Mahindra Tractor mPOWER Series 85 85P mCRD Operator Manual
Brand: Mahindra
Model:
Mahindra mPOWER Series 85 mCRD Tractor
Mahindra mPOWER Series 85P mCRD Tractor
Number Of Pages: 158 Pages
Emission Control Warranty for California
Emission Control Warranty for Federal
About This Manual
Introduction
General Description
Owner Assistance
Owner’s Personal Data
ROPS (mPower 85)
Safety Instructions
Safety Signs (mPower 85)
Safety Signs (mPower 85P)
Universal Symbols
LH and RH View of Engine (mPower 85)
Lamps (mPower 85)
LH and RH View of Engine (mPower 85P)
Lamps (mPower 85P)
Controls, Instruments & Operations (mPower 85)
Controls, Instruments & Operations (mPower 85P)
Instrument Cluster
RPM Meter
Hour Counter
Fuel Gauge
Low Fuel Warning Indicator
Coolant Temperature Gauge
High Temperature Warning Indicator
High Temperature Defect Indicator
Engine Defect Indicator
Engine Healthy Indicator
Transmission and PTO Neutral Indicator
Parking Brake Indicator
High Beam Indicator
Battery Charging Indicator
Low Engine Oil Pressure Indicator
Air Filter Clog Indicator
Turn Indicators
MIL (Malfunction) Indicator
CHK ENG (Check Engine) Indicator
4WD Indicator
PTO 540 RPM Indicator
Heater Indicator
PTO 1000 RPM Indicator
Service Due Indicator
Low Oil Pressure Indicator
Beeper Output Provision
Self Test Function
Trailer Indicator
Buzzer for Transmission Low Oil Pressure
Switches
Scuttle Lamp Switch
Light Switch
Turn Signal Switch
Key Switch
Hazard Switch
Horn
Controls
Operator Seat
Adjusting Seat Position
Height and Weight Adjustment
Tilt Adjustment
Using Seat Belt
Fasten Seat Belt
Release Seat Belt
Hand Throttle Operation
Increasing Engine Speed
Engine Tachometer Speed
Decreasing Engine Speed
Constant Speed Setting
Foot Throttle Operation
Can Holder
Tilt Steering
4WD Engagement Lever
Brake
Glove Box
Differential Lock Pedal
Main and IPTO Clutch
IPTO Clutch
F-R Shuttle Shift Lever
Range Shift Lever
Speed Shift Lever
Auxiliary Valve
Loader
Opening the Hood
Closing the Hood
Opening Side Panels
Closing the Side Panels
Joystick Lever
Keys
Opening Doors from Outside
Opening Doors from Inside
Rear View Mirrors
Rear Window
Windshield Wiper/Washer System Controls
Adding Suitable Anti-freeze Solution to
Water in Reservoir
Heater and Air Conditioning Controls
Blower Speed Control Regulator
Heater Regulator
Cooling Regulator
AC ON/OFF Switch
Fresh/Recirculation Air Selector Switch
Cab Worklight Switches
Cabin Interior Lights
Power Socket Unit
Cigarette Lighter
3 - Terminal Power Socket
Optional Power Socket
Ashtray
Glove Tray
Coat Hook
Sun-visor
Audio System
PTO Speed Selection
Hydraulic System and Operation (mPower 85)
Hydraulic System and Operation (mPower 85P)
Position Control-Operation
Quadrant Assembly
Position Control
Setting of Position Control
Draft Control - Operation
Draft Control
Setting the Draft Control
Three Point Linkage
Toplink
Draft Sensing Bracket
Telescopic Lower Links
Adjustable Lift Rods
Lateral Stabilizers
Swinging Drawbar
Adjusting Drawbar length
Using Swinging Drawbar
Attaching PTO Driven Implement
Jerrycan Weights (Optional Fitment)
Seven Terminal Trailer Socket
Wheel Weights (Optional Fitment)
Wheel Tread Adjustment
Pneumatic Tires
Adding Liquid Weight
Inflation
Care of Tires
Shipping Tractors Equipped with
Tire Protection During Storage
Mounting Tires on the Rim
Operating Instructions
Before Starting The Tractor
Stopping The Engine
Cold Starting Aid
Glow Plug
Indications on Instrument Cluster
Driving The Tractor
Tractor Storage
Using The Tractor After Storage
Precautions
Operating The Tractor
The Tractor
Servicing The Tractor
Operating The PTO (Power Take Off)
Transporting Tractor on a Trailer
Towing
Diesel Fuel
Do’s and Dont’s
Maintenance
Engine Cooling System
Radiator Cap
Surge Tank
Thermostat
Hose Connections
Fan and Fan Belts
Belt Adjustment
Belt Removal
Belt Replacement
Draining the System
Cleaning Out Dirt and Sludge
Adding Coolant to the System
Cooling System Protection
Anti-freeze
Trash Guard for Radiator
Trash Guard for Intercooler
Adjusting The Valve Clearance
Cleaning the Cab Air Filters
Air Intake System
Air Cleaner
Body Air-Cleaner
Cyclopack or Built-in Pre-Cleaner
Paper Element Filter
Safety Cartridge
Dust Collector Bowl
Hose and Clamps
Emission Control System
Fuel System
Clean Diesel Fuel
Bleeding The CR Fuel Injection System
Fuel Tank and Fuel Pipes
Servicing The Fuel Filter
Lubrication System
Oil Level Check
Oil Change
Engine Oil Filter
Changing Spin On Filter
Turbocharger
