Momed80
150
35,046
Magni Telescopic Handler RTH Series Use and Maintenance Manual 99744_RTHV 2023
Brand: Magni
Type of Machine: Telescopic Handler, Rotating Telehandler
Type of Manual: Use and Maintenance Manual
Model: Magni RTH Series Telescopic Handler
RTH 6.31-V/A, RTH 6.31-V/D, RTH 6.35-V/A-1, RTH 6.35-V/D-1, RTH 6.39-V/A-1,
RTH 6.39-V/D-1, RTH 6.46-V/A-1, RTH 6.46-V/D-1, RTH 6.51-V/A-1, RTH 6.51-V/D-1,
RTH 8.27-V/A, RTH 8.27-V/D, RTH 8.35-V/A, RTH 8.35-V/D, RTH 8.39-V/A, RTH 8.39-V/D,
RTH 8.46-V/A, RTH 8.46-V/D, RTH 10.37-V/A, RTH 10.37-V/D, RTH 13.26-V/A-1, RTH 13.26-V/D-1
Volvo Penta Stage IIIA
Volvo Penta Stage V
Part Number: 99744_RTHV
Publication Date: 12/2023
Number of Pages: 149 Pages
Data Regarding The Manual
Reference Regulatory Framework
Preface
Manufacturer’s Details
Important Safety Information
Using The Manual
People To Whom This Manual Is Addressed
Symbols Used
Declaration Of Initial Testing
Delivery Of The Vehicle
Receipt Of The Vehicle
Assistance
How To Request Assistance
Spare Parts
Ec Declaration Of Conformity
Warranty
Recall Campaigns For Product Defects
General Warnings
Hazards And Safety Instructions
Noise Protection
Danger Of Crushing.
Prevention Of Cuts And Crushing
Danger From Hanging Load
Danger Of Burns
Danger Of Battery Explosion
Electrocution Hazard
Works Near Power Lines
Accident Prevention In Case Of Thunderstorms
Lightning
Risk Of Slipping
Risk Of Falling, Tripping
Penetration Of Fluids
Pressurised Air And Water
Limiting The Ejection Of Liquids
Braking System Accumulators
Storage Of Hazardous Liquids
Information Regarding Adblue®
Information Regarding Asbestos
Cabin Air Conditioning System Information
Use Of The Vehicle
Correct Use
Before Starting The Vehicle
Visual Inspection
Concomitant Work Phases
Reasonably Foreseeable Misuse
Incorrect Use
Safety Devices
Safety Devices On The Vehicle
Roll-Over Protective Structure (Rops), Falling
Protective Structure (Fops)
Sound Pressure Level
Sound Power Level
Vibration Level
Vehicle’s Identification Elements
Vehicle Plates And Marking
Cab Identification Plate
Engine Identification Plate
Transmission Pump Identification Plate
Service Pump Identification Plate
Gear Pump Identification Plate
Transmission Motor Identification Plate
Axles Identification Plate
Technical Product Information
Glossary
Features Of The Vehicle
Optional Accessories
Interchangeable Equipment
General Description Of The Vehicle
Front/Left Side
Rear/Right Side
Cab Interior (Plan View)
Cab Interior (Front View)
Safety Labels
Vehicle Features And Main Safety Devices
Vehicle Cab
Climbing On To Or Climbing Down From The Vehicle
Door Window
Rear Window
Emergency Exit
Driver's Seat
Adjustments
Armrests
Joystick
Right Joystick
Left Joystick
Steering Column
Light, Window Wiper, Horn Selector.
Steering Wheel
Pedals
Control Dashboard
Vehicle Ignition Key.
Safety System Limit Override Key.
Key For Radio Control Wiring Override In Aerial
Platform.
