Mahindra Tractor 8000 Series 8090 8100 4WD Cabin Operator Manual
Brand: Mahindra
Type of Machine: Tractor
Type of Manual: Operator Manual
Model:
Mahindra 8000 Series 8090 4WD Cabin Tractor TIER-4 FINAL
Mahindra 8000 Series 8100 4WD Cabin Tractor TIER-4 FINAL
Number Of Pages: 139 Pages
Emission Control Warranty for California
Emission Control Warranty for Federal
About This Manual
Introduction
Tractor Serial Number
General Description
Owner Assistance
Owner’s Personal Data
Safety Instructions
Safety Signs
Universal Symbols
LH and RH View of Engine
Lamps
Controls, Instruments & Operations
Instrument Cluster
Tractor Run Hour Counter
DEF Level Indicator
Service Reminder Indicator
Water In Fuel Indicator
540 RPM PTO Indicator
Air Filter Clogging Indicator
F-R Shuttle Switch Neutral Indicator
Air Pre-Heat Indicator
Fuel Level Gauge
Clutch Over Ride Indicator
High Beam Indicator
PTO Engaged Indicator
Turn Indicator
MIL Indicator
High Temperature Warning Indicator
Low Fuel Indicator
Tachometer (RPM Meter)
Low Oil Pressure Indicator
Battery Charging Indicator
SCR Tampering Indicator
Parking Brake Indicator
Diesel Exhaust Fluid (DEF) Quality & Low Level Indicator
Engine Coolant Temperature Gauge
Engine Stop Indicator
4WD Indicator
Exhaust Temperature Indicator
1000 RPM PTO Indicator
Transmission Oil Pressure Indicator
Check Engine Indicator
540/1000 PTO Operation Speed
Trip Hour Counter
Trip Hour Reset Button
Beeper Output Provision
Switches
Ignition Key Switch
Steering Column Mounted Combination Switch .
Parking light / Position lamps
Head lamp low and high beam
Turn Signal Switch
Horn
Hazard Switch
F-R Shuttle Switch
Brake Switch
Clutch Switch
Seven Pole Socket
Controls
Operator Seat
Adjusting Seat Position
Height and Weight Adjustment
Tilt Adjustment
Using Seat Belt
Fasten Seat Belt
Release Seat Belt
Hand Throttle Operation
Increasing Engine Speed
Engine Tachometer Speed
Decreasing Engine Speed
Constant Speed Setting
Foot Throttle Operation
Can Holder
Tilt Steering
Tilt Steering Adjustment
Brake
4WD Engagement Lever
Parking Brake
Differential Lock Pedal
Clutch / Inching Pedal
PTO
IPTO Clutch
Auxiliary Valve
Range Shift Lever
Speed Shift Lever
Opening the Hood
Closing the Hood
Opening the Side Panels
Closing the Side Panels
Joystick Lever
Keys
Opening Doors from Outside
Opening Doors from Inside cab
Rear View Mirrors
Rear Window
Windshield Wiper/Washer System Controls
Adding Suitable Anti-freeze Solution to
Water in Reservoir
Heater and Air Conditioning Controls
Blower Speed Control Regulator
Heater Regulator
Cooling Regulator
AC ON/OFF Switch
Fresh/Recirculation Air Selector Switch
Cab Worklight Switches
Cabin Interior Lights
Power Socket Unit
Cigarette Lighter
3 - Terminal Power Socket
USB Power Socket
Ashtray
Glove Tray
Coat Hook
Sun-visor
Audio System
PTO Speed Selection
Hydraulic System and Operation
Position Control - Operation
Quadrant Assembly
Position Control
Setting of Position Control
Draft Control - Operation
Draft Control
Setting of Draft Control
Three Point Linkage
Toplink
Draft Sensing Bracket
Telescopic Lower Links
Adjustable Lift Rods
Lateral Stabilizers
Swinging Drawbar
Adjusting Drawbar length
Using Swinging Drawbar