Battery Maintenance Cleaning
Servicing
Effect of Low Temperatures
Charging Circuit
Starter Motor Removal
Air Conditioning System (Cabin)
Cab Air Conditioning System Safety
Switching ON the Air Conditioning
Adjustment
Switching OFF the Air Conditioning System
Tips on using Air Conditioning
Maintaining the Air Conditioning System
Heating Mode
Cleaning of Condenser & Wiremesh
Hydraulics and Transmission
Adding Hydraulic and Transmission Oil
Adding Oil in Rear Axle
Drained & Filled Oil Quantity
Hydraulic Suction Filter and
Transmission Oil Filter
Hydraulics and Transmission Strainer
Transmission Oil Drain
Transmission Oil Cooler
Power Steering
Tips for maintaining the
Power Steering System
Front Axle - Front Wheel “Toe-in” Check
Front Axle Oil Filling/Drain/Level Checking
Hub Housing
Clutch Pedal Free Play (mPower 85)
Clutch Pedal Free Play (mPower 85P)
Brake Pedal Free Play (mPower 85)
Brake Pedal Free Play (mPower 85P)
Head Lamp Adjustment
Lubricants
General
Lubricant Storage
Alternate and Synthetic Lubricants
Diesel Engine Lubricating Oil
Mixing of Lubricants
Engine Oil
Transmission, Hydraulics and
Oil Immersed Brakes
Chassis Lubricant (CL)
Front Axle
Oil Specifications Chart
Special Bolt Torques
Specifications - mPower 85
Specifications - mPower 85P
Trouble Shooting
Hydraulics
Brakes
Electricals
Cabin
Tractor History Card
Service Record
Part Replacement Record
Daily Operating Log
Tractor Storage Precautions
Lubrication & Greasing Chart - mPower 85
Lubrication & Greasing Chart - mPower 85P
Routine Service Schedule - mPower 85
Routine Service Schedule - mPower 85P
Wiring Diagram - mPower 85
Wiring Diagram - mPower 85P
Heating, Ventilation & Air Conditioning Circuit - mPower 85P
Individual Circuit - mPower 85 / 85P
Brand: Mahindra
Model:
About This Manual
Introduction
General Description
Owner Assistance
ROPS (mPower 85)
Safety Instructions
Universal Symbols
Lamps (mPower 85)
Lamps (mPower 85P)
Instrument Cluster
RPM Meter
Hour Counter
Fuel Gauge
High Beam Indicator
Turn Indicators
4WD Indicator
Heater Indicator
Self Test Function
Trailer Indicator
Switches
Scuttle Lamp Switch
Light Switch
Turn Signal Switch
Key Switch
Hazard Switch
Horn
Controls
Operator Seat
Tilt Adjustment
Using Seat Belt
Fasten Seat Belt
Release Seat Belt
Can Holder
Tilt Steering
Brake
Glove Box
IPTO Clutch
Range Shift Lever
Speed Shift Lever
Auxiliary Valve
Loader
Opening the Hood
Closing the Hood
Opening Side Panels
Joystick Lever
Keys
Rear View Mirrors
Rear Window
Water in Reservoir
Heater Regulator
Cooling Regulator
AC ON/OFF Switch
Power Socket Unit
Cigarette Lighter
Ashtray
Glove Tray
Coat Hook
Sun-visor
Audio System
PTO Speed Selection
Quadrant Assembly
Position Control
Draft Control
Three Point Linkage
Toplink
Lateral Stabilizers
Swinging Drawbar
Pneumatic Tires
Inflation
Care of Tires
Stopping The Engine
Cold Starting Aid
Glow Plug
Driving The Tractor
Tractor Storage
Precautions
The Tractor
Towing
Diesel Fuel
Do’s and Dont’s
Maintenance
Radiator Cap
Surge Tank
Thermostat
Hose Connections
Fan and Fan Belts
Belt Adjustment
Belt Removal
Belt Replacement
Draining the System
Anti-freeze
Air Intake System
Air Cleaner
Body Air-Cleaner
Safety Cartridge
Dust Collector Bowl
Hose and Clamps
Fuel System
Clean Diesel Fuel
Lubrication System
Oil Level Check
Oil Change
Engine Oil Filter
Turbocharger
Servicing
Charging Circuit
Adjustment
Heating Mode
Power Steering
Hub Housing
Lubricants
General
Lubricant Storage
Engine Oil
Oil Immersed Brakes
Front Axle
Trouble Shooting
Hydraulics
Brakes
Electricals
Cabin
Service Record
Daily Operating Log
- Mahindra Tractor MAX Series 28XL Operator Manual
- Mahindra AML205 FRONT END LOADER Assembly, Operator's and Parts Manual
- Mahindra Tractor 10 Series 5010 Gear Cab Parts Manual
- Mahindra Tractor Super Turbo 595 DI Sarpanch Parts Manual
- Mahindra Tractor 16 Series 3616 Gear & HST Parts Manual
- Mahindra Tractor 60 Series 8560 4WD Parts Manual
- Mahindra USA Backhoe Model 2710/3710A/3710B Operators Parts Manual and Instructions
- Mahindra Tractor 16 Series 2216 Gear & HST Parts Manual
- Mahindra Tractor 10 Series Front Loader ML150 Parts Manual
- Mahindra Tractor 60 Series 7060 4WD Tier III Operators Manual
- Mahindra Tractor 16 Series 3016 Gear & HST Parts Manual
- Mahindra Tractor MAX Series 25 HST Parts Manual
- Mahindra Tractor 10 Series 6010 HST Cab Parts Catalog
- Mahindra Tractor 10 Series 4010 HST Parts Manual
- Mahindra USA Backhoe Model 3715 Operators Parts Manual and Instructions
