Martin Welker
107
235,284
Macdon FlexDraper Header FD2 Series FM200 Parts Catalog
Brand: Macdon
Type of Machine: FlexDraper Header
Model:
Macdon FD225 FD230 FD235 FD240 FD245 FD241 FD250 FlexDraper Header
Macdon FM200 Float Module For Combines
List Of File:
FD2 Series FM200 Parts Catalog 262612 Revision A
FD2 Series FM200 Parts Catalog 262613 Revision A
FD2 Series FM200 Parts Catalog 262614 Revision A
Introduction
Abbreviations
Serial Number Breaks
Summary of Changes – FD2 Series and FM200 (MD #262612 Rev A)
1 Header Frame Components
2 Header Frame End Panels
3 Header Frame – Split Frame Hardware
4 Manual Case, Retaining Pin, and Knife Storage
5 Transition Pan
6 Divider Cones
7 Divider Rods and Storage
8 End shields – MacDon
9 End shields – Case
10 End shields – New Holland
11 End shield Mount Components
12 Draper
13 Draper – End shields Panels (FD225)
14 Draper – End shields Panels (FD230, FD235, FD240, and FD241)
15 Draper – End shields Panels (FD245 and FD250)
16 Draper – Tensioner
17 Draper – Drive Roller
18 Draper – Decks and Tracks (FD225)
19 Draper – Decks and Tracks (FD230, FD235, FD240, and FD241)
20 Draper – Decks and Tracks (FD245 and FD250)
21 Draper – Seals (FD225)
22 Draper – Seals (FD230, FD235, and FD240)
23 Draper – Seals (FD241, FD245, and FD250)
24 Draper Deflectors – Narrow
25 Balance Linkage
26 Flex Linkage Shield – Back tube Hinge
27 Flex Linkage Shield – Single Reel (FD225) and Double Reel (FD230, FD235, FD240, and FD241)
28 Flex Linkage Shield – Triple Reel (FD240)
29 Flex Linkage Shield – Triple Reel (FD245 and FD250)
30 Guards, Hold-Downs, and Cutter bar Shoes – Single Knife, Pointed (FD225, FD230, FD235, and FD240)
31 Guards, Hold-Downs, and Cutter bar Shoes – Double Knife, Pointed (FD235, FD240, FD241, FD245, and
FD250)
32 Guards, Hold-Downs, and Cutter bar Shoes – Single Knife, PlugFree™ (FD225, FD230, FD235, and FD240)
33 Guards, Hold-Downs, and Cutter bar Shoes – Double Knife, PlugFree™ (FD240, FD241, FD245, and FD250)
34 Knives – Single-Knife Headers (FD225)
35 Knives – Single-Knife Headers (FD230, FD235, and FD240)
36 Knives – Double-Knife Headers (FD235 and FD240)
37 Knives – Double-Knife Headers (FD241)
38 Knives – Double-Knife Headers (FD245)
39 Knives – Double-Knife Headers (FD250)
40 Knife Drive – Single and Double Knife
41 Knife Drive Box
42 Reel Support Arm and Lift Cylinders – Center Arm (FD230, FD235, FD240, and FD241)
43 Reel Support Arm and Lift Cylinders – Center Arm, Right Side (FD240, FD245, and FD250)
44 Reel Support Arm and Lift Cylinders – Center Arm, Left Side (FD240, FD245, and FD250)
45 Reel Support Arm and Lift Cylinders – Outer Arms, Single Reel
46 Reel Support Arm and Lift Cylinders – Outer Arms, Double and Triple Reel
47 Reel Arm Components – Right Arm, Single Reel (FD225)
48 Reel Arm Components – Right Arm, Double Reel (FD230, FD235, FD240, and FD241)
49 Reel Arm Components – Right Arm, Triple Reel (FD240, FD245, and FD250)
50 Reel Arm Components – Center Arm (FD230, FD235, FD240, FD241, FD245, and FD250)
51 Reel Arm Components – Center Right Arm, Triple Reel (FD240, FD245, and FD250)
52 Reel Arm Components – Left Arm (FD225, FD230, FD235, FD240, FD241, FD245, and FD250)
