Mahindra Tractor 3540 3550 PST Operator Manual
Brand: Mahindra
Model:
Mahindra 3540 PST Tractor TIER-4 FINAL mCRD
Mahindra 3550 PST Tractor TIER-4 FINAL mCRD
Number Of Pages: 110 Pages
Emission Control Warranty for California
Emission Control Warranty for Federal
About this manual
Introduction
General Description
Owner Assistance
Owner’s Personal Data
ROPS
Safety Instructions
Safety Signs
Universal Symbols
LH & RH View of Engine
Lamps
Controls, Instruments & Operations
Instrument Cluster
Self Test Function of Instrument Cluster
Engine RPM Meter
LCD of Instrument Cluster
Hour Counter
Trip Hour Meter
Next Service / Service Reminder Indicator
Clock Indicator
Fuel Gauge
Coolant Temperature Gauge
Turn Indicators
High Beam Indicator
Forward/Reverse & PTO Neutral Indicator
Heater Indicator
Parking Brake Indicator
Battery Charging Indicator
High Temperature Warning Indicator
Low Oil Pressure Indicator
Water in Fuel Indicator
Air Filter Clog Indicator
4WD Indicator
CHK ENG (Check Engine) Indicator
MIL (Malfunction) Indicator
Switches
Hazard Switch
Combination Switch
Horn
Light Switch
Turn Signal Switch
Starter Key Switch
Work Lamp Switch
PTO Engage / Disengage Switch
PTO Auto / Manual / Off Switch
Key Pad Switch
Power Take Off
Controls
Operator Seat
Adjusting Seat Position
Weight Adjustment
Tilt Adjustment
Using Seat Belt
Fasten Seat Belt
Release Seat Belt
Slow Fast Valve Control Knob
Hand Throttle Operation
Increasing Engine Speed
Engine Tachometer speed
Decreasing Engine Speed
Constant Speed Setting
Foot Throttle Operation
Can Holder
Glove Box
Tilt Steering
Tilt Adjustment
4WD Engagement Lever
Brake
Differential Lock Pedal
Clutch
F-R Shuttle Shift Lever
Range Shift Lever
Speed Shift Lever
Loader
Opening the Hood
Closing the Hood
Removing the Side Panels
Assembling the Side Panels
Air Cleaner Clog Sensor
Hydraulic System & Operation
Position Control - Operation
Quadrant Assembly
Position Control
Setting of Position Control
Draft Control - Operation
Draft Control
Setting the Draft Control
Three Point Linkage
Toplink
Draft Sensing Bracket
Telescopic Lower Links
Adjustable Lift Rod RH
Lateral Stabilizers
Lift Rod LH
Drawbar
Attaching PTO Driven Implement
Drawbar
Wheel Tread Adjustment
Pneumatic Tires
Adding Liquid Weight
Inflation
Exceptions (Rear Tires only)
Care of Tires
Shipping Tractors Equipped with
Pneumatic Tires
Tire Protection during Storage
Mounting Tires on the Rim
Operating Instructions
Before Starting the Tractor
Stopping the Engine / Tractor
Cold Starting Aid
Driving the Tractor
Tractor Storage
Using The Tractor After Storage
Precautions
Operating the Tractor
The Tractor
Driving the Tractor
Servicing the Tractor
Operating the PTO (Power Take Off)
ROPS
Transporting Tractor on a Trailer
Towing
Diesel Fuel
Do’s & Dont’s
Maintenance
Radiator Cap
Surge Tank
Thermostat
Hose Connections
Fan & Fan Belts
Draining the System
Cleaning out Dirt and Sludge
Adding Coolant to the System
Cooling System Protection
Thresh Guard
Adjusting the Valve Clearance
Air Intake System
Air Cleaner
Body Air-Cleaner
Cyclopack or built-in Pre-Cleaner
Paper Element Filter
Safety Cartridge
Dust Collector Bowl
Hose and Clamps
Emission Control System
Fuel System
Clean Diesel Fuel
Bleeding the Fuel Filter
Bleeding the Fuel Injection Pump
Fuel Tank and Fuel Pipes
Servicing the Fuel Filter
Lubrication System
Oil Level Check
Oil Change
Engine Oil Filter
Changing Spin On Filter
Battery Maintenance Cleaning
