Macdon Self-Propelled Windrower M1170 Parts Catalog 215980 Revision A
Brand: Macdon
Type of Machine: Self-Propelled Windrower
Model: Macdon M1170 Self-Propelled Windrower
Publication Date: 2022
Parts Number: 215980 Revision A
Number Pages: 332 Pages
Introduction
Abbreviations
Serial Number Breaks
Summary of Changes – M1170 (215980 Rev A)
1 Wheel Legs
2 Left Platform and Toolbox
3 Left Platform Mechanism
4 Right Platform
5 Right Support and Tanks
6 Diesel Exhaust Fluid Tank
7 Diesel Exhaust Fluid Plumbing
8 Walking Beam
9 Anti-Shimmy
10 Casters – Suspended 165-161
11 Drive Wheels and Tires – Ten Bolt
12 Drive Wheels and Tires – Twelve Bolt
13 Lift Linkage
14 Lift Linkage Cylinders
15 Float Sensors
16 Center-Link
17 Engine Sub Assembly
18 Fuel System
19 Engine Air Intake
20 Engine Exhaust
21 Engine Cooling System
22 Cooling Module – Left
23 Cooling Module – Right
24 Charge Air Cooler Plumbing
25 Radiator Plumbing
26 Hood
27 Hood Frame
28 Hood Latch Mechanism
29 Hood Gas Shocks – Standard
30 Rear Lights and Bezels
31 Cab-Forward Lighting and Marking
32 Roof – Standard and Deluxe Cab
33 Roof – Lighting
34 Headliner – Radio, Speakers, and Relay Module
35 Roof Relay Module – Service Parts
36 Cab GPS Bulkhead/Display Mount
37 Cab Interior and Upholstery
38 Cab Exterior and Air Intake Stack
39 Cab Suspension
40 Windows
41 Doors
42 Wipers
43 Mirror Arms, Beacons, and Reflectors
44 Cab Air Conditioning and Heating
45 Cab Air Conditioning and Heating – Service Parts
46 Heating, Ventilation, and Air Conditioning – Chassis
47 Standard Cab Components
48 Deluxe Cab Components
49 Standard Operator’s Seat
50 Standard Seat Suspension
51 Deluxe Operator’s Seat
52 Deluxe Seat Suspension
53 Trainer’s Seat
54 Steering Column and Seat Base
55 Steering Column – Service Parts
56 Ground Speed Lever, Cable, and Display
57 Console Components
58 Steering and Ground Speed Control (under Cab)
59 Neutral Interlock and Pintle Arms
60 Engine Gearbox
61 Traction Drive Pump
62 Traction Drive Pump – Service Parts
63 Left-Hand Pump Stack
64 Gear Pump Replace Service Kit
65 Disc/Knife Drive Pump – Service Parts
66 Lift/Fan Pump – Service Parts
67 Wheel Drive Assembly – Ten Bolt
68 Wheel Drive Assembly – Twelve Bolt
69 Wheel Drive – Service Parts, Ten Bolt
70 Wheel Drive – Service Parts, Twelve Bolt
71 Wheel Drive Motor
72 Header Drive – Frame Interface
73 Header Drive – Manifold Multi coupler Assembly
74 Header Drive – Fitting Manifold Frame Assembly
75 Header Drive – Charge Filter Frame Assembly
76 Drive Manifold – Service Parts
77 Float Selector Manifold
78 Charge Manifold
79 Hydraulics – Tank Fittings
80 Hydraulics – Fan/Lift Manifold (Accumulator Replace)
81 Lift/Fan Manifold – Valves and Coils
82 Lift/Fan Manifold – Plugs and Fittings
83 Hydraulics – Fan Drive Lines
84 Hydraulics – Oil Cooler Lines
85 Hydraulics – Frame Fittings
86 Junction Manifold – Service Parts
87 Hydraulics – Charge Lines, Salami Gear Pump (2019 and Prior)
88 Hydraulics – Charge Lines, Turolla Gear Pump (2020 and Later)
89 Hydraulics – Open Drive Lines
90 Hydraulics – Closed Drive Lines