Attaching PTO Driven Implement
Jerrycan Weights (Optional Fitment)
Wheel Tread Adjustment
Pneumatic Tires
Adding Liquid Weight
Inflation
Care of Tires
Shipping Tractors Equipped with Pneumatic Tires
Tire Protection During Storage
Mounting Tires on the Rim
Operating Instructions
Before Starting The Tractor
Stopping The Engine
Winter Care
Block Heater
Transmission-Hydraulic System Oil
warm-up in cold-weather
Driving The Tractor
Tractor Storage
Long-Term Tractor Storage
Using the Tractor after Storage
Precautions
Cleaning The Tractor
Using High Pressure Washers
Operating The Tractor
The Tractor
Driving The Tractor
Starting off on steep slope
Tips for driving on slope
Servicing The Tractor
Operating The PTO (Power Take Off)
Transporting Tractor on a Trailer
Towing
Diesel Fuel
Do's & Dont's
Do's - for better performance
Dont's - for safe operation
Do's & Dont's for Sensors
Maintenance
Engine Cooling System
Radiator
Radiator Cap
Surge Tank
Hose Connections
Fan and Fan Belts
Draining the System
Cleaning Out Dirt and Sludge
Adding Coolant to the System
Cooling System Protection
Anti-freeze
Thresh Guard for Radiator
Thresh Guard for Condensor
Thresh Guard for Transmission Oil Cooler
Thresh Guard for Fuel Cooler
Sealings
Air Intake System
Air Cleaner
Body Air-Cleaner
Cyclopack or Built-in Pre-Cleaner
Paper Element Filter
Safety Cartridge
Dust Collector Bowl
Hose and Clamps
Emission Control System (ECS)
Positive Crankcase Ventilation (PCV) System
Exhaust Gas Recirculation (EGR) System
Diesel Oxidation Catalyst (DOC)
Selective Catalytic Reduction (SCR)
Introduction
Recommendations on DEF
Handling of DEF
Contamination / Incorrect DEF
DEF Freezing and Thawing
Filling Diesel Exhaust Fluid in DEF Tank
Draining Diesel Exhaust Fluid in DEF Tank
Cleaning Diesel Exhaust Fluid (DEF) Tank .
Clean DEF Tank with new DEF
Disposal of Diesel Exhaust Fluid (DEF)
Maintenance instruction for DeNOx System
Fuel System
Using Proper Fuel
Clean Diesel Fuel
Bleeding the CR Fuel Injection System
Fuel Tank and Fuel Pipes
Servicing The Fuel Filter
Lubrication System
Oil Level Check
Oil Change
Changing Oil Filter
Electrical System
Battery Maintenance Cleaning
Servicing
Effect of Low Temperatures
Alternator
Charging Circuit
Starter Motor Removal
Air Conditioning System (Cabin)
Cab Air Conditioning System Safety
Switching ON the Air Conditioning System
Adjustment
Switching OFF the Air Conditioning System
Tips on using Air Conditioning
Maintaining the Air Conditioning System
Heating Mode
Cleaning the Cab Air Filters
Hydraulics and Transmission
Adding Hydraulic and Transmission Oil
Hydraulic Suction Filter
Hydraulics Strainer
Transmission Strainer
Transmission Oil Drain
Power Steering
Front Axle
Front Axle - Front Wheel "Toe-in" Check
Front Axle Oil Filling / Draining / Level Checking
Hub Housing
Check and Adjust Brake Pedal Free Play
Parking Brake Adjustment / Settings
Fuse Box
Lubricants
General
Lubricant Storage
Alternate Lubricants
Mixing of Lubricants
Lubricantion Oil
Engine Oil
Recommended Oils
Transmission, Hydraulics and
Oil Immersed Brakes
Chassis Lubricant (CL)
Front Axle
Oil Specifications Chart
Special Bolt Torques
Specifications - 8090 4WD
Specifications - 8100 4WD
