Hyundai
86
176,684
Mahindra Tractor 1120HST 1123HST 1126HST Operators Manual 008032496K91
Brand: Mahindra
Model: Mahindra 1120HST 1123HST 1126HST Tractor
Part Number: 008032496K91
Publication Date: 2024
Number of Pages: 141 Pages
1 GENERAL INFORMATION​
Note to the owner​
Owner’s assistance​
Owner’s Personal Data​
Improvements​
Engine Tampering Statements​
Introduction​
Intended use​
Environmental safety​
Proposition 65 (P65) sticker information - California​
Mahindra Emissions Control Warranty Policy​
Universal symbols​
Tractor identification plates​
Component identification​
Left hand and right hand side view of engine​
Lamps overview​
2 SAFETY INFORMATION​
Safety rules and signal words​
Read safety instructions​
Safety for children​
Precautions to avoid tipping​
Park tractor safely​
Keep riders off tractor​
Handle fuel safely - avoid fires​
Stay clear of rotating shafts​
Always use lamps and SMV during road transport​
Slow Moving Vehicle (SMV) emblem​
Service tractor safely​
Practice safe maintenance​
Prevent acid burns​
Prevent battery explosions​
Avoid high-pressure fluids​
Work in ventilated area​
Tractor runaway​
Overhead protection​
Hearing protection​
Precautions while using loader​
Roll over protective structure (ROPS)​
Hazardous chemicals​
Getting ON and OFF of the tractor​
Electrical storm safety​
Transporting Tractor safely​
Wheels and tires​
Driving on public roads and general transportation safety​
Utility safety​
Recommended jacking points​
General precautions​
Driving concerns​
Starting on steep slope​
Tips for driving on slope​
Servicing the tractor​
Cleaning the tractor​
Using high pressure washers​
Safety decals​
3 CONTROLS AND INSTRUMENTS​
Controls, instruments and operations​
Ignition key switch (if equipped)​
FORWARD CONTROLS​
Flashing warning lamp switch​
Signature lamp switch​
Parking brake​
Brake pedal​
Forward-Reverse pedals​
Tilt steering​
Telescopic steering​
RIGHT HAND SIDE CONTROLS​
Range shift lever​
4WD engagement lever​
LEFT HAND SIDE CONTROLS​
Power Take Off (PTO) Selector lever​
USB power socket​
12V Power socket​
Cupholder​
Differential lock pedal​
Instrument cluster​
Beeper output provision​
OPERATOR SEAT​
4 OPERATING INSTRUCTIONS​
Primary operating safety rules​
Before starting and operating the tractor​
Starting the tractor​
Coolant heater (optional fitments)​
Driving the tractor​
Operational instructions​
Stopping the engine​
5 WORKING OPERATIONS​
WORKING OPERATIONS​
Slow fast valve control knob​
Auxiliary valve (if equipped)​
Sliding collar remote couplers (if equipped)​
Three point linkage​
Top link​
Fixed type lower links​
Telescopic lower links (if equipped)​
Adjustable lift rod RH side​
Check chains​
Operating the PTO (Power Take Off)​
Drawbar​
Using drawbar clevis​
Implement preparation​
Wheels and tires​
Inflation​
Care of tires​
Wheel tread​
Diesel fuel​
Do's and Don'ts​
6 TRANSPORT OPERATIONS​
Towing the tractor​
7 MAINTENANCE​
MAINTENANCE​
Hood​
Fuse box​
Air intake system​
Engine cooling system​
Fuel system​
Lubrication system​
Electrical system​
Hydraulic and transmission​
Power steering system​
Front axle 4WD​
Check and adjust brake pedal free play​
Check HST Neutral setting​
Lubricants​
Lubrication oil​
Special bolt torques​
Storage​
8 TROUBLESHOOTING​
Engine​
Hydraulics​
Brakes​
Transmission​
Rear wheels​
Electrical​
Power steering​