91 Hydraulics – Traction Drive
92 Hydraulics – Control Lines
93 Hydraulics – Lift System
94 Hydraulics – Line Supports
95 Electrical – Chassis
96 Main Fuse Panel
97 Electrical – Chassis Components
98 Chassis Relay Module and Fuse Panel Assembly
99 Chassis Relay Module – Service Parts
100 Electrical – Battery and Cover
101 Electrical – Battery Cables
102 Electrical – Engine
103 Electrical – Firewall Modules
104 Electrical – Wheel Legs
105 Decals – Safety
106 Decals – Information and Reflectors
107 Decals – Product Identification
108 (Option) Bluetooth Software Interface Module
109 (Option) Center-Link Self-Alignment
110 (Option) Coolant Heater Kit
111 (Option) Counterweights – Rear Ballast
112 (Option) DWA Shut-Off Kit
113 (Option) Float Booster Spring
114 (Option) Float Booster Spring Doubler
115 (Option) High Debris Cooler Intake
116 (Option) Neutral Setting Service Kit
117 (Option) Quick Couplers
118 (Option) Reel Drop Rate Adjustment
119 (Option) Service Filters Kit
120 (Option) Trimble® Autopilot™ – Electrical and Display Mount (2018 and Prior)
121 (Option) Trimble® Autopilot™ – Hydraulics (2018 and Prior)
122 (Option) Trimble® Autopilot™ – Electrical (2019–2022)
123 (Option) Trimble® Autopilot™ – Electrical (2023)
124 (Option) Trimble® Autopilot™ – Hydraulics (2019 and Later)
125 (Option) Trimble® EZ-Pilot® – Electrical and Display Mount (2018 and Prior)
126 (Option) Trimble® EZ-Pilot® – Electrical (2019–2022)
127 (Option) Trimble® EZ-Pilot® – Electrical (2023)
128 (Option) Trimble® GFX Compatibility for M1 Series (2017–2022)
129 (Option) Trimble® TMX Compatibility Kits
130 (Option) Aftermarket GPS Steering Wheel Kits
131 (Option) Weight Box
Index
Brand: Macdon
Introduction
Abbreviations
1 Wheel Legs
4 Right Platform
8 Walking Beam
9 Anti-Shimmy
13 Lift Linkage
15 Float Sensors
16 Center-Link
18 Fuel System
20 Engine Exhaust
26 Hood
27 Hood Frame
33 Roof – Lighting
39 Cab Suspension
40 Windows
41 Doors
42 Wipers
53 Trainer’s Seat
60 Engine Gearbox
78 Charge Manifold
96 Main Fuse Panel
105 Decals – Safety
Index
- Macdon Multi-Crop Header and Hay Conditioner 940 Operators Manual 46005
- Macdon Offset Mount Adapter 901 Supplement Operators Manual 46080
- Macdon Rotary Disc 13 Foot Header R85 Operators Manual
- Macdon Rotary Disc 13-Foot R113 Unloading & Assembly Instructions 214075 Revision A
- Macdon Rotary Disc 13-Foot R85 Unloading & Assembly Instructions
- Macdon Rotary Disc 16 Foot Header R85 Operators Manual
- Harvestec Corn Header 4000 5000 Series Parts Catalog
- Macdon Rotary Disc 16-Foot R85 Unloading & Assembly Instructions
- Harvestec Corn Header 440 630 636 830 836 840 Parts Catalog
- Macdon Rotary Disc Header R113 R116 Parts Catalog 262298 Revision A
- Harvestec Corn Header 6000 Series Parts Catalog
- Macdon Rotary Disc Header R113 R116 Unloading & Assembly Instructions 215368 Revision A
- Macdon Combine Draper Header D1-Series FM100 Unloading and Assembly Instructions
- Macdon Rotary Disc Header R113 Unloading & Assembly Instructions
- Macdon Combine Header 973 974 Operators Manual 147083
