Mahindra Tractor 4565 2WD Operator Manual
Brand: Mahindra
Model: Mahindra 4565 2WD Tractor TIER-4 FINAL
Number Of Pages: 107 Pages
Emission Control Warranty for California
Emission Control Warranty for Federal
About This Manual
Introduction
General Description
Owner Assistance
Owner’s Personal Data
Roll Over Protective Structure (ROPS)
Safety Instructions
Safety Signs
Universal Symbols
LH & RH View of Engine
Lamps
Controls, Instruments & Operations
Instrument Cluster
RPM Meter
PTO 540 rpm Mark
Hour Counter
Fuel Gauge
Low Oil Pressure Indicator
Engine Coolant Temperature Gauge
Battery Charging Indicator
High Beam Indicator
Parking Brake Indicator
LH / RH Turn Signal Indicator
Heater Indicator
Air Filter Clog Indicator
Water In Fuel Indicator
CHK ENG (Check Engine) Indicator
MIL (Malfunction) Indicator
Switches
Rotary Light Switch
Combination Switch
Horn Button
Plow Lamp Rotary Switch
Key
Key Switch
Stopping the Engine
Hazard Switch
Fuse Box
Controls
Adjusting Seat Position
Weight Adjustment
Seat Belt
Hand Throttle Lever
Increasing Engine Speed
Decreasing Engine Speed
Constant Speed Setting
Foot Throttle Operation
Dual Clutch
Hi-Low Range Selection Lever
Gear Shifter Lever
Brakes
Parking Brake Lever
Differential Lock Pedal
Power Take Off
Opening the Hood
Closing the Hood
Transmission and PTO Neutral Safety
PTO Neutral Switch
Transmission Neutral Switch
Hydraulic System & Operation
Full Live "Vary-Touch" Hydraulic System
Position Control Lever
Draft Control Lever
Isolating Valve
Position Control - Operation
Draft Control - Operation
Three Point Linkage
Toplink
Draft Sensing Bracket
Lower Links
Lower Link Hitch Point
Adjustable Lift Rods
Lateral Strut Stabilizer
Attaching Implement
Swinging Drawbar
Using Swinging Drawbar
Attaching PTO Driven Implement
Jerrycan Weights (Optional Fitment)
Wheel Weights (Optional Fitment)
Adjustment of Front Wheel Tread
Adjustment of Rear Wheel Tread
Pneumatic Tires
Adding Liquid Weight
Inflation
Care of Tires
Shipping Tractors Equipped with
Pneumatic Tires
Tire Protection during Storage
Mounting Tires on the Rim
Operating Instructions
Before Starting the Tractor
Starting the tractor
Cold Starting Aid
Glow Plug
Driving the Tractor
Precautions
Operating the Tractor
The Tractor
Servicing the Tractor
Operating the PTO (Power Take Off)
ROPS
Transporting Tractor on a Trailer
Towing
Diesel Fuel
Do's and Dont's
Maintenance
Radiator Cap
Surge Tank
Thermostat
Hose Connections
Fan & Fan Belts
Draining the System
Cleaning out Dirt and Sludge
Adding Coolant to the System
Cooling System Protection
Engine Valve Clearance
Air Intake System
Air Cleaner
Body Air Cleaner
Cyclopack or Built-in Pre-Cleaner
Paper Element Filter
Safety Cartridge
Dust Collector Bowl
Service Instructions for Air Cleaner
Emission Control System
Fuel System
Clean Diesel Fuel
Bleeding the Fuel Filter
Bleeding the Fuel Injection Pump
Fuel Tank and Fuel Pipes
Tamper Proofing
Servicing the Fuel Filter
Lubrication System
Oil Level Check
Engine Oil Filter
Changing Spin On Filter
Oil Change
Turbocharger
Battery Maintenance Cleaning
Charging Circuit
Starter Motor Removal
Front Axle
Front Wheel “Toe-in” Check
Front Wheel Check
Greasing the Front Wheels
Preloading Bearings
Transmission Oil Level
Transmission Oil Drain
Hydraulic Suction Filter
Transmission Strainer
Clutch Pedal
Clutch Pedal Adjustment
Clutch Pedal Free Play
Brake Pedal
Disc Brakes
Brake Pedal Adjustment
Brake Pedal Free Play
Special Bolt Torque
Head Lamp Adjustment
Aiming Head Lamps
Lubrication Points
Lubricants
General
Lubricant Storage
Alternate and Synthetic Lubricants
Diesel Engine Lubricating Oil
Mixing of Lubricants
Lubrication Oil
Engine Oil
Selecting the Viscosity of Engine Oil (EO)
Transmission, Hydraulic & Steering Oil (GL)
Chassis Lubricant (CL)
Lubricant Recommendation Chart.
