Magni Telescopic Handler TH5.8 Use and Maintenance Manual P.N.75475.B 2022
Brand: Magni
Type of Machine: Telescopic Handler
Type of Manual: Use and Maintenance Manual
Model: Magni TH5.8 Telescopic Handler
TH 5.8-D5/A (TH5.8) – TH 5.8-D7/A (TH5.8 P), TH 5.8-D5/C (TH5.8) – TH 5.8-D7/C (TH5.8 P),
TH 5.8-D5/D (TH5.8) – TH 5.8-D7/D (TH5.8 P), THU 5.8-D7/A (THU5.8) - THU 5.8-D7/D (THU5.8 P)
Part Number: P.N.75475.B
Publication Date: 2022
Number of Pages: 131 Pages
PREFACE
Manufacturer’s details
Important safety information
Using the manual
Symbols used
Reference regulatory framework
Receipt of the vehicle
Assistance
How to request assistance
Spare parts
Warranty
WARRANTY AND EC DECLARATION
CONFORMITY
MAGNI’s Warranty Policy
EC Declaration of Conformity
TECHNICAL PRODUCT INFORMATION
Main parts and general description of
vehicle (TH version)
vehicle (THU version)
Vehicle features and main safety
(TH/THU versions)
Front headlights
Tail lights
Work and emergency lights
Rear view mirrors
Quick-fit coupling for the equipment
Shear pin housing
Anchoring points
Lifting points
Additional work lights (optional)
Cab features and main safety
(TH/THU versions)
Cab door
Cab door window
Rear window
Emergency exit
Seat belt
Safety keys container
Vehicle radio
Emergency stop button
Additional safety devices inside the cab
Position and load sensing system (LMI)
Additional features of the THU “MINING
vehicle
Cab protection grilles and lights
External emergency stop buttons
Fire extinguishers
Specific lighting and signalling devices for use
the mining sector
Additional equipment for THU version
Identification elements on the vehicle
Vehicle’s identification plate (up to 10/2021)
Vehicle’s identification plate (from 11/2021)
Serial no. stamped on chassis
Cab identification plate
Roll-Over Protective Structure
Falling Objects Protective Structure (FOPS) label
Sound power emitted plate
Engine identification plate
Transmission identification plate
Axles identification plate
TH / THU safety stickers
TH / THU Version Dimensions
Technical Specifications
Performances
Braking System
Tyres
Environmental data
Visibility data
TH/THU versions - Report on Visibility with
on fork carriage (according to EN 15830)
hanging load (according to EN 15830)
SAFETY AND WARNINGS
Symbols and safety labels
Do not transport persons
Do not touch
Engine compartment
Radiator fan
Do not enter the operating area of the vehicle
Pressure of tyres on the ground
Do not stand under the load
Do not approach the accessory
Speed limit on public roads
4
General danger information
Pressurised air and water
Penetration of fluids
Limiting the ejection of liquids
Information regarding asbestos
Prevention of cuts and crushing
Preventing burns
Coolants
Oils
Batteries
Prevention of fires and explosions
Fire extinguisher
Ether
Piping
Accident prevention in case of
with lightning
Spare parts and tooling
Before using the vehicle
Sound pressure and vibration levels in the cab
Sound pressure level
Vibration level
Protection for the operator
Safety devices
Safety devices present
Residual risks
Hot fluid jets and hot surfaces
Generic faults
Braking system accumulators
Intended use
Reasonably foreseeable misuse
Potentially explosive atmospheres (ATEX Directive)
Information regarding AdBlue®
AdBlue® and high temperatures
AdBlue® and low temperatures
Storage and disposal
Regeneration
OPERATION
Controls
Steering column
Ignition switch
Lights/horn/windscreen wiper selector
Horn
Windscreen Wipers/Washers
Parking brake
Hazard lights
Pedals
Steering modes
Joystick
Transmission selector
Drive speed
Joystick movements
Boom head hydraulic control
Control dashboard
Multiple function display
Exclusion of the safety systems
USB socket
Pushbutton panel
Double USB socket
Browsing through the pages
Accessory confirmation page
Main page
Load control page
Configuration of boom
Interactive load chart
Load percentage (SWL)
Limits page
Radio controls (Optional)
General information
Before starting the engine
Visual inspection
Climbing on to or climbing down from the vehicle
Driver's seat
Starting the engine
Start-up in normal conditions
