Mahindra Tractor Jivo 245 DI Service Manual
Brand: Mahindra
Type of Manual:
Model: Mahindra Jivo 245 DI Tractor
Number Of Pages: 87 Pages
Product Specification
Safety Notes
Maintenance Chart
Special Service Tools List
Special Service Tools Details
4 WD Front Axle
Fault Tracing
Greasing Point Location
Consumable Details
Primary Check Up
Bleeding Fuel System
Tyre Maintenance
Front Wheel Toe - In
Front Wiring Harness Layout
Rear Wiring Harness Layout
4wd Front Axle -Torque Values
Bearing & Oil Seal Position
Maintenance Schedule On 4wd Front Axle
4wd Front Axle –Oil & Grease Specification
Swivel & Side Housing Sub Assembly
Hub End -Assembly Process
Swivel Housing Sub Assembly
Side Housing Sub Assembly Lh & Rh
Swivel To Side Housing Assembly
Differential Assembly
Spline Shaft Assembly
Beam Housing Assembly
Critical Setting On 4wd Front Axle Chart
Transmission Torque Values
Bearing and Oil Seal Positions
Transmission Oil & Greassing Locations
Transmission Slidingmesh Gears And Shafts Layout
Speed Bottom Shaft Mounting
Speed Housing Fork & Rail Mounting
Speed Shifter Assembly & Mounting
Speed Driving Shaft Mounting
Cluster Gear Mounting
Input Shaft Mounting
Speed Housing And Clutch Housing Assembly
Rear Axle Carrier Assembly & Mounting Process
Bevel Pinion Shaft Sub Assembly
Bullcage & Differential Assembly
Brake Assembly Mounting
Dropbox Assembly & Mounting On Rear Housing
Speed Housing And Clutch Housing Mounting With Rear Housing
1 Speed Pto Shaft And Gears Assembly And Mounting
1 Speed Pto Operating Linkage Mounting
Range Shifter Assembly & Mounting
Reverse Idler Shaft Assembly And Mounting
Transmission Covers Mounting
Detailed Engine Specifications
Engine Torque Chart
Recommended FIP Removal Instruction
Recommended FIP Mounting Instruction
Cylinder Head Bolt Torquing Sequence
Tappet Settings
Refilling of Coolant In System
Engine Trouble Shooting
Brand: Mahindra
Type of Manual:
Safety Notes
Maintenance Chart
4 WD Front Axle
Fault Tracing
Consumable Details
Primary Check Up
Tyre Maintenance
Engine Torque Chart
Tappet Settings
- Mahindra Tractor MAX Series 28XL Operator Manual
- Mahindra AML205 FRONT END LOADER Assembly, Operator's and Parts Manual
- Mahindra Tractor 10 Series 5010 Gear Cab Parts Manual
- Mahindra Tractor Super Turbo 595 DI Sarpanch Parts Manual
- Mahindra Tractor 16 Series 3616 Gear & HST Parts Manual
- Mahindra Tractor 60 Series 8560 4WD Parts Manual
- Mahindra USA Backhoe Model 2710/3710A/3710B Operators Parts Manual and Instructions
- Mahindra Tractor 16 Series 2216 Gear & HST Parts Manual
- Mahindra Tractor 10 Series Front Loader ML150 Parts Manual
- Mahindra Tractor 60 Series 7060 4WD Tier III Operators Manual
- Mahindra Tractor 16 Series 3016 Gear & HST Parts Manual
- Mahindra Tractor MAX Series 25 HST Parts Manual
- Mahindra Tractor 10 Series 6010 HST Cab Parts Catalog
- Mahindra Tractor 10 Series 4010 HST Parts Manual
- Mahindra USA Backhoe Model 3715 Operators Parts Manual and Instructions
