Macdon Precision Header SwathMaster Rake-Up Parts Catalog
Brand: Macdon
Type of Machine: Precision Header , Swath Master , Rake-Up
Model:
Macdon 13ft & 15ft Precision Header
Macdon 10ft 12ft 14ft and 16ft Pickups
Macdon Rake Up
10S Grass Seed, 10S, 10M Grass Seed, 10M, 12S Grass Seed
12S, 12M Grass Seed, 12M, 14M, 16M
Macdon 12B 12BGS 14B 16B SwathMaster
Release Date: 2004
Parts Number: 53-10039-01
Number Of Pages: 171 Pages
Introduction
Section A – Rake Up
Hold down Assembly
Draper And Gear Box Drive – Conventional
Draper And Gear Box Drive – Grass Seed
Drive End Rotor
Idler End Rotor
Main Gear Box
Shield Assembly
Main Frame Assembly
Section B – Swath master
Hold down Assembly
Roller, Tire, And Frame Assembly– Conventional
Roller, Tire, And Frame Assembly– Grass Seed
16 Ft Roller Support
Draper And Shield Assembly– Conventional
Draper And Shield Assembly– Grass Seed
Pickup Drive
Suspension Assembly
Section C – Rake Up/Swath master
Optional Mechanical Hold down
Hydraulic Hold down Lift Kit (S/N: 2001 To Present)
Hydraulic Hold down Lift Kit (S/N: Pre 2001)
Hydraulic Cylinder
Hydraulic Cylinder (S/N: Pre 2001)
Section D – Pick Up Options
Alternate End Kit – Rake-Up (Standard)
Alternate End Kit – Rake-Up (Mirror)
Alternate End Kit – Swath master
Pea Coulter
Miscellaneous Optional Kits / Parts
Section E – Lubricants, Service Tools, & Replacement Parts
Rake-Up
Rake-Up & Swath master
Section F –Header
Table Assembly
Table Assembly (S/N:13h-99001 To 13h-99099, 15h-99001 To 15h-99099)
Auger Drive & Support (Rh)
Auger Support (Lh)
Auger Assembly
John Deere
New Holland
Caterpillar
Case
Agco
Hydraulics
John Deere
New Holland/Case
Caterpillar
Agco
Extremity Light Assembly
Addapters
John Deere
New Holland
Caterpillar
Agco
Case
Section F –Header (Continued)
Drive Shaft
John Deere
New Holland
Caterpillar
Agco
Case
Speed Control
John Deere
Caterpillar
Agco
Height Control
John Deere
Notes
Brand: Macdon
Model:
Macdon Rake Up
Release Date: 2004
Introduction
Section A – Rake Up
Hold down Assembly
Drive End Rotor
Idler End Rotor
Main Gear Box
Shield Assembly
Main Frame Assembly
Hold down Assembly
Pickup Drive
Suspension Assembly
Hydraulic Cylinder
Pea Coulter
Rake-Up
Section F –Header
Table Assembly
Auger Support (Lh)
Auger Assembly
John Deere
New Holland
Caterpillar
Case
Agco
Hydraulics
John Deere
New Holland/Case
Caterpillar
Agco
Addapters
John Deere
New Holland
Caterpillar
Agco
Case
Drive Shaft
John Deere
New Holland
Caterpillar
Agco
Case
Speed Control
John Deere
Caterpillar
Agco
Height Control
John Deere
Notes
- Macdon Multi-Crop Header and Hay Conditioner 940 Operators Manual 46005
- Macdon Offset Mount Adapter 901 Supplement Operators Manual 46080
- Macdon Rotary Disc 13 Foot Header R85 Operators Manual
- Macdon Rotary Disc 13-Foot R113 Unloading & Assembly Instructions 214075 Revision A
- Macdon Rotary Disc 13-Foot R85 Unloading & Assembly Instructions
- Macdon Rotary Disc 16 Foot Header R85 Operators Manual
- Harvestec Corn Header 4000 5000 Series Parts Catalog
- Macdon Rotary Disc 16-Foot R85 Unloading & Assembly Instructions
- Harvestec Corn Header 440 630 636 830 836 840 Parts Catalog
- Macdon Rotary Disc Header R113 R116 Parts Catalog 262298 Revision A
- Harvestec Corn Header 6000 Series Parts Catalog
- Macdon Rotary Disc Header R113 R116 Unloading & Assembly Instructions 215368 Revision A
- Macdon Combine Draper Header D1-Series FM100 Unloading and Assembly Instructions
- Macdon Rotary Disc Header R113 Unloading & Assembly Instructions
- Macdon Combine Header 973 974 Operators Manual 147083
