Mahindra Tractor Max 26XLT Shuttle HST Operator Manual
Brand: Mahindra
Model:
Mahindra Max 26XLT Shuttle Tractor
Mahindra Max 26XLT HST Tractor
Date: 2017
Number Of Pages: 135 Pages
Serial Number
Safety Precautions
General Operating Safety Precaution
Intended Use
Operation Of The Tractor
Leaving The Tractor
Implements
Pto Operation
Basic Safety Requirements For Maintenance
Tractor Access
Roll Over Protective Structure (Rops)
Prior To Use
Terms And Glossary
Instruments/Controls
Operators Seat
Steering Column Tilt
Instruments And Indicators
Operating Controls
Control Levers And Pedals
Control Levers
Operating Instructions
Before Starting The Engine
Run-In Procedure
Normal Starting Procedure
Cold Temperature Operation
Stopping The Engine
Foldable Rops Frame
Towing The Tractor
How To Transport Tractor
Gear Drive Transmission (Shuttle Type Only)
Hydrostatic Drive Transmission (Hst Type Only)
Hydrostatic Speed Lock Lever (Hst Type Only)
Mechanical Front Drive (4wd)
Differential Lock
Power Take Off (Rear Pto)
Power Take Off (Mid Pto)
Power Take Off Guards
Stationary Rear Pto Work
Pto Operating Safety
Drawbar
Connecting Implement To Drawbar
Safety Chain
Field Operation
Three Point Hitch System
Hitch System Adjustments
Hitch Operation
Remote Hydraulic Control Valve (If Equipped)
Remote Hydraulics Operation
Hydraulic Block
Tires/Wheels/Spacing/Ballast
Tire And Rim Equipment
Wheel Mounting Torques
Toe-In Adjustment
Tire Size Combinations
Tractor Ballast
Lubrication And Maintenance
Periodical Inspection And Maintenance List
Oil Supply, Lubrication And Water Supply List
Oil Supply, Oil Level Check, Grease Supply, Filters Change
Hood
Service Hour Interval
Engine Lubrication
Engine Coolant
Fuel System
Air Induction System
Transmission And Hydraulic Lubrication
Hoses
Front Axle Lubrication (Mfd)
Clutch Pedal Adjustment
Brake Pedal Adjustment
Raise Stop Setting Position
General Service Information
Specifications
Battery
Fuses
Long-Term Storage
Storing The Tractor
Removing From Storage
Caution At Vehicle Washing
Troubleshooting
Specification Table
Speed Chart
Appendix Table
Consumables
Detail Index