53 Reel – Drive, Right Arm, Single Reel
54 Reel – Drive, Center Arm, Double and Triple Reel
55 Reel – Cam Components, Right Arm
56 Reel – Cam Components, Center Right Arm, Triple Reel (FD240, FD245, and FD250)
57 Reel – Tine Tube
58 Reel Discs – Cam End and Linkage (FD225, FD230, FD235, FD240, FD241, FD245, and FD250)
59 Reel Discs – Mid Span, Cam Side (FD225, FD235, FD240, FD241, FD245, and FD250)
60 Reel Discs – Mid Span, Tail Side (FD225, FD230, FD235, FD240, FD241, FD245, and FD250)
61 Reel Discs – Tail End (FD225, FD230, FD235, FD240, FD241, FD245, and FD250)
62 Reel – Center Tubes, Single Reel
63 Reel – Center Tubes, Double Reel
64 Reel – Center Tubes, Triple Reel
65 Reel – End shields, Cam End, Inboard
66 Reel – End shields, Cam End, Outboard
67 Reel – End shields, Tail End, Inboard
68 Reel – End shields, Tail End, Outboard
69 Skid Shoes – End and Center
70 Hydraulics – Manifold Fittings and Fasteners
71 Hydraulics – Manifold Plugs
72 Hydraulics – Knife Drive, Single and Double Knife, Left Side (FD225, FD230, FD235, FD240, FD241,
and FD245)
73 Hydraulics – Knife Drive, Double Knife, Left Side (FD250)
74 Hydraulics – Knife Drive, Double Knife, Right Side (FD235, FD240, and FD241)
75 Hydraulics – Knife Drive, Double Knife, Right Side (FD245 and FD250)
76 Hydraulics – Draper Drive (FD225, FD230, FD235, FD240, and FD241)
77 Hydraulics – Draper Drive (FD245 and FD250)
78 Hydraulics – Lift and Fore-Aft, Single Reel, Left Arm (FD225)
79 Hydraulics – Lift and Fore-Aft, Single Reel, Right Arm (FD225)
80 Hydraulics – Lift and Fore-Aft, Double Reel, Left Arm (FD230, FD235, FD240, and FD241)
81 Hydraulics – Lift and Fore-Aft, Double Reel, Center Arm (FD230, FD235, FD240, and FD241)
82 Hydraulics – Lift and Fore-Aft, Double Reel, Right Arm (FD230 and FD235)
83 Hydraulics – Lift and Fore-Aft, Double Reel, Right Arm (FD240 and FD241)
84 Hydraulics – Lift and Fore-Aft, Triple Reel, Left Arm (FD240, FD245, and FD250)
85 Hydraulics – Lift and Fore-Aft, Triple Reel, Center Arm, Left Side (FD240, FD245, and FD2
86 Hydraulics – Lift and Fore-Aft, Triple Reel, Center Arm, Right Side (FD240, FD245, and FD
87 Hydraulics – Lift and Fore-Aft, Triple Reel, Right Arm (FD240, FD245, and FD250)
88 Hydraulics – Upper Cross Auger
89 Hydraulics – Reel Drive, Single Reel
90 Hydraulics – Reel Drive, Double and Triple Reel
91 Hydraulics – ContourMax™, Contour Wheels (FD225 and FD230)
92 Hydraulics – ContourMax™, Contour Wheels (FD235)
93 Hydraulics – ContourMax™, Contour Wheels (FD240, FD241, FD245, and FD250)
94 Hydraulics – VertiBlade™ Vertical Knife (FD225, FD230, FD235, FD241, and FD245)
95 Hydraulics – VertiBlade™ Vertical Knife (FD250)
96 Hydraulic Line Covers (FD225)
97 Hydraulic Line Covers (FD230, FD235, and FD240)
98 Hydraulic Line Covers (FD241, FD245, and FD250)
99 Electrical – Harness (FD225)
100 Electrical – Harness (FD230, FD235, FD240, FD241, FD245, and FD250)
101 Electrical – Clearance Lights
102 Electrical – Reel Height Sensor
103 Electrical – Reel Fore-Aft Sensor (2023 and Prior)
104 Electrical – Reel Fore-Aft Sensor (2024 and Later)
105 Electrical – Reel Speed Sensor, AGCO and CLAAS
