Mahindra Tractor 4540 4550 2WD Operator Manual
Brand: Mahindra
Model:
Mahindra 4540 2WD Tractor TIER-4 FINAL mCRD
Mahindra 4550 2WD Tractor TIER-4 FINAL mCRD
Number Of Pages: 110 Pages
Emission Control Warranty for California
Emission Control Warranty for Federal
About This Manual
Introduction
General Description
Owner Assistance
Owner’s Personal Data
Roll Over Protective Structure (ROPS)
Safety Instructions
Safety Signs
Universal Symbols
LH & RH View of Engine
Lamps
Controls, Instruments and Operations
Instrument Cluster
RPM Meter
PTO 540 rpm Mark
Hour Counter
Fuel Gauge
Low Oil Pressure Indicator
Engine Coolant Temperature Gauge
Battery Charging Indicator
High Beam Indicator
Parking Brake Indicator
LH / RH Turn Signal Indicator
Heater Indicator
Air Filter Clog Indicator
Water In Fuel Indicator
CHK ENG (Check Engine) Indicator
MIL (Malfunction) Indicator
Switches
Rotary Light Switch
Combination Switch
Horn Button
Work Lamp Rotary Switch
Key
Key Switch
Stopping the Engine
Hazard Switch
Fuse Box
Controls
Adjusting Seat Position
Weight Adjustment
Seat Belt
Cold Starting Aid
Hand Throttle Lever
Increasing Engine Speed
Decreasing Engine Speed
Constant Speed Setting
Foot Throttle Operation
Clutch Operation
High-Low Range Selection Lever
Gear Shifter Lever
Brakes
Parking Brake Lever
Differential Lock Pedal
Power Take Off
Opening the Hood
Closing the Hood
Transmission and PTO Neutral Safety
PTO Neutral Switch
Transmission Neutral Switch
Hydraulic System & Operation
Position Control - Operation
Draft Control - Operation
Three Point Linkage
Toplink
Draft Sensing Bracket
Lower Links
Lower Link Hitch Point
Adjustable Lift Rod
Lateral Strut Stabilizer
Attaching Implement
Swinging Drawbar
Jerrycan Weights (Optional Fitment)
Wheel Weights (Optional Fitment)
Adjustment of Front Wheel Tread
Adjustment of Rear Wheel Tread
Pneumatic Tires
Adding Liquid Weight
Inflation
Exceptions (Rear Tires only)
Care of Tires
Shipping Tractors Equipped with
Pneumatic Tires
Tire Protection during Storage
Mounting Tires on the Rim
Operating Instructions
Before Starting the Tractor
Driving the Tractor
Precautions
Operating the Tractor
The Tractor
Servicing the Tractor
Operating the PTO (Power Take Off)
ROPS
Transporting Tractor on a Trailer
Towing
Diesel Fuel
Do's and Dont's
Maintenance
Radiator Cap
Recovery Bottle
Thermostat
Block Heater
Hose Connections
Fan and Fan Belts
Draining the System
Cleaning out Dirt and Sludge
Adding Coolant to the System
Cooling System Protection
Engine Valve Clearance
Air Intake System
Air Cleaner
Body Air-Cleaner
Cyclopack or built-in Pre-Cleaner
Paper Element Filter
Safety Cartridge
Dust Collector Bowl
Service Instructions for Air Cleaner
Fuel System
Bleeding the Diesel Fuel System
Fuel Tank and Fuel Pipes
Tamper Proofing
Servicing Fuel Filter
Emission Control System (ECS)
Lubrication System
Oil Level Check
Engine Oil Filter
Changing Spin On Filter
Oil Change
Battery Maintenance Cleaning
Charging Circuit
Starter Motor Removal
Power Steering
Tips for Maintaining
the Power Steering System
Front Axle
Front Axle - Front Wheel "Toe-in" Check
Front Wheel Check
Greasing the Front Wheels
Preloading Bearings
Transmission Oil Level
