Mahindra Tractor 7095 4WD Cabin Operator Manual
Brand: Mahindra
Model: Mahindra 7095 4WD Cabin Tractor TIER-4 FINAL
Number Of Pages: 136 Pages
Emission Control Warranty for California
Emission Control Warranty for Federal
About This Manual
Introduction
Tractor
Tractor Serial Number
General Description
Owner Assistance
Owner’s Personal Data
Safety Instructions
Safety Signs
Universal Symbols
LH & RH View of Engine
Lamps
Controls, Instruments & Operations
Instrument Cluster
Tractor Run Hour Counter
DEF Level Indicator
Service Reminder Indicator
Water In Fuel Indicator
540 RPM PTO Indicator
Air Filter Clogging Indicator
F-R Shuttle Switch Neutral Indicator
Air Pre-Heat Indicator
Fuel Level Gauge
Clutch Over Ride Indicator
High Beam Indicator
PTO Engaged Indicator
Turn Indicator
MIL Indicator
High Temperature Warning Indicator
Low Fuel Indicator
Tachometer (RPM Meter)
Low Oil Pressure Indicator
Battery Charging Indicator
SCR Tampering Indicator
Parking Brake Indicator
Diesel Exhaust Fluid (DEF) Quality &
Low Level Indicator
Engine Coolant Temperature Gauge
Engine Stop Indicator
4WD Indicator
Exhaust Temperature Indicator
1000 RPM PTO Indicator
Transmission Oil Pressure Indicator
Check Engine Indicator
540 PTO Operation Speed
540E PTO Operation Speed
Trip Hour Counter
Trip Hour Reset Button
Beeper Output Provision
Switches
Ignition Key Switch
Steering Column Mounted Combination Switch
Parking Light / Position Lamps
Head Lamp Low and High Beam
Turn Signal Switch
Horn
PTO ON/OFF Switch
Seven Pole Socket
Hazard Switch
F-R Shuttle Switch
Brake Switch
Clutch Switch
Controls
Operator Seat
Adjusting Seat Position
Height and Weight Adjustment
Tilt Adjustment
Using Seat Belt
Fasten Seat Belt
Release Seat Belt
Tilt Steering
Tilt Steering Adjustment
4WD Engagement Lever
Hand Throttle Operation
Increasing Engine Speed
Engine Tachometer Speeds
Decreasing Engine Speed
Constant Speed Setting
Foot Throttle Operation
Can Holder
Brake
Differential Lock Pedal
Clutch / Inching Pedal
PTO
Auxiliary Valve
Range Shift Lever
Speed Shift Lever
Opening the Hood
Closing the Hood
Opening the Side Panels
Closing the Side Panels
Joystick Lever
Keys
Opening Doors from Outside
Opening Doors from Inside
Rear View Mirrors
Rear Window
Windshield Wiper/Washer System Controls
Adding Suitable Anti-freeze Solution to
Water in Reservoir
Heater and Air Conditioning Controls
Blower Speed Control Regulator
Heater Regulator
Cooling Regulator
AC ON/OFF Switch
Fresh/Recirculation Air Selector Switch
Cab Worklight Switches
Cabin Interior Lights
Power Socket Unit
Cigarette Lighter
3 - Terminal Power Socket
USB Power Socket
Ashtray
Glove Tray
Coat Hook
Sun-visor
Audio System
Speakers
Hydraulic System & Operation
Position Control - Operation
Quadrant Assembly
Position Control
Setting of Position Control
Draft Control - Operation
Draft Control
Setting of Draft Control
Three Point Linkage
Top Link
Top Link Crank
Telescopic Lower Links
Adjustable Lift Rods
Stabilizers
Swinging Drawbar
Adjusting Drawbar Length
Using Swinging Drawbar
Jerrycan Weights (Optional Fitment)
Wheel Tread Adjustment
