Hyundai
86
176,834
Manitowoc Carrydeck Crane 5540F YB5515 Service Manual
Brand: Manitowoc, Grove
Type of Machine: Carrydeck Crane
Model: Manitowoc 5540F YB5515 Carrydeck Crane
Publication Date: 2011
Number of Pages: 412 Pages
Introduction
Directional Reference​
Identification Plates​
Specifications​
General Maintenance​
Cleanliness​
After Cleaning​
Removal and Installation​
Disassembly and Assembly​
Pressing Parts​
Locking Devices​
Wires and Cables​
Shims​
Hoses and Tubes​
Bearings​
Gaskets​
Batteries​
Hydraulic Systems​
Electrical System​
Fatigue of Welded Structures​
Loctite​
Fasteners and Torque Values​
Weld Studs (Table 1-10)​
Hydraulic Fitting​
Wire Rope​
General​
Environmental Conditions​
Dynamic Shock Loads​
Lubrication​
Precautions and Recommendations During Inspection or Replacement​
Wire Rope Inspection (Running Ropes and Pendant Cables)​
Keeping Records​
Frequent Inspection​
Wire Rope Inspection (Boom Extension and Retraction Cables)​
Wire Rope Inspection/Replacement (All Wire Rope)​
Seizing Wire Rope​
Installing Flex-X 35 Wire Rope​
Procedures for Cutting and Preparing Flex-X 35​
O-ring, Seal and Elastic Nut Replacement​
Hydraulic Pressure Testing​
Safety Practices
Introduction​
Signal Words​
Personal Considerations​
Equipment Considerations​
General Considerations​
Operational Considerations​
Final Word​
Electric System
General​
Comparing Electrical System to a Hydraulic System​
Magnetism​
Main Electrical System​
General​
Wire Harnesses​
Fuses​
Charging System​
Alternator and Voltage Regulator​
Batteries​
Voltmeter​
Pressure Switch​
Special Precautions​
Battery Maintenance and Charging​
Starting Circuit​
General Inspections​
Starting Circuit Check​
Instrument and Light Circuits​
General​
Light Bulbs​
Gauges​
Wire Harnesses​
Engine Wire Harness​
Instrument Panel Wire Harness​
Accessory Circuits​
Anti-Double Blocking System (Figure 3-6)​
Load Moment Indicator (LMI) System (Figure 3-1)​
Optional Engine Shutdown​
Heater​
Troubleshooting​
Technical Data​
General Description​
General​
Hydraulic System​
Troubleshooting​
Troubleshooting Aids​
Troubleshooting Procedures​
Troubleshooting Guides​
Suction, Pressure and Return Circuits​
General​
Hydraulic Pump​
Main Relief Valves​
Main Control Valve​
Adjusting Main Relief Valve Pressure Settings​
Lift Circuit​
General​
Oil Flow​
Holding Valve​
Lift Cylinder Leakage Check​
Hydraulic Swivel​
Crowd Circuit​
General​
Oil Flow​
Holding Valve​
Crowd Cylinders Leakage Test​
Hydraulic Swivel​
Main Winch Circuit​
General​
Oil Flow​
Brake Holding Valve​
Hydraulic Swivel​
Swing Circuit​
General​
Oil Flow​
Anti-Double Blocking System​
General​
System Function​
Outrigger Circuit​
General​
Oil Flow​
Load Holding Valves​
Outrigger Cylinder Leakage Check​
Axle Lockout Circuit​
General​
Oil Flow​
Component Repair​
Hydraulic Pump Repair​
Main Control Valves​
Swing Motor​
Hydraulic Swivel​
Hydraulic Cylinders​
Preventative Maintenance
Introduction​
Spark Arresting Mufflers​
Safety List​
Lubricants​
Maintenance Records​
Special Maintenance​
Delivery Inspection​
After First 50 Hours of Operation (New Cranes)​
Cranes Not In Regular Use​
Preventive Maintenance​
Maintenance Schedule and Checklist​
Lubrication Points​
Scheduled Maintenance​
Daily (Walk-around) Inspection​
50 Hours of Operation (Weekly)​
100 Hours of Operation (Two Weeks)​
250 Hours of Operation (Monthly)​
500 Hours of Operation (3 Months)​
1000 Hours of Operation (6 Months)​
2000 Hours of Operation (Yearly)​
Miscellaneous Maintenance​
Batteries/Charging System​
Fuel System​
Fuse Replacement​
Carwell® Rust Inhibitor​
Protecting Cranes From Rusting​
Cleaning Procedures​
Inspection and Repair​
Application​
Areas of Application​
Engine and Engine Systems
General​
Engine Types​
Engine Performance​
Engine RPM​
Governor​
Engine Crankcase System​
Crankcase Oil Data​
Engine Cooling System​
Coolant Requirements​
Radiator Cap and Overflow Bottle​
Thermostat​
Engine Electrical System​
Engine Fuel System​
Diesel Engine Fuel System Description​