Specifications
Troubleshooting
Hydraulics
Electricals
Power Steering
Tractor History Card
Service Record
Part Replacement Record
Daily Operating Log
Tractor Storage Precautions
Routine Service Schedule
Electrical Circuit Layout
Brand: Mahindra
About This Manual
Introduction
General Description
Owner Assistance
Safety Instructions
Safety Signs
Universal Symbols
Lamps
Instrument Cluster
RPM Meter
PTO 540 rpm Mark
Hour Counter
Fuel Gauge
High Beam Indicator
Heater Indicator
Switches
Rotary Light Switch
Combination Switch
Horn Button
Key
Key Switch
Stopping the Engine
Hazard Switch
Fuse Box
Controls
Weight Adjustment
Seat Belt
Hand Throttle Lever
Dual Clutch
Gear Shifter Lever
Brakes
Parking Brake Lever
Power Take Off
Opening the Hood
Closing the Hood
PTO Neutral Switch
Draft Control Lever
Isolating Valve
Three Point Linkage
Toplink
Lower Links
Attaching Implement
Swinging Drawbar
Pneumatic Tires
Inflation
Care of Tires
Pneumatic Tires
Cold Starting Aid
Glow Plug
Driving the Tractor
Precautions
The Tractor
ROPS
Towing
Diesel Fuel
Do's and Dont's
Maintenance
Radiator Cap
Surge Tank
Thermostat
Hose Connections
Fan & Fan Belts
Draining the System
Air Intake System
Air Cleaner
Body Air Cleaner
Safety Cartridge
Dust Collector Bowl
Fuel System
Clean Diesel Fuel
Tamper Proofing
Lubrication System
Oil Level Check
Engine Oil Filter
Oil Change
Turbocharger
Charging Circuit
Front Axle
Front Wheel Check
Preloading Bearings
Clutch Pedal
Brake Pedal
Disc Brakes
Special Bolt Torque
Aiming Head Lamps
Lubrication Points
Lubricants
General
Lubricant Storage
Lubrication Oil
Engine Oil
Specifications
Troubleshooting
Hydraulics
Electricals
Power Steering
Service Record
Daily Operating Log
- Mahindra Tractor MAX Series 28XL Operator Manual
- Mahindra AML205 FRONT END LOADER Assembly, Operator's and Parts Manual
- Mahindra Tractor 10 Series 5010 Gear Cab Parts Manual
- Mahindra Tractor Super Turbo 595 DI Sarpanch Parts Manual
- Mahindra Tractor 16 Series 3616 Gear & HST Parts Manual
- Mahindra Tractor 60 Series 8560 4WD Parts Manual
- Mahindra USA Backhoe Model 2710/3710A/3710B Operators Parts Manual and Instructions
- Mahindra Tractor 16 Series 2216 Gear & HST Parts Manual
- Mahindra Tractor 10 Series Front Loader ML150 Parts Manual
- Mahindra Tractor 60 Series 7060 4WD Tier III Operators Manual
- Mahindra Tractor 16 Series 3016 Gear & HST Parts Manual
- Mahindra Tractor MAX Series 25 HST Parts Manual
- Mahindra Tractor 10 Series 6010 HST Cab Parts Catalog
- Mahindra Tractor 10 Series 4010 HST Parts Manual
- Mahindra USA Backhoe Model 3715 Operators Parts Manual and Instructions
