire Rope Reeving​
Maintenance
Introduction​
Spark Arresting Mufflers​
Safety List​
Lubricants​
Maintenance Records​
Maintenance​
Preparation​
Hydraulic System Maintenance Precautions​
Label Parts when Disassembling​
Hydraulic Oil Recommendations​
Draining and Flushing​
Removing Air From the Hydraulic System​
Parts Replacement​
Special Maintenance​
Delivery Inspection​
After First 50 Hours of Operation (New Cranes)​
After First 100 Hours of Operation (New Cranes)​
Cranes Not In Regular Use​
Preventive Maintenance​
Maintenance Schedule and Checklist​
Lubrication Points​
Daily Walk-around Inspection​
Inspect the Anti-Two Blocking System​
Inspect the Wire Rope​
Inspect Reeving, Clamps and Connections​
Inspect the Lifting Hook​
Inspect All Safety Devices​
Check Controls Operation​
Component/System Checks​
Check Diesel or Gasoline Fuel Level​
Check LP Gas Fuel Level​
Check the Engine Crankcase Oil Level​
Check the Transmission Oil Level​
Check Engine Coolant Level​
Drain Water from Engine Fuel Filter​
Check Hydraulic Oil Level​
Service Dual-Fuel Engine Air Cleaner​
Service Tiers 3 and 4 Engine Air Cleaner​
Check Tire Pressure​
50 Hours of Operation (Weekly)​
Clean the Air Cleaner Dust Cup​
Wire Rope Inspection​
Grease Fittings​
Lubricate Parking Brake​
Lubricate the Boom Slides​
100 Hours of Operation (Two Weeks)​
Inspect the Fan Belts​
Check Wheel Nut Torque​
175 Hours of Operation​
250 Hours of Operation (Monthly)​
Inspect the Hydraulic Hoses​
Clean Battery and Cables​
Clean the Radiator​
Lubricate the Wire Rope​
Lubricate the Swing Gear and Pinion​
Replace the Crankcase Oil and Filter​
Torque Critical Bolts​
Hoist Gearbox Mounting Bolts​
Swing Gearbox Mounting Bolts​
Mast Mounting Bolts​
Front Axle Mounting Bolts​
Rear Axle Mounting Bolts​
500 Hours of Operation (3 Months)​
Replace the Transmission Filter​
Inspect the Tires​
Inspect Parking Brake Pads​
Replace Fuel Filter​
Add SCA to Engine​
Lubricate the Outrigger Slides​
Add Grease to the Swing Gearbox​
Lubricate Drivelines​
Check Axle Housing Lubricant Level​
Check Wheel Hub Lubricant Level​
Check Hoist Gearbox and Brake Lubricant Levels​
1000 Hours of Operation (6 Months)​
Replace the Transmission Oil and Filter — 4WD​
Replace the Transmission Oil and Filter — 2WD​
Replace the Axle Housing Oil​
Replace Axle Wheel Hub Lubricant​
Replace the Hoist Gearbox Oil​
Replace the Hoist Brake Oil​
Replace the Hydraulic Oil​
Replace the Hydraulic Oil Filter​
Check Swing Gear/Pinion Backlash​
2000 Hours of Operation (Yearly)​
Replace the Engine Coolant​
Inspect the Crane Structure and Boom for Damage​
Testing the Rated Capacity Limiter (Optional)​
Miscellaneous Maintenance​
Batteries/Charging System​
Fuel System​
Fuel Storage​
Fuse Replacement​
Carwell® Rust Inhibitor​
Protecting Cranes From Rusting​
Cleaning Procedures​
Inspection and Repair​
Application​
Areas of Application​
Adjustments
Specification
Lubrication Schematic​
Lubrication Symbols​
Lubrication Legend​
Lubrication Notes​
Engine Oil Specifications​
Fuel Types​
Relief Valve Settings​
General Specifications​
Boom​
Electrical System​
Engine​
Fuel Tank​
Hydraulic System​
Mast​
Outriggers​
Tires​
Travel Speeds (approximate)​
Weight (GVW)​
Wire Rope​
Dimensions (Side View)​
Dimensions (Top View and Rear View)​