QSB Engine Electronic Controlled Fuel System Units​
Types of Fuel to Use​
Engine Air Intake System​
Engine Exhaust System​
Checks and Adjustments​
Throttle Linkage Adjustment​
Removal​
Installation​
Dual Fuel Engine And engine Systems​
General​
Engine Types​
Engine Performance​
Engine RPM​
Governor​
Crankcase System​
Crankcase Oil Data​
Thermostat​
Engine Fuel Systems​
Fuel Injected Dual Fuel System​
Fuel Tank​
Fuel Level Sender and Gauge​
Fuel Pump​
Electronic Fuel Injection System​
Fuel Injection Components​
Troubleshooting​
Removal And Installation​
Transmission and Torque Converter
Technical Data​
General Technical Data​
Clutch Solenoid Technical Data​
Description of Operation​
General​
Reverser Clutch​
Hydraulic 2/4-Wheel Drive Unit - Spring ON/Pressure OFF​
Hydraulic 2/4-Wheel Drive Unit - Pressure ON/Spring OFF​
Hydraulic 2/4-Wheel Drive Unit - Pressure ON/Spring OFF (cont'd)​
Troubleshooting​
General Troubleshooting​
Hydraulic 2/4-Wheel Drive Unit (Spring ON/ Pressure OFF)​
Hydraulic 2/4-Wheel Drive Unit (Pressure ON/Spring OFF)​
Water Contamination​
Transmission Repair​
Servicing the Torque Converter​
Servicing the Transmission​
Transmission Gearbox Repair​
Assembly​
Solenoid Valve Disassembly and Assembly​
Assembly​
Hydraulic 2/4-Wheel Drive Unit Disassembly and Assembly (Pressure ON/Spring OFF Type)​
Hydraulic 2/4-Wheel Drive Unit Disassembly and Assembly (Spring ON/Pressure OFF Type)​
Hydraulic 2/4-Wheel Drive Unit Pressure Testing (Spring ON/Pressure OFF Type)​
Axles/Drive Shafts/Wheels and Tires
Description​
Front Axle​
Rear Axle​
Technical Data​
Front Drive Axle​
Rear Drive Axle​
Rear Non-Drive Axle​
Front Drive Axle Repair​
Removal​
Installation​
Special Tools​
Replacing The Pinion Oil Seal​
Axle Hub Repair​
Drive Head Repair​
Rear Axles Repair​
Removal​
Installation​
Service Tools​
Replacing the Pinion Oil Seal​
Axle Hub Repair​
Drive Head Repair (Drive Axles Only)​
Drive Shafts​
Removal​
Disassembly​
Inspection​
Assembly​
Installation​
Lubrication Procedure​
Wheel & Tires​
Tire Inflation​
Wheel Stud Nuts​
Technical Data​
Front Axle Brakes​
Rear Axle Brakes​
Accumulator​
Accumulator Charging Valve​
Priority Flow Control Valve​
Description​
Service Brake System​
Parking Brake System​
Maintenance And Adjustments​
Service Brake Bleeding​
Parking Brake Bleeding​
Parking Brake Adjustment​
Accumulator Charging​
Residual Brake System Pressure​
Tests​
Brake Piston Seal Leakage Test (Front Axle Only)​
Service Brake Repair​
Front Axle Brakes​
Rear Axle Brakes​
Parking Brake Repair​
Lining Kit Replacement​
Repair Kit Installation​
Seal Kit Installation​
Brake Modulating Valve Repair​
Removal​
Disassembly​
Assembly​
Installation​
Troubleshooting​
Service Brakes​
Units Without Return-To-Center Steering​
Technical Data​
Description​
Two-Wheel Steering​
Four-Wheel Steering​
Crab Steering​
Relief Valve Pressure Check And Adjustment​
Pressure Check​
Pressure Adjustment​
Units With Return-To-Center Steering​
Technical Data​
Description​
General​
Steering Modes​
Two-Wheel Steering​
Crab Steering​
Steering Proximity Switches​
General​
Principle Of Operation​
Sensor Operation And Spacing Checks​
Steering Orbitrol​
Description​
Orbitrol Repair​
Steering Cylinder​
Technical Data​
Special Tools​
Cylinder Repair​
Structurals
Booms​
General​
Disassembly​
Assembly​
Wire Rope, Sheaves and Hoist Blocks​
Wire Rope Description​
Wire Rope Safety​
Inspecting Wire Rope​
Inspection of Sheaves​
Wire Rope Lubrication​
Wire Rope Installation​
Main Winch (Tulsa Model)​
Theory Of Operation​
Repair​
Troubleshooting​
Main Winch (Braden Model)​
Winch Operation​
Repair​
Troubleshooting​
Bearing, Mast And Related Parts​
General​
Mast Bearing​
Mast Bearing Bolts​
Inspection For Bearing Wear​
Replacing The Mast Bearing​
Swing Gearbox And Pinion​
Swing Gearbox Repair (Tulsa Gearbox)​
Swing Gearbox Repair (Braden Gearbox)​
Outriggers​
Outrigger Monitoring System (OMS)(Optional—Standard in North America)​
Cylinder Removal​
Cylinder Installation​
