Martin Welker
104
230,310
Macdon Windrower M1170NT M1170NT5 Parts Catalog 215984 Revision A
Brand: Macdon
Type of Machine: Narrow Transport Windrower
Model: Macdon M1170NT M1170NT5 Narrow Transport Windrower
Publication Date: 2022
Parts Number: 215984 Revision A
Number Pages: 352 Pages
Introduction
Abbreviations
Serial Number Breaks
Summary of Changes – M1170NT, M1170NT5 (215984 Rev A)
1 Wheel Legs
2 Left Platform and Toolbox
3 Left Platform Mechanism
4 Right Platform – M1170NT
5 Right Platform – M1170NT5
6 Right Support and Tanks – M1170NT
7 Right Support and Tanks – M1170NT5
8 Diesel Exhaust Fluid Tank – M1170NT
9 Diesel Exhaust Fluid Tank – M1170NT5
10 Diesel Exhaust Fluid Plumbing – M1170NT
11 Diesel Exhaust Fluid Plumbing – M1170NT5
12 Walking Beam
13 Anti-Shimmy
14 Casters – Suspended 165-161
15 Drive Wheels and Tires – Ten Bolt
16 Lift Linkage
17 Lift Linkage Cylinders
18 Float Sensors
19 Center-Link
20 Engine Sub Assembly
21 Fuel System
22 Engine Air Intake
23 Engine Exhaust – M1170NT
24 Engine Exhaust – M1170NT5
25 Engine Cooling System
26 Cooling Module – Left
27 Cooling Module – Right
28 Charge Air Cooler Plumbing – M1170NT
29 Charge Air Cooler Plumbing – M1170NT5
30 Radiator Plumbing – M1170NT
31 Radiator Plumbing – M1170NT5
32 Hood
33 Hood Frame
34 Hood Latch Mechanism
35 Hood Gas Shocks – Standard
36 Rear Lights and Bezels
37 Front Lights and Mirrors
38 Roof – Deluxe Cab
39 Headliner – Radio, Speakers, and Relay Module
40 Roof Relay Module – Service Parts
41 Cab GPS Bulkhead/Display Mount
42 Cab Interior and Upholstery
43 Cab Exterior and Air Intake Stack
44 Cab Suspension
45 Windows
46 Doors
47 Wipers
48 Mirror Arms and Beacons
49 Cab Air Conditioning and Heating
50 Cab Air Conditioning and Heating – Service Parts
51 Heating, Ventilation, and Air Conditioning – Chassis
52 Deluxe Cab Components
53 Deluxe Operator’s Seat
54 Deluxe Seat Suspension
55 Trainer’s Seat
56 Steering Column and Seat Base
57 Steering Column – Service Parts
58 Ground Speed Lever, Cable, and Display
59 Console Components
60 Steering and Ground Speed Control (under Cab)
61 Neutral Interlock and Pintle Arms
62 Engine Gearbox
63 Traction Drive Pump
64 Traction Drive Pump – Service Parts
65 Left Pump Stack
66 Disc/Knife Drive Pump – Service Parts
67 Lift/Fan Pump – Service Parts
68 Wheel Drive Assembly – Ten Bolt
69 Wheel Drive – Service Parts, Ten Bolt
70 Wheel Drive Motor
71 Header Drive – Frame Interface
72 Header Drive – Manifold Multi coupler Assembly
73 Header Drive – Fitting Manifold Frame Assembly
74 Header Drive – Charge Filter Frame Assembly
75 Drive Manifold – Service Parts
76 Float Selector Manifold
77 Charge Manifold
78 Hydraulics – Tank Fittings
79 Hydraulics – Fan/Lift Manifold (Accumulator Replace)
80 Lift/Fan Manifold – Valves and Coils
81 Lift/Fan Manifold – Plugs and Fittings
82 Hydraulics – Fan Drive Lines
83 Hydraulics – Oil Cooler Lines
84 Hydraulics – Frame Fittings
85 Junction Manifold – Service Parts
86 Hydraulics – Charge Lines
87 Hydraulics – Open Drive Lines
88 Hydraulics – Closed Drive Lines
89 Hydraulics – Traction Drive
90 Hydraulics – Control Lines
91 Hydraulics – Lift System
92 Hydraulics – Line Supports
93 Hydraulics – Narrow Transport
94 Hydraulics – Walking Beam
95 Hydraulics – Wheel Legs
96 Secondary Brakes – Germany Only
97 Secondary Brake Hydraulics – Germany Only
98 Secondary Brakes GSL Sensors – Germany Only
99 Secondary Brakes Seat Base – Germany Only
100 Electrical – Chassis
101 Main Fuse Panel
102 Electrical – Chassis Components
103 Chassis Relay Module and Fuse Panel Assembly
104 Chassis Relay Module – Service Parts
105 Electrical – Battery and Cover
106 Electrical – Battery Cables
107 Electrical – Engine, M1170NT
108 Electrical – Engine, M1170NT5
109 Electrical – Firewall Modules
110 Electrical – Wheel Legs
111 Electrical – Narrow Transport Lights
112 Electrical – Narrow Transport Control
113 Decals – Safety
114 Decals – Information and Reflectors
115 Decals – Product Identification
116 (Option) Bluetooth Software Interface Module
117 (Option) Center-Link Self-Alignment
118 (Option) Coolant Heater Kit
119 (Option) Counterweights – Rear Ballast
120 (Option) DWA Shut-Off Kit
121 (Option) Float Booster Spring
122 (Option) High Debris Cooler Intake
123 (Option) Left Drive Headlights
124 (Option) Neutral Setting Service Kit
125 (Option) Quick Couplers
126 (Option) Reel Drop Rate Adjustment
127 (Option) Service Filters Kit
128 (Option) Swath Compressor – Frame
129 (Option) Swath Compressor – Hydraulics and Supports
130 (Option) Trimble® Autopilot™ – Electrical (2021–2022)
131 (Option) Trimble® Autopilot™ – Electrical (2023)
132 (Option) Trimble® Autopilot™ – Hydraulics
133 (Option) Trimble® EZ-Pilot® – Electrical (2021–2022)
134 (Option) Trimble® EZ-Pilot® – Electrical (2023)
135 (Option) Trimble® TMX Compatibility Kit
136 (Option) Trimble® GFX Compatibility for M1 Series (2021–2022)
137 (Option) Aftermarket GPS Steering Wheel Kits
138 (Option) Weight Box – Narrow Transport
Index