Pneumatic Tires
Adding Liquid Weight
Inflation
Exceptions (Rear Tires only)
Care of Tires
Shipping Tractors Equipped with Pneumatic Tires
Tire Protection during Storage
Mounting Tires on the Rim
Operating Instructions
Before Starting the Tractor
Stopping the Engine
Winter Care
Block Heater
Transmission-Hydraulic System Oil warm-up in cold weather
Driving the Tractor
Tractor Storage
Long-Term Tractor Storage
Using the Tractor After Storage
Precautions
Cleaning the Tractor
Using High Pressure Washers
Operating the Tractor
The Tractor
Starting off on steep slope
Tips for driving on slope
Servicing the Tractor
Operating the PTO (Power Take Off)
Transporting Tractor on a Trailer
Towing
Diesel Fuel
Do's & Dont's
Do's - for better performance
Dont's - for safe operation
Do's & Dont's for Sensors
Maintenance
Radiator Cap
Surge Tank
Thermostat
Hose Connections
Fan & Fan Belts
Draining the System
Cleaning out Dirt and Sludge
Adding Coolant to the System
Cooling System Protection
Thresh Guard for Radiator
Thresh Guard for Condensor
Thresh Guard for Fuel Cooler
Sealings
Air Intake System
Air Cleaner
Body Air-Cleaner
Cyclopack or built-in Pre-Cleaner
Paper Element Filter
Safety Cartridge
Dust Collector Bowl
Hose and Clamps
Emission Control System (ECS)
Positive Crankcase Ventilation (PCV) System
Exhaust Gas Recirculation (EGR) System
Diesel Oxidation Catalyst (DOC)
Selective Catalytic Reduction (SCR)
Recommendations on DEF
Handling of DEF
Contamination / incorrect DEF
DEF Freezing and Thawing
Filling Diesel Exhaust Fluid in DEF Tank
Draining Diesel Exhaust Fluid in DEF Tank
Cleaning Diesel Exhaust Fluid (DEF) Tank
Clean DEF tank with new DEF
Disposal of Diesel Exhaust Fluid (DEF)
Maintenance instruction for
DeNOx System
DEF Long Storage Conditions
DEF Shelf Life - Replacement recommendations during Long storage
Fuel System
Using Proper Fuel
Clean Diesel Fuel
Bleeding the CR Fuel Injection System
Fuel Tank and Fuel Pipes
Servicing the Fuel Filter
Lubrication System
Oil Level Check
Oil Change
Engine Oil Filter
Changing Oil Filter
Turbocharger
Battery Maintenance Cleaning
Servicing
Effect of Low Temperatures
Charging Circuit
Starter Motor Removal
Air Conditioning System (Cabin)
Cab Air Conditioing System Safety
Switching On The Air Conditioing System
Adjustment
Switching Off The Air Conditioing System
Tips on Using Air-Conditioning
Maintaining the Air Conditioning System
Heating Mode
Clean the Cab Air Filters
Hydraulic & Transmission
Adding Hydraulic & Transmission Oil
Hydraulic & Transmission Suction Oil Filter
Hydraulic & Transmission Strainer
Transmission Oil Drain
Power Steering
Front Axle
Axle Oil Change
Reduction Gear Oil Change
Front Axle - Front Wheel "Toe-in" Check
Check & Adjust Brake Pedal Free Play
Parking Brake Adjustment / Settings
Fuse Box
4-Way Fuse Box
2-Way Fuse Box
B-Post Fuse Box
Lubricants
General
Lubricant Storage
Alternate Lubricants
Mixing of Lubricants
Lubricantion Oil
Engine Oil
Recommended Oils
Transmission, Hydraulics & Oil Immersed Brakes
Chassis Lubricant (CL)
Oil Specifications Chart
Special Bolt Torques
Specifications - 7095 4WD CABIN