106 Electrical – Reel Speed Sensor, John Deere
107 Electrical – Reel Speed Sensor, Rostselmash
108 Decals and Reflectors – FD2 Series
109 Decals – Product Identification
110 Decals – Product Identification, Case
111 Decals – Product Identification, New Holland
112 Decals – French
113 Decals – Portuguese
114 Decals – Russian
115 Decals – Spanish
116 Paint
117 (Option) Brace Tube Kits
118 (Option) ContourMax™ – Outer Contour Wheels
119 (Option) ContourMax™ – Inner Contour Wheels
120 (Option) ContourMax™ – Gauge Service Kit
121 (Option) ContourMax™ – Height Sensing – Case, New Holland, and John Deere X9 Series
122 (Option) Crop Lifters and Storage Rack
123 (Option) Divider Storage Bracket
124 (Option) EasyMove™ – Slow Speed Transport, Base Kit and Stabilizer Wheels
125 (Option) EasyMove™ – Slow Speed Transport, Wheels, Tires, and Tow Poles
126 (Option) End shield Conversion Kits
127 (Option) Flex Linkage Stop Repair
128 (Option) Floating Crop Dividers
129 (Option) Four-Point Guard Kits, Single Knife
130 (Option) Four-Point Guard Kits, Double Knife
131 (Option) Header Tilt Foot Switch
132 (Option) High Wear Skid Shoes
133 (Option) Lodged Crop Reel Fingers
134 (Option) Reel Tine Tube Conversion Kits – Double Reel, 5 Bat to 6 Bat
135 (Option) Reel Tine Tube Conversion Kits – Double Reel, 6 Bat to 9 Bat
136 (Option) Reel – Two Speed
137 (Option) Rice Divider Rods
138 (Option) Rock Retarder Kit
139 (Option) Service Kit – Pointed Guards, Coarse Knives
140 (Option) Service Kit – PlugFree™ Guards, Coarse Knives
141 (Option) Service Kit Plus – Single Knife
142 (Option) Service Kit Plus – Double Knife
143 (Option) Side Hill Stabilizer Kit
144 (Option) Stabilizer Wheels
145 (Option) Steel Finger Kit
146 (Option) Steel Reel End Finger Kits
147 (Option) Stubble Lights
148 (Option) Sunflower Attachment – Base Kit – Lean Bar and Deflectors
149 (Option) Sunflower Attachment – Base Kit – Pans and Supports
150 (Option) Sunflower Attachment – Deflector Kits (Double Reel)
151 (Option) Sunflower Attachment – Deflector Kits (Triple Reel)
152 (Option) Sunflower Attachment – Pans
153 (Option) Upper Cross Auger – Two-Piece Auger (FD225, FD230, FD235, and FD241)
154 (Option) Upper Cross Auger – Three-Piece Auger (FD240, FD245, and FD250)
155 (Option) VertiBlade™ Vertical Knife Kit
156 (Option) VertiBlade™ Vertical Knife Components
157 Frame Components – Float Module
158 Pump, Gearbox, and Input Drive (Integrated Hydraulic System)
159 Pump Assembly (Integrated Hydraulic System)
160 Integrated Pump – Service Parts (Integrated Hydraulic System)
161 Pump, Gearbox, and Input Drive (Modular Hydraulic System)
162 Pump Assembly (Modular Hydraulic System)
163 Gearbox Brace (Modular Hydraulic System)
164 Gearbox Assembly
165 Input Drive Assembly
166 Input Driveline and Support
167 Input Driveline and Support – High Angle
168 Input Driveline Conversion Kits
169 Auger Drum and Internal Components
170 Auger Assembly – Right Arm
171 Auger Assembly – Left Arm
172 Auger – Float Linkage
173 Auger Completion
174 Auger Conversion Kits – Fingers and Flighting
175 Auger – Crop Deflector Kits
176 Auger – Grease Lines
