Driver
98
288,393
Mahindra Tractor 6065 6075 2WD 4WD Operator Manual
Brand: Mahindra
Model:
Mahindra 6065 2WD Tractor Open Station
Mahindra 6065 4WD Tractor Open Station
Mahindra 6075 4WD Tractor Open Station
Mahindra 6075 2WD Tractor Open Station
Number Of Pages: 116 Pages
Emission Control Warranty for California
Emission Control Warranty for Federal
About This Manual
Introduction
Tractor
Tractor Serial Number
General Description
Owner Assistance
Owner’s Personal Data
Roll Over Protective Structure (ROPS)
Safety Instructions
Safety Signs
Universal Symbols
LH & RH View of Engine
Lamps
Controls, Instruments & Operations
Instrument Cluster
Engine Coolant Temperature Warning Indicator
Air Filter Clogging Indicator
Check Engine Indicator
High Beam Indicator
Clutch Over Ride Indicator
F-R Shuttle Neutral Indicator
Fuel Gauge
4WD Indicator
Turn Indicator
Tachometer
Trip Hour Counter
Tractor Run Hour Counter
Trip Hour Reset Button
Water In Fuel Indicator
Service Reminder Indicator
Coolant Temperature Gauge
Cold Start Device Indicator
PTO Indicator
Parking Brake Indicator
MIL Indicator
Battery Charging Indicator
Low Oil Pressure Indicator
Beeper Output Provision
Switches
Ignition Key Switch
Steering Column Mounted Combination Switch . 38
Light Switch
Dipper Switch
Turn Signal Switch
Horn
Plough Lamp Switch
Hazard Switch
Brake Switch
Forward Reverse Switch
PTO AUTO/MANUAL Switch
PTO ON/OFF Switch
Seven Pole Socket
Mobile Charger Socket
Fuse Box
Controls
Operator Seat
Adjusting Seat Position
Weight Adjustment
Tilt Adjustment
Using Seat Belt
Fasten Seat Belt
Release Seat Belt
Tilt Steering
Hand Throttle Operation
Increasing Engine Speed
Engine Tachometer Speeds
Decreasing Engine Speed
Constant Speed Setting
Foot Throttle Operation
4WD Engagement Lever
Brake
Differential Lock Pedal
Clutch / Inching Pedal
PTO
Range Shift Lever
F-R Shuttle Shift Lever
Speed Shift Lever
Auxiliary Valve
Opening the Hood
Closing the Hood
Hydraulic System & Operation
Position Control - Operation
Quadrant Assembly
Position Control
Position Control Lever Setting
Draft Control - Operation
Draft Control
Setting the Draft Control
Three Point Linkage
Top Link
Draft Sensing Bracket
Telescopic Lower Links
Adjustable Lift Rods
Stabilizers
Swinging Drawbar
Using Swinging Drawbar
Attaching PTO Driven Implement
Jerrycan Weights
Wheel Tread Adjustment
Pneumatic Tires
Adding Liquid Weight
Inflation
Exceptions (Rear Tires only)
Care of Tires
Shipping Tractors Equipped with
Pneumatic Tires
Tire Protection during Storage
Mounting Tires on the Rim
Operating Instructions
Before Starting The Tractor
Starting the Tractor
Stopping the Engine
Cold Starting Aid
Glow Plug
Driving the Tractor
Tractor Storage
Long-Term Tractor Storage
Using the Tractor After Storage
Precautions
Cleaning the Tractor
Using High Pressure Washers
Operating the Tractor
The Tractor
Servicing the Tractor
Operating the PTO (Power Take Off)
ROPS
Transporting Tractor on a Trailer
Towing
Diesel Fuel
Do’s & Dont’s
Maintenance
Radiator Cap
Surge Tank
Thermostat
Hose Connections
Fan & Fan Belts
Belt Adjustment
Belt Removal
Belt Replacement
Draining the System
Cleaning out Dirt and Sludge
Adding Coolant to the System
Cooling System Protection
Thresh Guard
Air Intake System
Air Cleaner
Body Air-Cleaner
Cyclopack or built-in Pre-Cleaner
Paper Element Filter
Safety Cartridge
Dust Collector Bowl
Hose and Clamps
Emission Control System (ECS)
Positive Crankcase Ventilation (PCV) System
Removing the Oil Separator
Assembly the Oil Separator
Exhaust Gas Recirculation (EGR) System
Diesel Oxidation Catalyst (DOC)
Under-Hood Muffler (UHM)
Fuel System
Using Proper Fuel
Clean Diesel Fuel
Bleeding the Fuel Filter
Bleeding the Fuel Injection Pump
Fuel Tank and Fuel Pipes
Servicing the Fuel Filter
Lubrication System
Oil Level Check
Oil Change
Engine Oil Filter
Changing Spin On Filter
Turbocharger
Battery Maintenance Cleaning
Servicing
Effect of Low Temperatures
Charging Circuit
Starter Motor Removal
Front Axle & Power Steering (2WD)
Front Axle - Front Wheel "Toe-in" Check
Tips for maintaining the power steering system . 84
Front Axle (4WD)
Axle Oil Change
Reduction Gear Oil Change
Hydraulic & Transmission
Adding Hydraulic and Transmission Oil
Hydraulic and Transmission Suction Oil Filter
Hydraulic and Transmission Strainer
Transmission Oil Drain
Check & Adjust Brake Pedal Free Play
Head Lamp Adjustment
Aiming Head Lamps
Lubricants
General
Lubricant Storage
Alternate and Synthetic Lubricants
Diesel Engine Lubricating Oil
Mixing of Lubricants
Engine Oil
Recommended Oil
Transmission, Hydraulics and
Oil Immersed Brakes
Chassis Lubricant (CL)
Front Axle
Oil Specifications Chart
Warm-up procedure-Transmission-Hydraulic Oil
Special Bolt Torques
Specifications - 6065 2WD
Specifications - 6065 4WD
Specifications - 6075 4WD
Trouble Shooting
Precautions for CRDI Engines
Turbocharger
Hydraulics
Brakes
Electricals
Power Steering
Tractor History Card
Service Record
Part Replacement Record
Daily Operating Log
Tractor Storage Precautions
Lubrication & Greasing Chart
Routine Service Schedule
P65 Sticker-California