Trouble Shooting
Precautions for CRDI Engines
Engine
Hydraulics
Brakes
Transmission
Rear Wheels
Electricals
Power Steering
Cabin
Tractor History Card
Service Record
Part Replacement Record
Daily Operating Log
Tractor Storage Precautions
Lubrication and Greasing Chart
Routine Service Schedule
Brand: Mahindra
Model:
About This Manual
Introduction
General Description
Owner Assistance
Safety Instructions
Safety Signs
Universal Symbols
Lamps
Instrument Cluster
DEF Level Indicator
Fuel Level Gauge
High Beam Indicator
Turn Indicator
MIL Indicator
Low Fuel Indicator
4WD Indicator
Trip Hour Counter
Switches
Ignition Key Switch
Turn Signal Switch
Horn
Hazard Switch
F-R Shuttle Switch
Brake Switch
Clutch Switch
Seven Pole Socket
Controls
Operator Seat
Tilt Adjustment
Using Seat Belt
Fasten Seat Belt
Release Seat Belt
Can Holder
Tilt Steering
Brake
Parking Brake
PTO
IPTO Clutch
Auxiliary Valve
Range Shift Lever
Speed Shift Lever
Opening the Hood
Closing the Hood
Joystick Lever
Keys
Rear View Mirrors
Rear Window
Water in Reservoir
Heater Regulator
Cooling Regulator
AC ON/OFF Switch
Power Socket Unit
Cigarette Lighter
USB Power Socket
Ashtray
Glove Tray
Coat Hook
Sun-visor
Audio System
PTO Speed Selection
Quadrant Assembly
Position Control
Draft Control
Three Point Linkage
Toplink
Lateral Stabilizers
Swinging Drawbar
Pneumatic Tires
Inflation
Care of Tires
Stopping The Engine
Winter Care
Block Heater
Driving The Tractor
Tractor Storage
Precautions
The Tractor
Driving The Tractor
Towing
Diesel Fuel
Do's & Dont's
Maintenance
Radiator
Radiator Cap
Surge Tank
Hose Connections
Fan and Fan Belts
Draining the System
Anti-freeze
Sealings
Air Intake System
Air Cleaner
Body Air-Cleaner
Safety Cartridge
Dust Collector Bowl
Hose and Clamps
Introduction
Handling of DEF
Fuel System
Using Proper Fuel
Clean Diesel Fuel
Lubrication System
Oil Level Check
Oil Change
Changing Oil Filter
Electrical System
Servicing
Alternator
Charging Circuit
Adjustment
Heating Mode
Hydraulics Strainer
Power Steering
Front Axle
Hub Housing
Fuse Box
Lubricants
General
Lubricant Storage
Lubricantion Oil
Engine Oil
Recommended Oils
Oil Immersed Brakes
Front Axle
Trouble Shooting
Engine
Hydraulics
Brakes
Transmission
Rear Wheels
Electricals
Power Steering
Cabin
Service Record
Daily Operating Log
- Mahindra Tractor MAX Series 28XL Operator Manual
- Mahindra AML205 FRONT END LOADER Assembly, Operator's and Parts Manual
- Mahindra Tractor 10 Series 5010 Gear Cab Parts Manual
- Mahindra Tractor Super Turbo 595 DI Sarpanch Parts Manual
- Mahindra Tractor 16 Series 3616 Gear & HST Parts Manual
- Mahindra Tractor 60 Series 8560 4WD Parts Manual
- Mahindra USA Backhoe Model 2710/3710A/3710B Operators Parts Manual and Instructions
- Mahindra Tractor 16 Series 2216 Gear & HST Parts Manual
- Mahindra Tractor 10 Series Front Loader ML150 Parts Manual
- Mahindra Tractor 60 Series 7060 4WD Tier III Operators Manual
- Mahindra Tractor 16 Series 3016 Gear & HST Parts Manual
- Mahindra Tractor MAX Series 25 HST Parts Manual
- Mahindra Tractor 10 Series 6010 HST Cab Parts Catalog
- Mahindra Tractor 10 Series 4010 HST Parts Manual
- Mahindra USA Backhoe Model 3715 Operators Parts Manual and Instructions
