702,019
Mahindra Tractor 245DI BHOOMIPUTRA Parts Manual
Brand: Mahindra
Model: Mahindra 245DI BHOOMIPUTRA Tractor
Number Of Pages: 35 Pages
Alternator Drive & Mountings
Starter Motor
Battery Cover, Instrument Panel, Scuttle Panel, Controlling
Ininstruments, Gauges, Horn & Lamps
Clutch Housing & Connections
Transmission Gears & Shafts
Rear Axle Carrier And Rear Axle
Front Axle (One Piece), Stay Rod And Cast Iron Weight
Front Axle Support (Folded),Front End Weights & Bracket
Steering Knuckle, Arm, Drag Link And Tie Rod
Fuel System
Battery Box
Governor Control Linkages
Foot Accelerator
Hood And Radiator Grille
Hydraulics
Crankcase Assembly
Crankshaft Mechanism
Valve Gear
Cylinder Head Assembly
Water Pump Assembly
Lubricating System
Air Cleaner
