Magni Telescopic Handler RTH Series Use and Maintenance Manual 99261_RTHD 2023
Brand: Magni
Type of Machine: Telescopic Handler, Rotating Telehandler
Type of Manual: Use and Maintenance Manual
Model: Magni RTH Series Telescopic Handler
RTH 5.18-D5/A, RTH 5.18-D5/D, RTH 5.21-D/A-1, RTH 5.21-D/D-1, RTH 5.23-D/A-1,
RTH 5.23-D/D-1, RTH 5.25-D/A-1, RTH 5.25-D/D-1, RTH 6.22-D/A, RTH 6.22-D/D, RTH 6.26-D/A, RTH 6.26-D/D
Engine: Deutz stage IIIA, Deutz stage V
Part Number: 99261_RTHD
Publication Date: 12/2023
Number of Pages: 151 Pages
Data regarding the manual
Reference regulatory framework
PREFACE
Manufacturer’s details
Important safety information
Using the manual
People to whom this manual is addressed
Symbols used
Declaration of initial testing
Delivery of the vehicle
Receipt of the vehicle
Assistance
How to request assistance
Spare parts
EC Declaration of Conformity
Warranty
Recall campaigns for product defects
GENERAL WARNINGS
Hazards and safety instructions
Noise protection
Danger of crushing.
Prevention of cuts and crushing
Danger from hanging load
Danger of burns
Danger of battery explosion
Electrocution hazard
Works near power lines
Accident prevention in case of thunderstorms with
lightning
Risk of slipping
Risk of falling, tripping
Penetration of fluids
Pressurised air and water
Limiting the ejection of liquids
Braking system accumulators
Storage of hazardous liquids
Information regarding AdBlue®
Information regarding asbestos
Cabin air conditioning system information
USE OF THE VEHICLE
Correct use
Before starting the vehicle
Visual inspection
Concomitant work phases
Reasonably foreseeable misuse
Incorrect use
Safety devices
Safety devices on the vehicle
Roll-Over Protective Structure (ROPS), Falling Objects
Protective Structure (FOPS)
Sound pressure level
Sound power level
Vibration level
VEHICLE’S IDENTIFICATION ELEMENTS
Vehicle plates and marking
Cab identification plate
Engine identification plate
Transmission pump identification plate
Service pump identification plate
Gear pump identification plate
Transmission motor identification plate
Axles identification plate
TECHNICAL PRODUCT INFORMATION
Glossary
Features of the vehicle
Optional accessories
Interchangeable equipment
General description of the vehicle
Front/left side
Rear/right side
Cab interior (plan view)
Cab interior (front view)
Safety labels
FEATURES OF THE VEHICLE
Vehicle features and main safety devices
Vehicle cab
Climbing on to or climbing down from the vehicle
Door window
Rear window
Emergency exit
Driver's seat
Adjustments
Armrests
Joystick
Right joystick
Left joystick
Steering column
Light, window wiper, horn selector.
Steering wheel
Pedals
Control dashboard
Vehicle ignition key.
Safety system limit override key.
Key for radio control wiring override in aerial work
platform.
