Martin Welker
104
230,310
Macdon Windrower M2170 M2170NT Parts Catalog 262168 Revision A
Brand: Macdon
Type of Machine: Windrower
Model: Macdon M2170 M2170NT Windrower
Publication Date: 2023
Parts Number: 262168 Revision A
Number Pages: 360 Pages
Introduction
Serial Number Breaks
Abbreviations
1 Wheel Legs – M2170
2 Wheel Legs – M2170NT
3 Left Platform and Toolbox – M2170
4 Left Platform and Toolbox – M2170NT
5 Left Platform Mechanism
6 Right Platform – M2170
7 Right Platform – M2170NT
8 Right Support and Tanks
9 Diesel Exhaust Fluid Tank
10 Diesel Exhaust Fluid Plumbing
11 Walking Beam – M2170
12 Walking Beam – M2170NT
13 Anti-Shimmy – M2170
14 Anti-Shimmy – M2170NT
15 Casters – Suspended 165-161
16 Drive Wheels and Tires – Ten Bolt
17 Drive Wheels and Tires – Ten Bolt, ECE Certified
18 Drive Wheels and Tires – Twelve Bolt
19 Lift Linkage
20 Lift Linkage Cylinders
21 Float Sensors
22 Center-Link
23 Engine Sub Assembly
24 Fuel System
25 Engine Air Intake
26 Engine Exhaust
27 Engine Cooling System
28 Cooling Module – Left
29 Cooling Module – Right
30 Charge Air Cooler Plumbing
31 Radiator Plumbing
32 Hood
33 Hood Frame
34 Hood Latch Mechanism
35 Hood Gas Shocks – Standard
36 Rear Lights and Bezels – M2170
37 Cab-Forward Lighting and Marking – M2170
38 Rear Lights and Bezels, Cab-Forward Lighting and Marking – M2170NT
39 Front Lights and Mirrors, Engine-Forward Lighting and Marking – M2170NT
40 Roof – Standard and Deluxe Cab
41 Headliner – Radio, Speakers, and Relay Module
42 Roof – Lighting
43 Roof Relay Module – Service Parts
44 Cab GPS Bulkhead/Display Mount
45 Electrical – Autosteer
46 Cab Interior and Upholstery
47 Cab Exterior and Air Intake Stack
48 Cab Suspension
49 Windows
50 Doors
51 Wipers
52 Mirror Arms, Beacons, and Reflectors – M2170
53 Mirror Arms and Beacons – M2170NT
54 Cab Air Conditioning and Heating
55 Cab Air Conditioning and Heating – Service Parts
56 Heating, Ventilation, and Air Conditioning – Chassis
57 Standard Cab Components
58 Deluxe Cab Components
59 Standard Operator’s Seat
60 Standard Seat Suspension
61 Deluxe Operator’s Seat
62 Deluxe Seat Suspension
63 Trainer’s Seat
64 Steering Column and Seat Base
65 Steering Column – Service Parts
66 Ground Speed Lever, Cable, and Display
67 Console Components
68 Steering and Ground Speed Control (under Cab)
69 Neutral Interlock and Pintle Arms
70 Engine Gearbox
71 Traction Drive Pump
72 Traction Drive Pump – Service Parts
73 Left Pump Stack
74 Disc/Knife Drive Pump – Service Parts
75 Lift/Fan Pump – Service Parts
76 Wheel Drive Assembly – Ten Bolt
77 Wheel Drive Assembly – Twelve Bolt
78 Wheel Drive – Service Parts, Ten Bolt
79 Wheel Drive – Service Parts, Twelve Bolt
80 Header Drive – Frame Interface
81 Header Drive – Manifold Multi coupler Assembly
82 Header Drive – Fitting Manifold Frame Assembly
83 Header Drive – Charge Filter Frame Assembly
127 (Option) Counterweights – Rear Ballast, M2170NT
128 (Option) DWA Shut-Off Kit
129 (Option) Float Booster Spring
130 (Option) Float Booster Spring Doubler
131 (Option) High Debris Cooler Intake
132 (Option) Left Drive Headlights
133 (Option) Neutral Setting Service Kit
134 (Option) Quick Couplers
135 (Option) Reel Drop Rate Adjustment
136 (Option) Trimble® Autopilot™ – Electrical
137 (Option) Trimble® Autopilot™ – Hydraulics
138 (Option) Trimble® IMD-900 Adapter Harness
139 (Option) Trimble® TMX Compatibility Kit
140 (Option) Weight Box – M2170
141 (Option) Weight Box – M2170NT
Index