177 Float Linkage and Float Setting and Measuring
178 Float Lock Pivot Rework Kit
179 Float Springs
180 Float Module Attaching and Filler Components – FM200 to FD2 Series (2021 and Prior)
181 Float Module Attaching and Filler Components – FM200 to FD2 Series (2022 and Later)
182 Feed Deck – Frame, Pivot Pins, and Front Support
183 Feed Deck – Draper
184 Feed Deck – Drive/Idler Roller and Tensioner
185 Feed Deck – Pans and Fillers
186 Hydraulics – Center-Link and Header Tilt / Reel Fore-Aft
187 Hydraulics – Feed Deck (Integrated Hydraulic System)
188 Hydraulics – Suction and Return (Integrated Hydraulic System)
189 Hydraulics – Feed Deck (Modular Hydraulic System)
190 Hydraulics – Suction and Return (Modular Hydraulic System)
191 Hydraulics – Drives and Float Module Manifold (Modular Hydraulic System)
192 Hydraulics – Drive Manifold Assembly, Service Parts (Modular Hydraulic System)
193 Hydraulics – Double Reel, Float Module to Header Manifold (Integrated Hydraulic System)
194 Hydraulics – Triple Reel, Float Module to Header Manifold (Integrated Hydraulic System)
195 Hydraulics – Double Reel, Float Module to Header Manifold (Modular Hydraulic System)
196 Hydraulics – Triple Reel, Float Module to Header Manifold (Modular Hydraulic System)
197 Electrical – Base (Integrated Hydraulic System)
198 Electrical – Base (Modular Hydraulic System)
199 Electrical – FM200 to Combine Cab
200 Decals and Reflectors – FM200
201 Challenger®, Massey Ferguson®, and Gleaner® – Float Module Completion
202 Challenger®, Massey Ferguson®, and Gleaner® – Hydraulic/Electrical Completion
203 IDEAL™ Series – Float Module Completion
204 IDEAL™ Series – Hydraulic/Electrical Completion
205 Challenger®, Massey Ferguson®, and IDEAL™ Series – Auger Completion
206 Case IH – Float Module Completion
207 Case IH – Hydraulic/Electrical Completion
208 Case IH 2300/2500 Series – Float Module Completion
209 Case IH 2300/2500 Series – Hydraulic/Electrical Completion
210 CLAAS – Float Module Completion
211 CLAAS – Hydraulic/Electrical Completion (2022 and Prior)
212 CLAAS – Hydraulic Completion (2023 and Later)
213 CLAAS – Electrical Completion (2023 and Later)
214 CLAAS – Auger Completion
215 John Deere S Series – Float Module Completion
216 John Deere S and T Series – Hydraulic/Electrical Completion
217 John Deere T Series – Float Module Completion
218 John Deere X9 Series – Float Module Completion
219 John Deere X9 Series – Hydraulic Completion
220 John Deere X9 Series – Electrical Completion
221 New Holland CR/CX – Float Module Completion
222 New Holland CR/CX – Hydraulic/Electrical Completion
223 New Holland CR/CX – Auger Completion
224 New Holland CR/CX – Flighting Completion
225 New Holland CR/CX – Deflector Completion
226 New Holland 10 Volt Auto Header Height Control Adapter Kit
227 Rostselmash – Float Module Completion
228 Rostselmash – Hydraulic/Electrical Completion
229 (Option) Auger Flighting Kits
230 (Option) FM200 Full Interface Filler – FD2 Series
231 (Option) FM200 Fillers and Links
232 (Option) Hillside Extension
233 (Option) Integration Kit – CLAAS
234 (Option) Module Programming Kit
235 (Option) Stripper Bars
Index