Multifunctional manipulator;
Service buttons
Levelling on wheels
Stabiliser controls
Electric emergency pump button
Parking brake engagement button
Automatic parking brake
Hazard lights button
Red emergency stop button
Double USB socket
Multiple function display
Drive page
Graduated indicators
Levelling indicator
Turret rotation indicator
Anti-tipping system indicator
List of warning lights and functions that can be selected
in the Drive page
Handling mode
Speed of movements
Reset
Eco mode
Radio control connection
Steering modes
Boom suspension
Winter mode
Stabilizers page
Setup function
Auto levelling
Limits page
Limitation of telescopic boom extension
Setting the movement speed limits
Load page
Flow rate diagram in static view
Flow rate diagram in dynamic side view
Flow rate diagram in dynamic plan view
Commands page
Air-conditioning system
Auxiliary lighting system
Ancillary functions
Hydraulic rotation lock
Working mode
24V electrical output at boom head
Continuous hydraulic fluid
Idle speed/engine control
Start & STOP
Cooling fan rotation reversal
Password Pages
System Info page
Air vents
Service compartments for the vehicle driver
Safety keys container
Vehicle radio
Reading light
Sunshade
Radio control battery charger
Radio control housing (Optional)
External elements
Work and emergency lights
Rear view mirrors
Headlights
Tail lights (Optional)
Additional cab work lights
Additional work lights on the telescopic boom
(Optional)
Shear pin housing for interchangeable equipment
Anchoring points
Tow hook
Quick-fit coupling for the equipment
“I” and “U” couplings
Secondary access ladder
Turret rotation lock pin
OPERATING TECHNIQUES
Before using the vehicle
Work area
Weather conditions
Climatic conditions of use
Road circulation
Parking the vehicle
Interchangeable equipment installation
Equipment confirmation
Removing the equipment
Hydraulic shear pin
List of compatible accessories
Approved equipment
Handling of loads
Centre of gravity of the load
Picking up a load from the ground with fork
plate
Moving the centre of gravity
Visibility
Traversing over sloping ground
INFORMATION REGARDING TRANSPORT
Shipping the vehicle
Lifting the vehicle
Anchoring the vehicle for transportation
Towing the vehicle
Mechanical brake release
Manual positioning of the reverse gear in neutral
How to tow a vehicle
MAINTENANCE
General information
Vehicle in maintenance position
Tightening torques
Tyres
Standard inflation pressures
Inflation with air
Inflation with nitrogen
Replacing the wheels
Washing
Liquids, lubricants and spare parts
List of spare parts for routine maintenance
Maintenance Schedule
Maintenance operations
Safety information
Battery disconnect switch
Maintenance operations under the telescopic boom
Maintenance operations in areas not accessible from
the ground
Hydraulic hoses
Differentials oil
Wheel reduction gears oil
Transmission shaft
Steering elements
Transmission belt
Checking the belt tension
Brand: Magni
PREFACE
Using the manual
Symbols used
Assistance
Spare parts
Warranty
GENERAL WARNINGS
Noise protection
Danger of crushing.
Danger of burns
lightning
Risk of slipping
USE OF THE VEHICLE
Correct use
Visual inspection
Incorrect use
Safety devices
Sound power level
Vibration level
Glossary
Front/left side
Rear/right side
Safety labels
Vehicle cab
Door window
Rear window
Emergency exit
Driver's seat
Adjustments
Armrests
Joystick
Right joystick
Left joystick
Steering column
Steering wheel
Pedals
Control dashboard
platform.
Service buttons
Levelling on wheels
Stabiliser controls
Double USB socket
Drive page
Levelling indicator
in the Drive page
Handling mode
Speed of movements
Reset
Eco mode
Steering modes
Boom suspension
Winter mode
Stabilizers page
Setup function
Auto levelling
Limits page
Load page
Commands page
Ancillary functions
Working mode
Start & STOP
Password Pages
System Info page
Air vents
Vehicle radio
Reading light
Sunshade
External elements
Rear view mirrors
Headlights
(Optional)
Anchoring points
Tow hook
Work area
Weather conditions
Road circulation
Parking the vehicle
Hydraulic shear pin
Approved equipment
Handling of loads
plate
Visibility
Lifting the vehicle
Towing the vehicle
MAINTENANCE
General information
Tightening torques
Tyres
Inflation with air
Washing
Safety information
the ground
Hydraulic hoses
Differentials oil
Transmission shaft
Steering elements
Transmission belt
- Magni Self-Propelled Scissor Lifts ES0807HP ES0807EP Parts Manual P.N.62641 2019
- Magni Telehandler REP 2-4.5 I Parts Catalog 07279
- Magni Telehandler RTH4.18 RTH5.18 Hydraulic Diagram
- Magni Telehandler RTH5-18 to RTH5-30 JCB Wiring Diagram
- Magni Telehandler RTH5.21 Hydraulic Diagram
- Magni Telehandler RTH5.23 RTH5.26 RTH5.30 Hydraulic Diagram
- Magni Telehandler RTH18 to RTH30 Mercedes Wiring Diagram
- Magni Telehandler RTH 4.18 Operation and Maintenance Manual
- Magni Telehandler RTH 4.18 Operation and Maintenance Manual DE
- Magni Telehandler RTH 4.18 Operation and Maintenance Manual FR
- Magni Telehandler RTH 5.18 M Parts Catalog 05860
- Magni Telehandler RTH 5.18 Operation and Maintenance Manual DE
- Magni Telehandler RTH 5.18 Operation and Maintenance Manual FR
- Magni Telehandler RTH 5.18 Operation and Maintenance Manual RU