Multifunctional Manipulator
Service Buttons
Levelling On Wheels
Stabiliser Controls
Electric Emergency Pump Button
Parking Brake Engagement Button
Automatic Parking Brake
Hazard Lights Button
Red Emergency Stop Button
Double Usb Socket
Multiple Function Display
Drive Page
Graduated Indicators
Levelling Indicator
Turret Rotation Indicator
Anti-Tipping System Indicator
List Of Warning Lights And Functions That Can Be
In The Drive Page
Handling Mode
Speed Of Movements
Eco Mode
Radio Control Connection
Steering Modes
Boom Suspension
Winter Mode
Stabilizers Page
Setup Function
Auto Levelling
Limits Page
Limitation Of Telescopic Boom Extension
Setting The Movement Speed Limits
Load Page
Flow Rate Diagram In Static View
Flow Rate Diagram In Dynamic Side View
Flow Rate Diagram In Dynamic Plan View
Commands Page
Air-Conditioning System
Auxiliary Lighting System
Ancillary Functions
Hydraulic Rotation Lock
Working Mode
24v Electrical Output At Boom Head
Continuous Hydraulic Fluid
Idle Speed/Engine Control
Start & Stop
Cooling Fan Rotation Reversal
Password Pages
System Info Page
Air Vents
Service Compartments For The Vehicle Driver
Safety Keys Container
Vehicle Radio
Reading Light
Sunshade
Radio Control Battery Charger
Radio Control Housing (Optional)
External Elements
Work And Emergency Lights
Rear View Mirrors
Headlights
Tail Lights (Optional)
Additional Cab Work Lights
Additional Work Lights On The Telescopic
(Optional)
Shear Pin Housing For Interchangeable
Anchoring Points
Tow Hook
Quick-Fit Coupling For The Equipment
“I” And “U” Couplings
Secondary Access Ladder
Turret Rotation Lock Pin
Operating Techniques
Before Using The Vehicle
Work Area
Weather Conditions
Climatic Conditions Of Use
Road Circulation
Parking The Vehicle
Interchangeable Equipment Installation
Equipment Confirmation
Removing The Equipment
Hydraulic Shear Pin
List Of Compatible Accessories
Approved Equipment
Handling Of Loads
Centre Of Gravity Of The Load
Picking Up A Load From The Ground With Fork
Plate
Moving The Centre Of Gravity
Visibility
Traversing Over Sloping Ground
Information Regarding Transport
Shipping The Vehicle
Lifting The Vehicle
Anchoring The Vehicle For Transportation
Towing The Vehicle
Mechanical Brake Release
Manual Positioning Of The Reverse Gear In Neutral
How To Tow A Vehicle
Maintenance
Vehicle In Maintenance Position
Tightening Torques
Tyres
Standard Inflation Pressures
Inflation With Air
Inflation With Nitrogen
Replacing The Wheels
Washing
Liquids, Lubricants
List Of Spare Parts For Routine Maintenance
Maintenance Schedule
Maintenance Operations
Safety Information
Battery Disconnect Switch
Maintenance Operations Under The Telescopic Boom
Maintenance Operations In Areas Not Accessible
The Ground
Hydraulic Hoses
Dana Axles
Differentials Oil
Wheel Reduction Gears Oil
Steering Elements
Omci Axles
Differentials Oil
Steering Elements
Transmission Shaft
Engine Oil
Checking The Engine Oil Level
Changing The Engine Oil
Replacing The Oil Filter.
Fuel Prefilter
Bleeding The Fuel Supply System
Adblue® Filter
Coolant
Engine Radiator
Hydraulic Fluid
Hydraulic Fluid Filter
Two-Speed Reduction Gear Oil
Engine Air Filter
Cab Air Filter
Telescopic Boom Sliding Blocks
Telescopic Boom Pins
Telescopic Boom Chains
Adjustment
Checking For Wear
Windscreen Washer Liquid Tank
Emergency Hydraulic Pump
Turret Rotation Slewing Ring Gear
Check Slewing Gear Bearing Wear Every 500 Hours
Batteries
Fuse Section
Troubleshooting
Error And Display Messages
Engine Troubleshooting
Vehicle Storage
Leaving The Vehicle Unused For Long Periods
Leaving The Vehicle Unused For Less Than 12 Months
Leaving The Vehicle Unused For Less Than 36 Months
Reusing The Vehicle
Dismantling And Disposal Of The Vehicle
Dimensions
Dimensions
Technical Data
Engine: Volvo Penta (Stage Iiia / Stage V)
Brakes
Masses
Performances
Sound Power
Sound Pressure And Vibrations
Reference Information
