Martin Welker
104
230,310
Macdon Self-Propelled Windrower M205 Parts Catalog 214604 Revision A
Brand: Macdon
Type of Machine: Self-Propelled Windrower
Model: Macdon M205 Self-Propelled Windrower
Publication Date: 2018
Parts Number: 214604 Revision A
Number Pages: 332 Pages
Introduction
Serial Number Breaks
Abbreviations
Summary of Changes – M205 (214604 Rev A)
1 Frame Hose Guards
2 Wheel Legs
3 Platform Stairs – 2010 and Prior
4 Platforms and Toolbox
5 Platform Mechanism
6 Walking Beam
7 Anti-Shimmy
8 Casters – Forked 165-161
9 Casters – Formed 75-16
10 Casters – Forked 10 x 16
11 Casters – Formed 10 x 16
12 Drive Wheels and Tires – Eight Bolt
13 Drive Wheels and Tires – Ten Bolt
14 Lift Linkage
15 Lift Linkage Cylinders
16 Center-Link
17 Engine Sub Assembly
18 Fuel System
19 Tanks (Fuel and Hydraulic)
20 Engine Air Intake – 2017 and Prior
21 Engine Air Intake – 2018 and Later
22 Engine Exhaust
23 Radiator
24 Coolers
25 Cooler Box
26 Screen Cleaner
27 Hood
28 Hood Mechanism
29 Cab Seals, Grommets, Mounts, and Upholstery
30 Cab Suspension
31 Windows
32 Doors
33 Roof and Headliner
34 Headliner Switch Panels
35 Mirror Arms – 2010 and Prior
36 Mirrors and Wipers – 2011 and Later
37 Cab Air Conditioning and Heating – 2014 and Prior
38 Cab Air Conditioning and Heating – 2015 and Later
39 HVAC – Cab Group (2015 and Later)
40 HVAC – Engine Group (2014 and Prior)
41 HVAC – Engine Group (2015 and Later)
42 Steering Column and Seat Base
43 Operator's Seat
44 Seat Suspension Internal Components
45 Trainer's Seat
46 Console Components
47 Ground Speed Lever and Cable
48 Steering and Ground Speed Control (Under Cab)
49 Neutral Interlock and Pintle Arms
50 Engine Gearbox – 2016 and Prior
51 Engine Gearbox – 2017 and Later
52 Traction Drive Pump
53 Traction Drive Pump Repair Parts
54 Header Drive Pump
55 Header Drive Pump Repair Parts
56 Wheel Drive Assembly
57 Wheel Drive Motor Repair Parts
58 Wheel Drive – Bonfiglioli (8 Bolt), 2014 and Prior
59 Wheel Drive – Auburn Gear (8 Bolt), 2014 and Prior
60 Wheel Drive – Auburn Gear (10 Bolt), 2015 and Later
61 Header Lift Manifold
62 Lift Manifold Valve Repair Parts
63 Cooler Bypass
64 Hydraulics – Charge Cooler
65 Hydraulics – Header Drive
66 Hydraulics – Traction Drive
67 Hydraulics – Brake Shift
68 Hydraulics – Lift
69 Hydraulics – Interlock Servo
70 Hydraulics – Draper/Auger Header Drive
71 Draper Conditioner/Auger Header Reverser
72 Draper Header Reel Hydraulics – Couplers
73 Draper Header Reel Hydraulics – Fore-Aft
74 Draper Header Case Drain Kit
75 Electrical – Chassis
76 Electrical – GPS
77 Paint
78 Decals – Safety (2012 and Prior)
79 Decals – Safety (2013 and Later)
80 Decals – Information and Reflectors
81 Decals – Product Identification
82 Decals – Russian
83 Slow Moving Vehicle (SMV) Reflector
84 Draper Header Supports
85 Center-Link Cylinder Lift Kit
86 Auxiliary Lift Valve
87 Warning Beacon
88 Auxiliary Springs
89 Weight Box
90 Lighting and Marking for Cab-Forward Travel
91 Fan Air Baffle Kit
92 Pressure Sensor Kit
93 Hydraulic Autosteer
94 Scoop Kit
95 Sweeps Kit
96 Hood Reinforcement Kit
97 Pre-Cleaner Kit
98 Fan Drive Upgrade and Reversible Fan Kit
99 Cab Suspension Limit Strap Kit
100 M205 Gearbox Service Kit
101 Cab Suspension Rear Bumpers Kit
102 M205 to R85 – Connections
103 Neutral Setting Service Kit
104 (Option) Auxiliary Cooling Package – Frame
105 (Option) Auxiliary Cooling Package – Oil Cooler and Fan Shroud
106 (Option) Auxiliary Cooling Package – Hydraulics
107 (Option) Auxiliary Cooling Package – Electrical
Index
