Macdon Windrower M2260 Parts Catalog 262169 Revision A
Brand: Macdon
Type of Machine: Windrower
Model: Macdon M2260 Windrower
Publication Date: 2023
Parts Number: 262169 Revision A
Number Pages: 314 Pages
Introduction
Serial Number Breaks
Abbreviations
1 Wheel Legs
2 Left Platform and Toolbox
3 Left Platform Mechanism
4 Right Platform
5 Right Support and Tanks
6 Diesel Exhaust Fluid Tank
7 Diesel Exhaust Fluid Plumbing
8 Walking Beam
9 Anti-Shimmy
10 Casters – Suspended 165-161
11 Drive Wheels and Tires – Ten Bolt
12 Drive Wheels and Tires – Twelve Bolt
13 Lift Linkage
14 Lift Linkage Cylinders
15 Float Sensors
16 Center-Link
17 Engine Sub Assembly
18 Fuel System
19 Engine Air Intake
20 Engine Exhaust
21 Engine Cooling System
22 Cooling Module – Left
23 Cooling Module – Right
24 Charge Air Cooler Plumbing
25 Radiator Plumbing
26 Hood
27 Hood Frame
28 Hood Latch Mechanism
29 Hood Gas Shocks – Standard
30 Rear Lights and Bezels
31 Cab-Forward Lighting and Marking
32 Roof – Standard and Deluxe Cab
33 Headliner – Radio, Speakers, and Relay Module
34 Roof – Lighting
35 Roof Relay Module – Service Parts
36 Cab GPS Bulkhead/Display Mount
37 Electrical – Autosteer
38 Cab Interior and Upholstery
39 Cab Exterior and Air Intake Stack
40 Cab Suspension
41 Windows
42 Doors
43 Wipers
44 Mirror Arms, Beacons, and Reflectors
45 Cab Air Conditioning and Heating
46 Cab Air Conditioning and Heating – Service Parts
47 Heating, Ventilation, and Air Conditioning – Chassis
48 Standard Cab Components
49 Deluxe Cab Components
50 Standard Operator’s Seat
51 Standard Seat Suspension
52 Deluxe Operator’s Seat
53 Deluxe Seat Suspension
54 Trainer’s Seat
55 Steering Column and Seat Base
56 Steering Column – Service Parts
57 Ground Speed Lever, Cable, and Display
58 Console Components
59 Steering and Ground Speed Control (under Cab)
60 Neutral Interlock and Pintle Arms
61 Engine Gearbox
62 Engine Gearbox – Service Parts
63 Traction Drive Pump
64 Traction Drive Pump – Service Parts
65 Left-Hand Pump Stack
66 Disc/Knife Drive Pump
67 Lift/Fan Pump
68 Wheel Drive Assembly – Ten Bolt
69 Wheel Drive Assembly – Twelve Bolt
70 Wheel Drive – Service Parts, Ten Bolt
71 Wheel Drive – Service Parts, Twelve Bolt
72 Header Drive (Rotary Disc Only) – Frame Interface
73 Header Drive – Frame Interface
74 Header Drive – Manifold Multi coupler Assembly
75 Header Drive – Fitting Manifold Frame Assembly
76 Header Drive – Charge Filter Frame Assembly
77 Header Drive Manifold (Rotary Disc Only)
78 Drive Manifold (Except Rotary Disc)
79 Float Selector Manifold
80 Charge Manifold
81 Hydraulics – Tank Fittings
82 Hydraulics – Fan/Lift Manifold
83 Lift/Fan Manifold – Valves and Coils
84 Lift/Fan Manifold – Plugs and Fittings
85 Hydraulics – Fan Drive Lines
86 Hydraulics – Oil Cooler Lines
87 Hydraulics – Frame Fittings
88 Junction Manifold – Service Parts
89 Hydraulics – Charge Lines
90 Hydraulics – Open Drive Lines
91 Hydraulics – Closed Drive Lines
92 Hydraulics – Case Drain Cooler Lines
93 Hydraulics – Traction Drive
94 Hydraulics – Control Lines
95 Hydraulics – Lift System
96 Hydraulics – Line Supports
97 Electrical – Chassis
98 Main Fuse Panel
99 Electrical – Chassis Components
100 Chassis Relay Module and Fuse Panel Assembly
101 Chassis Relay Module – Service Parts
102 Electrical – Battery and Cover
103 Electrical – Battery Cables
104 Electrical – Engine
105 Electrical – Firewall Modules
106 Electrical – Wheel Legs
107 Decals – Safety
108 Decals – Information and Reflectors
109 Decals – Product Identification
110 (Option) Bluetooth Software Interface Module
111 (Option) Center-Link Self-Alignment
112 (Option) Coolant Heater Kit – 6 Cylinder
113 (Option) Counterweights – Rear Ballast
114 (Option) Draper and Auger Conversion
115 (Option) DWA Shut-Off Kit
116 (Option) Float Booster Spring
117 (Option) Float Booster Spring Doubler
118 (Option) High Debris Cooler Intake
119 (Option) Neutral Setting Service Kit
120 (Option) Quick Couplers
121 (Option) Reel Drop Rate Adjustment
122 (Option) Trimble® Autopilot™ – Electrical
123 (Option) Trimble® Autopilot™ – Hydraulics
124 (Option) Trimble® IMD-900 Adapter Harness
125 (Option) Trimble® TMX Compatibility Kit
126 (Option) Weight Box
Index
Brand: Macdon
Introduction
Abbreviations
1 Wheel Legs
4 Right Platform
8 Walking Beam
9 Anti-Shimmy
13 Lift Linkage
15 Float Sensors
16 Center-Link
18 Fuel System
20 Engine Exhaust
26 Hood
27 Hood Frame
34 Roof – Lighting
40 Cab Suspension
41 Windows
42 Doors
43 Wipers
54 Trainer’s Seat
61 Engine Gearbox
67 Lift/Fan Pump
80 Charge Manifold
98 Main Fuse Panel
107 Decals – Safety
Index
- Macdon Multi-Crop Header and Hay Conditioner 940 Operators Manual 46005
- Macdon Offset Mount Adapter 901 Supplement Operators Manual 46080
- Macdon Rotary Disc 13 Foot Header R85 Operators Manual
- Macdon Rotary Disc 13-Foot R113 Unloading & Assembly Instructions 214075 Revision A
- Macdon Rotary Disc 13-Foot R85 Unloading & Assembly Instructions
- Macdon Rotary Disc 16 Foot Header R85 Operators Manual
- Harvestec Corn Header 4000 5000 Series Parts Catalog
- Macdon Rotary Disc 16-Foot R85 Unloading & Assembly Instructions
- Harvestec Corn Header 440 630 636 830 836 840 Parts Catalog
- Macdon Rotary Disc Header R113 R116 Parts Catalog 262298 Revision A
- Harvestec Corn Header 6000 Series Parts Catalog
- Macdon Rotary Disc Header R113 R116 Unloading & Assembly Instructions 215368 Revision A
- Macdon Combine Draper Header D1-Series FM100 Unloading and Assembly Instructions
- Macdon Rotary Disc Header R113 Unloading & Assembly Instructions
- Macdon Combine Header 973 974 Operators Manual 147083
