Macdon Windrower M1240 Parts Catalog 215950 Revision A
Brand: Macdon
Type of Machine: Windrower
Model: Macdon M1240 Windrower
Publication Date: 2022
Parts Number: 215950 Revision A
Number Pages: 346 Pages
Introduction
Serial Number Breaks
Abbreviations
Summary of Changes – M1240 (215950 Rev A)
1 Wheel Legs
2 Left Platform and Toolbox
3 Left Platform Mechanism
4 Right Platform
5 Right Support and Tanks
6 Diesel Exhaust Fluid (DEF) Tank
7 Diesel Exhaust Fluid (DEF) Plumbing
8 Walking Beam
9 Anti-Shimmy
10 Casters – Suspended 165-161
11 Drive Wheels and Tires – Ten Bolt
12 Drive Wheels and Tires – Twelve Bolt
13 Lift Linkage
14 Lift Linkage Cylinders
15 Float Sensors
16 Center-Link
17 Engine Sub Assembly
18 Fuel System
19 Engine Air Intake
20 Engine Exhaust
21 Engine Cooling System
22 Cooling Module – Left
23 Cooling Module – Right
24 Charge Air Cooler Plumbing
25 Radiator Plumbing
26 Hood
27 Hood Frame
28 Hood Latch Mechanism
29 Hood Gas Shocks – Standard
30 Rear Lights and Bezels
31 Cab-Forward Lighting and Marking
32 Roof – Standard and Deluxe Cab
33 Headliner – Radio, Speakers, and Relay Module
34 Roof – Lighting
35 Roof Relay Module – Service Parts
36 Cab GPS Bulkhead/Display Mount
37 Cab Interior and Upholstery
38 Cab Exterior and Air Intake Stack
39 Cab Suspension
40 Windows
41 Doors
42 Wipers
43 Mirror Arms, Beacons, and Reflectors
44 Cab Air Conditioning and Heating
45 Cab Air Conditioning and Heating – Service Parts
46 Heating, Ventilation, and Air Conditioning – Chassis
47 Standard Cab Components
48 Deluxe Cab Components
49 Standard Operator’s Seat
50 Standard Seat Suspension
51 Deluxe Operator’s Seat
52 Deluxe Seat Suspension
53 Trainer’s Seat
54 Steering Column and Seat Base
55 Steering Column – Service Parts
56 Ground Speed Lever, Cable, and Display
57 Console Components
58 Steering and Ground Speed Control (under Cab)
59 Neutral Interlock and Pintle Arms
60 Engine Gearbox – 2018 and Prior
61 Engine Gearbox – 2019 and Later
62 Traction Drive Pump
63 Traction Drive Pump – Service Parts
64 Left-Hand Pump Stack
65 Gear Pump Replace Service Kit
66 Disc/Knife Drive Pump
67 Lift/Fan Pump
68 Wheel Drive Assembly – Ten Bolt
69 Wheel Drive Assembly – Twelve Bolt
70 Wheel Drive – Service Parts, Ten Bolt
71 Wheel Drive – Service Parts, Twelve Bolt
72 Wheel Drive Motor
73 Header Drive (Rotary Disc Only) – Frame Interface
74 Header Drive – Frame Interface
75 Header Drive – Manifold Multi coupler Assembly
76 Header Drive – Fitting Manifold Frame Assembly
77 Header Drive – Charge Filter Frame Assembly
78 Header Drive Manifold (Rotary Disc Only)
79 Drive Manifold (Except Rotary Disc)
80 Float Selector Manifold
81 Charge Manifold
82 Hydraulics – Tank Fittings
83 Hydraulics – Fan/Lift Manifold (Accumulator Replace)
84 Lift/Fan Manifold – Valves and Coils
85 Lift/Fan Manifold – Plugs and Fittings
86 Hydraulics – Fan Drive Lines
87 Hydraulics – Oil Cooler Lines
88 Hydraulics – Frame Fittings
89 Junction Manifold – Service Parts
90 Hydraulics – Charge Lines (2017 and Prior)
91 Hydraulics – Charge Lines, Salami Gear Pump (2018–2019)
92 Hydraulics – Charge Lines, Turolla Gear Pump (2020 and Later)
