Mahindra Tractor 2123HST 2126HST Operators Manual 008032495N91
Brand: Mahindra
Model: Mahindra 2123HST 2126HST Tractor
Part Number: 008032495N91
Publication Date: 2024
Number of Pages: 141 Pages
Brand: Mahindra
1 GENERAL INFORMATION
Note to the owner
Owner’s assistance
Owner’s Personal Data
Improvements
Engine Tampering Statements
Introduction
Intended use
Environmental safety
Proposition 65 (P65) sticker information - California
Mahindra Emissions Control Warranty Policy
Universal symbols
Tractor identification plates
Component identification
Left hand and right hand side view of engine
Lamps overview
2 SAFETY INFORMATION
Safety rules and signal words
Read safety instructions
Safety for children
Precautions to avoid tipping
Park tractor safely
Keep riders off tractor
Handle fuel safely - avoid fires
Stay clear of rotating shafts
Always use lamps and SMV during road transport
Slow Moving Vehicle (SMV) emblem
Service tractor safely
Practice safe maintenance
Prevent acid burns
Prevent battery explosions
Avoid high-pressure fluids
Work in ventilated area
Tractor runaway
Overhead protection
Hearing protection
Precautions while using loader
Roll over protective structure (ROPS)
Hazardous chemicals
Getting ON and OFF of the tractor
Electrical storm safety
Transporting Tractor safely
Driving on public roads and general transportation safety
Utility safety
Recommended jacking points
General precautions
Driving concerns
Starting on steep slope
Tips for driving on slope
Servicing the tractor
Cleaning the tractor
Using high pressure washers
Safety decals
3 CONTROLS AND INSTRUMENTS
Controls, instruments and operations
Ignition key switch (if equipped)
FORWARD CONTROLS
Flashing warning lamp switch
Signature lamp switch
Parking brake
Brake pedals
Forward-Reverse pedals
Tilt steering
RIGHT HAND SIDE CONTROLS
Cruise control
PTO ON/OFF switch
LEFT HAND SIDE CONTROL
Range shift lever
4WD engagement lever
USB power socket
12V Power socket
Differential lock pedal
Instrument cluster
Beeper output provision
OPERATOR SEAT
4 OPERATING INSTRUCTIONS
Primary operating safety rules
Before starting and operating the tractor
Starting the tractor
Coolant heater (optional fitments)
Driving the tractor
Operational instructions
Stopping the engine
5 WORKING OPERATIONS
WORKING OPERATIONS
Draft Control (if equipped)
Setting of Draft Control
Slow fast valve control knob
Auxiliary valve (if equipped)
Sliding collar remote couplers (if equipped)
Three point linkage
Top link
Fixed type lower links
Telescopic lower links (if equipped)
Adjustable lift rod RH side
Telescopic stabilizers
Operating the PTO (Power Take Off)
Drawbar
Adjusting drawbar length
Implement preparation
Wheels and tires
Inflation
Wheel tread
Care of tires
Diesel fuel
Do's and Don'ts
6 TRANSPORT OPERATIONS
Towing the tractor
7 MAINTENANCE
MAINTENANCE
Hood
Front Side Panel
Fuse box
Air intake system
Engine cooling system
Fuel system
Lubrication system
Electrical system
Hydraulic and transmission
Power steering system
Front axle 4WD
Check and adjust brake pedal free play
Check HST Neutral setting
Lubricants
Lubrication oil
Special bolt torques
Storage
8 TROUBLESHOOTING
Hydraulics
Brakes
Rear wheels
Electrical
Power steering
9 SPECIFICATIONS
SPECIFICATIONS
- Mahindra Tractor MAX Series 28XL Operator Manual
- Mahindra AML205 FRONT END LOADER Assembly, Operator's and Parts Manual
- Mahindra Tractor 10 Series 5010 Gear Cab Parts Manual
- Mahindra Tractor Super Turbo 595 DI Sarpanch Parts Manual
- Mahindra Tractor 16 Series 3616 Gear & HST Parts Manual
- Mahindra Tractor 60 Series 8560 4WD Parts Manual
- Mahindra USA Backhoe Model 2710/3710A/3710B Operators Parts Manual and Instructions
- Mahindra Tractor 16 Series 2216 Gear & HST Parts Manual
- Mahindra Tractor 10 Series Front Loader ML150 Parts Manual
- Mahindra Tractor 60 Series 7060 4WD Tier III Operators Manual
- Mahindra Tractor 16 Series 3016 Gear & HST Parts Manual
- Mahindra Tractor MAX Series 25 HST Parts Manual
- Mahindra Tractor 10 Series 6010 HST Cab Parts Catalog
- Mahindra Tractor 10 Series 4010 HST Parts Manual
- Mahindra USA Backhoe Model 3715 Operators Parts Manual and Instructions