Start-up in extreme climates
Start-up using jumper cables
After start-up
Automatic parking brake
Driving the vehicle
Operating techniques
Fitting the equipment
Disassembling the equipment
List of compatible accessories
Handling of loads
Picking up and placing a hanging load
Moving the centre of gravity
Visibility
Traversing over sloping ground
Climatic conditions of use
Adverse climatic conditions
Parking the vehicle
Parking position
Stopping the vehicle
Leaving the vehicle
INDEX
TRANSPORT AND MAINTENANCE
Information regarding transport
Shipping the vehicle
Driving the vehicle on the road
Lifting and anchoring the vehicle
Towing the vehicle
General information
Tightening torques
Washing
Tyres
Standard inflation pressures
Inflation with air
Inflating with nitrogen
Fuseboxes
TH 5.8 models
THU 5.8 models
Liquids, lubricants and spare parts
Maintenance Schedule
Maintenance items
Safety information
Differentials oil
Wheel reduction gears oil
Transmission shaft
Steering elements
Transmission belt
Engine Oil
Checking the engine oil level
Changing the engine oil
Replacing the lubrication oil cartridge
Fuel prefilter
Fuel filter
Bleed the fuel supply system
AdBlue® filter
Coolant
Hydraulic oil
Hydraulic oil filter
Two or three-speed reduction gear oil
Engine air filter
Cab air filter
Telescopic boom sliding blocks
Telescopic boom pins
Emergency hydraulic pump
Engine radiator
Fuel tank
Windscreen washer liquid tank
Engine Troubleshooting
REFERENCE INFORMATION
Leaving the vehicle unused for long periods
Leaving the vehicle unused for less
12 months
36 months
Reusing the vehicle
Dismantling and disposal of the vehicle
Approved equipment
INSPECTION REGISTER
Brand: Magni
PREFACE
Using the manual
Symbols used
Assistance
Spare parts
Warranty
CONFORMITY
(TH/THU versions)
Front headlights
Tail lights
Rear view mirrors
Shear pin housing
Anchoring points
Lifting points
(TH/THU versions)
Cab door
Cab door window
Rear window
Emergency exit
Seat belt
Vehicle radio
vehicle
Fire extinguishers
the mining sector
Performances
Braking System
Tyres
Environmental data
Visibility data
SAFETY AND WARNINGS
Do not touch
Engine compartment
Radiator fan
4
Preventing burns
Coolants
Oils
Batteries
Fire extinguisher
Ether
Piping
with lightning
Vibration level
Safety devices
Residual risks
Generic faults
Intended use
Regeneration
OPERATION
Controls
Steering column
Ignition switch
Horn
Parking brake
Hazard lights
Pedals
Steering modes
Joystick
Drive speed
Joystick movements
Control dashboard
USB socket
Pushbutton panel
Double USB socket
Main page
Load control page
Limits page
General information
Visual inspection
Driver's seat
Starting the engine
After start-up
Driving the vehicle
Handling of loads
Visibility
Parking the vehicle
Parking position
Leaving the vehicle
INDEX
Towing the vehicle
General information
Tightening torques
Washing
Tyres
Inflation with air
Fuseboxes
TH 5.8 models
THU 5.8 models
Maintenance items
Safety information
Differentials oil
Transmission shaft
Steering elements
Transmission belt
Engine Oil
Fuel prefilter
Fuel filter
AdBlue® filter
Coolant
Hydraulic oil
Engine air filter
Cab air filter
Engine radiator
Fuel tank
12 months
36 months
Reusing the vehicle
Approved equipment
INSPECTION REGISTER
- Magni Self-Propelled Scissor Lifts ES0807HP ES0807EP Parts Manual P.N.62641 2019
- Magni Telehandler REP 2-4.5 I Parts Catalog 07279
- Magni Telehandler RTH4.18 RTH5.18 Hydraulic Diagram
- Magni Telehandler RTH5-18 to RTH5-30 JCB Wiring Diagram
- Magni Telehandler RTH5.21 Hydraulic Diagram
- Magni Telehandler RTH5.23 RTH5.26 RTH5.30 Hydraulic Diagram
- Magni Telehandler RTH18 to RTH30 Mercedes Wiring Diagram
- Magni Telehandler RTH 4.18 Operation and Maintenance Manual
- Magni Telehandler RTH 4.18 Operation and Maintenance Manual DE
- Magni Telehandler RTH 4.18 Operation and Maintenance Manual FR
- Magni Telehandler RTH 5.18 M Parts Catalog 05860
- Magni Telehandler RTH 5.18 Operation and Maintenance Manual DE
- Magni Telehandler RTH 5.18 Operation and Maintenance Manual FR
- Magni Telehandler RTH 5.18 Operation and Maintenance Manual RU
