Momed80
150
35,046
Magni Telescopic Handler HTH Series Use and Maintenance Manual 73317_HTH 2024
Brand: Magni
Type of Machine: Telescopic Handler, Heavy Lift Telehandler
Type of Manual: Use and Maintenance Manual
Model: Magni HTH Series Telescopic Handler
HTH 16.10, HTH 20.10, HTH 24.11, HTH 27.11, HTH 30.12, HTH 35.12
Part Number: 73317_HTH
Publication Date: 01/2024
Number of Pages: 112 Pages
PREFACE 1
Important safety information
Information regarding this Manual
Reference regulatory framework
SAFETY AND WARNINGS
Symbols and safety labels
Do not transport persons
Danger of burns
Engine compartment
Vehicle operating area
Speed limit on public roads
General danger information
Pressurised air and water
Penetration of fluids
Limiting the ejection of liquids
Information regarding asbestos
Prevention of cuts and crushing
Preventing burns
Coolant
Oils
Batteries
Prevention of fires and explosions
Fire extinguisher
Ether
Piping
Information regarding AdBlue
Engine regeneration
Accident prevention in case of
thunderstorms with lightning
Spare parts and Equipment
Before using the vehicle
Harsh operating conditions
Sound pressure and vibration levels in
the cab
Sound pressure level
Vibration level
Protection for the operator
Safety devices
Safety devices present
Residual risks
Hot fluid jets
Hot fluids and surfaces
Generic faults
Braking system accumulators
Reasonably foreseeable misuse
IDENTIFICATION ELEMENTS
Identification plates
Vehicle’s identification plate
Acoustic power emitted plate
Serial no. stamped on chassis
Axles identification plate
Transmission identification plate
Engine identification plates
Cab identification plate
Roll-Over Protective Structure (ROPS),
Falling Objects Protective Structure (FOPS)
General description of the vehicle
Front
Rear
Position of the safety, functional and
generic stickers
EC declaration of conformity
TECHNICAL SPECIFICATIONS
Dimensions
Characteristics
EXTERNAL FUNCTIONAL ELEMENTS
Front headlights
Tail lights
Work and emergency lights
Rear view mirrors
Quick-fit “I” coupling for the equipment
Anchoring points
Tow hook
Additional work lights (Optional)
Setup for countries with cold climate
(optional)
CAB
Cab exterior
How to access the cab
Cab interior
Cab door
Cab door window
Rear window
Ceiling lights
Emergency exit
Safety keys container
Seat belts
Steering column
Air vents
Vehicle radio
Controls
Steering wheel
Ignition switch
Multiple function selector
Windscreen wipers
Parking brake
Hazard lights
Pedals
Joystick
Emergency stop button
Multiple function display
Browsing through the pages
Browsing using the multiple function
display
Browsing using the joypad
Multiple function display backlight
adjustment
Accessory confirmation page
Main page
Load control page
Controls page
Exclusion of the safety systems
USB socket
Levelling on wheels
A/B and C/D buttons
Emergency hydraulic circuit
Differential lock button
Electric cigarette lighter / dual USB socket
Radio control (OPTIONAL)
VEHICLE HANDLING
Before starting the engine
Visual inspection
Driver's seat
Starting the engine
Start-up in normal conditions
Start-up in extreme climates
Start-up using jumper cables
After start-up
Releasing the parking brake
Operating Techniques
Vehicle/accessory attachment
Disconnecting and removing the accessory
List of compatible accessories
Handling of loads
Picking up and placing a hanging load
Moving the centre of gravity
Visibility
Traversing over sloping ground
Climatic conditions of use
Driving the vehicle
Parking the vehicle
Parking position
Stopping the vehicle
Leaving the vehicle
Information regarding transport
Shipping the vehicle
Travelling by road with the vehicle
Lifting and anchoring the vehicle
Towing the vehicle
Recovery of the telescopic boom in case
of failure
MAINTENANCE
General information
Vehicle in maintenance position
Tightening torques
Tyres
Washing the vehicle
Fuses
Liquids and lubricants
Spare parts for routine maintenance
Maintenance Schedule
Maintenance Operations
Liquid leaks
Fuel tank
Windscreen washer liquid tank
Coolant
Engine radiator
Telescopic boom sliding blocks
Telescopic boom pins
Emergency hydraulic pump
Engine oil and filter
Fuel system
Fuel prefilter
Engine air filter
Hydraulic oil
Hydraulic oil filter
Cab air filter
Differentials oil
Wheel reduction gears oil
Speed reduction gear oil
Transmission shaft
Steering elements
Map of greasing points on the vehicle
Troubleshooting
Volvo Penta engine error messages
Error messages on the multiple
function display
Generic troubleshooting
Reference information
Leaving the vehicle unused for long
periods
Dismantling and disposal of the vehicle
Approved Equipment