93 Hydraulics – Open Drive Lines
94 Hydraulics – Closed Drive Lines
95 Hydraulics – Case Drain Cooler Lines
96 Hydraulics – Traction Drive
97 Hydraulics – Control Lines
98 Hydraulics – Lift System
99 Hydraulics – Line Supports
100 Electrical – Chassis
101 Main Fuse Panel
102 Electrical – Chassis Components
103 Chassis Relay Module and Fuse Panel Assembly
104 Chassis Relay Module – Service Parts
105 Electrical – Battery and Cover
106 Electrical – Battery Cables
107 Electrical – Engine
108 Electrical – Firewall Modules
109 Electrical – Wheel Legs
110 Decals – Safety
111 Decals – Information and Reflectors
112 Decals – Product Identification
113 (Option) Bluetooth Software Interface Module
114 (Option) Center-Link Self-Alignment
115 (Option) Coolant Heater Kit – 6 Cylinder
116 (Option) Counterweights – Rear Ballast
117 (Option) Draper and Auger Conversion
118 (Option) DWA Shut-Off Kit
119 (Option) Float Booster Spring
120 (Option) Float Booster Spring Doubler
121 (Option) High Debris Cooler Intake
122 (Option) Neutral Setting Service Kit
123 (Option) Quick Couplers
124 (Option) Reel Drop Rate Adjustment
125 (Option) Service Filters Kit
126 (Option) Trimble® Autopilot™ – Electrical and Display Mount (2018 and Prior)
127 (Option) Trimble® Autopilot™ – Electrical (2019–2021)
128 (Option) Trimble® Autopilot™ – Electrical (2022)
129 (Option) Trimble® Autopilot™ – Hydraulics (2018 and Prior)
130 (Option) Trimble® Autopilot™ – Hydraulics (2019 and Later)
131 (Option) Trimble® EZ-Pilot® – Electrical and Display Mount (2018 and Prior)
132 (Option) Trimble® EZ-Pilot® – Electrical (2019–2021)
133 (Option) Trimble® EZ-Pilot® – Electrical (2022)
134 (Option) Trimble® GFX Compatibility for M1 Series (2017–2021)
135 (Option) Weight Box
Index
Brand: Macdon
Introduction
Abbreviations
1 Wheel Legs
4 Right Platform
8 Walking Beam
9 Anti-Shimmy
13 Lift Linkage
15 Float Sensors
16 Center-Link
18 Fuel System
20 Engine Exhaust
26 Hood
27 Hood Frame
34 Roof – Lighting
39 Cab Suspension
40 Windows
41 Doors
42 Wipers
53 Trainer’s Seat
67 Lift/Fan Pump
81 Charge Manifold
101 Main Fuse Panel
110 Decals – Safety
Index
- Macdon Multi-Crop Header and Hay Conditioner 940 Operators Manual 46005
- Macdon Offset Mount Adapter 901 Supplement Operators Manual 46080
- Macdon Rotary Disc 13 Foot Header R85 Operators Manual
- Macdon Rotary Disc 13-Foot R113 Unloading & Assembly Instructions 214075 Revision A
- Macdon Rotary Disc 13-Foot R85 Unloading & Assembly Instructions
- Macdon Rotary Disc 16 Foot Header R85 Operators Manual
- Harvestec Corn Header 4000 5000 Series Parts Catalog
- Macdon Rotary Disc 16-Foot R85 Unloading & Assembly Instructions
- Harvestec Corn Header 440 630 636 830 836 840 Parts Catalog
- Macdon Rotary Disc Header R113 R116 Parts Catalog 262298 Revision A
- Harvestec Corn Header 6000 Series Parts Catalog
- Macdon Rotary Disc Header R113 R116 Unloading & Assembly Instructions 215368 Revision A
- Macdon Combine Draper Header D1-Series FM100 Unloading and Assembly Instructions
- Macdon Rotary Disc Header R113 Unloading & Assembly Instructions
- Macdon Combine Header 973 974 Operators Manual 147083