Servicing
Effect of Low Temperatures
Charging Circuit
Starter Motor Removal
Hydraulics & Transmission
Adding Hydraulic and Transmission Oil
Front Axle Oil Level Checking / Draining /
Filling
Hydraulic & Transmission Oil Filter
Hydraulic & Transmission Strainer
Transmission Oil Drain
Toe-in Setting
Front Axle - Front Wheel “Toe-in” Check
Brake Pedal Free Play
Head Lamp Adjustment
Lubricants
General
Lubricant Storage
Alternate and Synthetic Lubricants
Diesel Engine Lubricating Oil
Mixing of lubricants
Engine Oil
Transmission, Hydraulics &
Oil Immersed Brakes
Chassis Lubricant (CL)
Front Axle
Oil Specifications Chart
Special Bolt Torques
Specifications - 3540 PST
Specifications - 3550 PST
Trouble Shooting
Hydraulics
Brakes
Electricals
Power Steering
Tractor History Card
Service Record
Part Replacement Record
Daily Operating Log
Tractor Storage Precautions
Lubrication & Greasing Chart
Routine Service Schedule
Wiring Diagram
Brand: Mahindra
Model:
About this manual
Introduction
General Description
Owner Assistance
ROPS
Safety Instructions
Safety Signs
Universal Symbols
Lamps
Instrument Cluster
Engine RPM Meter
Hour Counter
Trip Hour Meter
Clock Indicator
Fuel Gauge
Turn Indicators
High Beam Indicator
Heater Indicator
4WD Indicator
Switches
Hazard Switch
Combination Switch
Horn
Light Switch
Turn Signal Switch
Starter Key Switch
Work Lamp Switch
Key Pad Switch
Power Take Off
Controls
Operator Seat
Weight Adjustment
Tilt Adjustment
Using Seat Belt
Fasten Seat Belt
Release Seat Belt
Can Holder
Glove Box
Tilt Steering
Tilt Adjustment
Brake
Clutch
Range Shift Lever
Speed Shift Lever
Loader
Opening the Hood
Closing the Hood
Quadrant Assembly
Position Control
Draft Control
Three Point Linkage
Toplink
Lateral Stabilizers
Lift Rod LH
Drawbar
Drawbar
Pneumatic Tires
Inflation
Care of Tires
Pneumatic Tires
Cold Starting Aid
Driving the Tractor
Tractor Storage
Precautions
The Tractor
Driving the Tractor
ROPS
Towing
Diesel Fuel
Do’s & Dont’s
Maintenance
Radiator Cap
Surge Tank
Thermostat
Hose Connections
Fan & Fan Belts
Draining the System
Thresh Guard
Air Intake System
Air Cleaner
Body Air-Cleaner
Safety Cartridge
Dust Collector Bowl
Hose and Clamps
Fuel System
Clean Diesel Fuel
Lubrication System
Oil Level Check
Oil Change
Engine Oil Filter
Servicing
Charging Circuit
Filling
Toe-in Setting
Lubricants
General
Lubricant Storage
Engine Oil
Oil Immersed Brakes
Front Axle
Trouble Shooting
Hydraulics
Brakes
Electricals
Power Steering
Service Record
Daily Operating Log
Wiring Diagram
- Mahindra Tractor MAX Series 28XL Operator Manual
- Mahindra AML205 FRONT END LOADER Assembly, Operator's and Parts Manual
- Mahindra Tractor 10 Series 5010 Gear Cab Parts Manual
- Mahindra Tractor Super Turbo 595 DI Sarpanch Parts Manual
- Mahindra Tractor 16 Series 3616 Gear & HST Parts Manual
- Mahindra Tractor 60 Series 8560 4WD Parts Manual
- Mahindra USA Backhoe Model 2710/3710A/3710B Operators Parts Manual and Instructions
- Mahindra Tractor 16 Series 2216 Gear & HST Parts Manual
- Mahindra Tractor 10 Series Front Loader ML150 Parts Manual
- Mahindra Tractor 60 Series 7060 4WD Tier III Operators Manual
- Mahindra Tractor 16 Series 3016 Gear & HST Parts Manual
- Mahindra Tractor MAX Series 25 HST Parts Manual
- Mahindra Tractor 10 Series 6010 HST Cab Parts Catalog
- Mahindra Tractor 10 Series 4010 HST Parts Manual
- Mahindra USA Backhoe Model 3715 Operators Parts Manual and Instructions