Trouble Shooting
Precautions for CRDI Engines
Hydraulics
Brakes
Electricals
Cabin
Tractor History Card
Service Record
Part Replacement Record
Daily Operating Log
Tractor Storage Precautions
Lubrication and Greasing Chart
Routine Service Schedule
Brand: Mahindra
About This Manual
Introduction
Tractor
General Description
Owner Assistance
Safety Instructions
Safety Signs
Universal Symbols
Lamps
Instrument Cluster
DEF Level Indicator
Fuel Level Gauge
High Beam Indicator
Turn Indicator
MIL Indicator
Low Fuel Indicator
Low Level Indicator
4WD Indicator
Trip Hour Counter
Switches
Ignition Key Switch
Turn Signal Switch
Horn
PTO ON/OFF Switch
Seven Pole Socket
Hazard Switch
F-R Shuttle Switch
Brake Switch
Clutch Switch
Controls
Operator Seat
Tilt Adjustment
Using Seat Belt
Fasten Seat Belt
Release Seat Belt
Tilt Steering
Can Holder
Brake
PTO
Auxiliary Valve
Range Shift Lever
Speed Shift Lever
Opening the Hood
Closing the Hood
Joystick Lever
Keys
Rear View Mirrors
Rear Window
Water in Reservoir
Heater Regulator
Cooling Regulator
AC ON/OFF Switch
Power Socket Unit
Cigarette Lighter
USB Power Socket
Ashtray
Glove Tray
Coat Hook
Sun-visor
Audio System
Speakers
Quadrant Assembly
Position Control
Draft Control
Three Point Linkage
Top Link
Top Link Crank
Stabilizers
Swinging Drawbar
Pneumatic Tires
Inflation
Care of Tires
Stopping the Engine
Winter Care
Block Heater
Driving the Tractor
Tractor Storage
Precautions
The Tractor
Towing
Diesel Fuel
Do's & Dont's
Maintenance
Radiator Cap
Surge Tank
Thermostat
Hose Connections
Fan & Fan Belts
Draining the System
Sealings
Air Intake System
Air Cleaner
Body Air-Cleaner
Safety Cartridge
Dust Collector Bowl
Hose and Clamps
Handling of DEF
DeNOx System
Fuel System
Using Proper Fuel
Clean Diesel Fuel
Lubrication System
Oil Level Check
Oil Change
Engine Oil Filter
Changing Oil Filter
Turbocharger
Servicing
Charging Circuit
Adjustment
Heating Mode
Power Steering
Front Axle
Axle Oil Change
Fuse Box
4-Way Fuse Box
2-Way Fuse Box
B-Post Fuse Box
Lubricants
General
Lubricant Storage
Lubricantion Oil
Engine Oil
Recommended Oils
Trouble Shooting
Hydraulics
Brakes
Electricals
Cabin
Service Record
Daily Operating Log
- Mahindra Tractor MAX Series 28XL Operator Manual
- Mahindra AML205 FRONT END LOADER Assembly, Operator's and Parts Manual
- Mahindra Tractor 10 Series 5010 Gear Cab Parts Manual
- Mahindra Tractor Super Turbo 595 DI Sarpanch Parts Manual
- Mahindra Tractor 16 Series 3616 Gear & HST Parts Manual
- Mahindra Tractor 60 Series 8560 4WD Parts Manual
- Mahindra USA Backhoe Model 2710/3710A/3710B Operators Parts Manual and Instructions
- Mahindra Tractor 16 Series 2216 Gear & HST Parts Manual
- Mahindra Tractor 10 Series Front Loader ML150 Parts Manual
- Mahindra Tractor 60 Series 7060 4WD Tier III Operators Manual
- Mahindra Tractor 16 Series 3016 Gear & HST Parts Manual
- Mahindra Tractor MAX Series 25 HST Parts Manual
- Mahindra Tractor 10 Series 6010 HST Cab Parts Catalog
- Mahindra Tractor 10 Series 4010 HST Parts Manual
- Mahindra USA Backhoe Model 3715 Operators Parts Manual and Instructions