Transmission Oil Drain
Hydraulic Suction Filter
Transmission Strainer
Clutch Pedal
Clutch Pedal Adjustment
Clutch Pedal Free Play
Brake Pedal
Disc Brakes
Brake Pedal Adjustment
Brake Pedal Free Play
Special Bolt Torque
Head Lamp Adjustment
Lubricants
General
Lubricant Storage
Alternate and Synthetic Lubricants
Diesel Engine Lubricating Oil
Mixing of Lubricants
Lubrication Oil
Engine Oil
Selecting the Viscosity of Engine Oil (EO)
Transmission, Hydraulic and
Steering Oil (GL)
Chassis Lubricant (CL)
Lubricant Recommendation Chart
Specifications - 4540 2WD
Specifications - 4550 2WD
Troubleshooting
Precautions for CRDI Engines
Hydraulics
Electricals
Tractor History Card
Service Record
Part Replacement Record
Daily Operating Log
Tractor Storage Precautions
Lubrication and Greasing Chart
Routine Service Schedule
Wiring Diagram
Brand: Mahindra
Model:
About This Manual
Introduction
General Description
Owner Assistance
Safety Instructions
Safety Signs
Universal Symbols
Lamps
Instrument Cluster
RPM Meter
PTO 540 rpm Mark
Hour Counter
Fuel Gauge
High Beam Indicator
Heater Indicator
Switches
Rotary Light Switch
Combination Switch
Horn Button
Key
Key Switch
Stopping the Engine
Hazard Switch
Fuse Box
Controls
Weight Adjustment
Seat Belt
Cold Starting Aid
Hand Throttle Lever
Clutch Operation
Gear Shifter Lever
Brakes
Parking Brake Lever
Power Take Off
Opening the Hood
Closing the Hood
PTO Neutral Switch
Three Point Linkage
Toplink
Lower Links
Adjustable Lift Rod
Attaching Implement
Swinging Drawbar
Pneumatic Tires
Inflation
Care of Tires
Pneumatic Tires
Driving the Tractor
Precautions
The Tractor
ROPS
Towing
Diesel Fuel
Do's and Dont's
Maintenance
Radiator Cap
Recovery Bottle
Thermostat
Block Heater
Hose Connections
Fan and Fan Belts
Draining the System
Air Intake System
Air Cleaner
Body Air-Cleaner
Safety Cartridge
Dust Collector Bowl
Fuel System
Tamper Proofing
Lubrication System
Oil Level Check
Engine Oil Filter
Oil Change
Charging Circuit
Power Steering
Front Axle
Front Wheel Check
Preloading Bearings
Clutch Pedal
Brake Pedal
Disc Brakes
Special Bolt Torque
Lubricants
General
Lubricant Storage
Lubrication Oil
Engine Oil
Steering Oil (GL)
Troubleshooting
Hydraulics
Electricals
Service Record
Daily Operating Log
Wiring Diagram
- Mahindra Tractor MAX Series 28XL Operator Manual
- Mahindra AML205 FRONT END LOADER Assembly, Operator's and Parts Manual
- Mahindra Tractor 10 Series 5010 Gear Cab Parts Manual
- Mahindra Tractor Super Turbo 595 DI Sarpanch Parts Manual
- Mahindra Tractor 16 Series 3616 Gear & HST Parts Manual
- Mahindra Tractor 60 Series 8560 4WD Parts Manual
- Mahindra USA Backhoe Model 2710/3710A/3710B Operators Parts Manual and Instructions
- Mahindra Tractor 16 Series 2216 Gear & HST Parts Manual
- Mahindra Tractor 10 Series Front Loader ML150 Parts Manual
- Mahindra Tractor 60 Series 7060 4WD Tier III Operators Manual
- Mahindra Tractor 16 Series 3016 Gear & HST Parts Manual
- Mahindra Tractor MAX Series 25 HST Parts Manual
- Mahindra Tractor 10 Series 6010 HST Cab Parts Catalog
- Mahindra Tractor 10 Series 4010 HST Parts Manual
- Mahindra USA Backhoe Model 3715 Operators Parts Manual and Instructions
