Linkbelt Mobile Crane ATC-3250 Parts Manual
Link-Belt Mobile Crane ATC-3250 Parts Manual
Brand: Link-Belt
Type of Machine: Mobile Crane
Type of Manual: Parts Catalog, Parts List
Model: Link-Belt ATC-3250 Mobile Crane
List of Files:
Key Sheet And General Information R4K1-1678.pdf (1 Pages)
1085 - ATC-3250 Annex (Vendor Parts).pdf (306 Pages)
1085 - ATC-3250 Lower Parts.pdf (744 Pages)
1085 - ATC-3250 Upper Parts.pdf (562 Pages)
Detail Contents:
1085 - ATC-3250 Annex (Vendor Parts):
ATC-3250
INDEX
ANNEX
34201831000 IDLER PULLEY ASSY
34344561500 HOSE REEL ASSY
34344561600 HOSE REEL ASSY
36018130001 TELESCOPIC CYLINDER ASSY
36052990000 HYDRAULIC CYLINDER ASSY
36053390000 HYDRAULIC CYLINDER ASSY
36053400000 HYDRAULIC CYLINDER ASSY
36161300000 CABLE DRUM ASSY
36190212000 INDICATOR GAUGE AML
36192971000 SWITCH AMPLIFIER AML
36604530000 LOWERING BRAKE VALVE ASSY
36625810000 CHECK VALVE ASSY
36647090000 PRESSURE RELIEF VALVE ASSY
36647180000 SOLENOID VALVE ASSY
36710960000 HOSE REEL ASSY
36710970000 HOSE REEL ASSY
99700576892 TOW HOOK ASSY
99702105405 SOLENOID VALVE 5/2 ASSY
99707004972 MULTI WAY VALVE 3/2
99707005415 RELAY VALVE ASSY
99707005416 BRAKE VALVE ASSY
99707005656 FLOW INDICATOR ASSY
99707005851 BLEED VALVE ASSY
99707006055 STEER CYLINDER ASSY
99707006057 STEER CYLINDER
99707006355 MULTI WAY VALVE 4/2
99707006543 RESERVOIR ASSY
99707007086 FILLER TUBE ASSY
99707007332 CONTROL BLOCK ASSY
99707007563 REFRIGERANT LINE
99707007564 REFRIGERANT LINE
99707007780 REFRIGERANT LINE
99707008177 SUSPENSION CYLINDER ASSY
99707008178 SUSPENSION CYLINDER ASSY
99707008198 MEASUREMENT OF LENGTHS
99707008308 COMPRESSED-AIR PURIFYNG DRYING ASSY
99707009791 CONTROL BLOCK ASSY
99707010421 HOUSING ASSY
99707013605 SOLENOID VALVE 3/2
99707013917 AXIAL PISTON MOTOR
99707013947 CONDENSOR
99707014041 CONTROL BLOCK ASSY
99707014068 CONTROL BLOCK
99707014070 BRAKE VALVE ASSY
99707014400 VALVE ASSY
99707014404 SLIP RING BULK ASSY
99707014498 RETURN FLOW FILTER ASSY
99707014510 HYDR ACCUMULATOR ASSY
99707014512 HYDR ACCUMULATOR ASSY
99707014556 REFRIGERANT LINE
99707015480 AIR DEHUMIDIFIER ASSY
99707015715 AXIAL PISTON ASSY
99707015800 SLEWING GEAR DRIVE ASSY
99707016300 AXIAL PISTON PUMP ASSY
99707016496 CONTROL BLOCK ASSY
99707016576 EXTENDING CYLINDER ASSY
99707016581 MULTI WAY VALVE -3/2 ASSY
99707017163 CABLE WINCH ASSY
99707017213 AXIAL PISTON MOTOR
99707017246 CABLE DRUM
99707017851 OIL COOLING SYSTEM
99707018855 LOCK VALVE TRUNK
99707018993 CONTROL BLOCK ASSY
99707019158 HEATER Thermo 90ST
99707019577 SHORING CYLINDER ASSY
99707019578 SHORING CYLINDER ASSY
99707021830 SUPPORT PLATE ASSY
99707022294 DERRICK CYLINDER ASSY
99707022490 CABLE WINCH ASSY
99707030010 MULTIPLE DISC BRAKE wearing parts
99707300332 RADIAL PISTON ASSY
99707308259 CONTROL VALVE ASSY
99707309314 PUMP ASSY
99707700823 BRACKET ASSY
99707706108 LOCK VALVE TRUNK ASSY
99707706137 MULTI WAY VALVE 2/2
99707711742 AXIAL PISTON MOTOR CPL
99707723331 CONTROL BLOCK ASSY
99707723401 BRAKE CYLINDER ASSY
99707731617 RELAY VALVE ASSY
99707738833 WEIGHT ASSY
99707757941 STEERING ROD ASSY
99707759800 ANGLE GEAR ASSY
99707764164 ANEMOMETER ASSY
99707765496 WEIGHT ASSY with bracket
99707766160 PRESSURE RELIEF VALVE ASSY
99707767776 STEERING ROD ASSY
99707771119 DOOR HANDLE
99707771204 TORQUE STRUT ASSY
99707771205 TORQUE STRUT ASSY
99707771515 SUPPORT PLATE ASSY
99707773701 SOCKET PIN ASSY
99707775397 FILLER TUBE ASSY
99707777788 CONTROL BLOCK
99707777792 AXIAL PISTON PUMP ASSY
99707777793 VALVE ASSY
99707778643 PROXIMITY SWITCH ASSY
99707778781 REMOTE CONTROL UNIT right
99707780653 RETURN FLOW FILTER ASSY
99707781013 ROLLER RETAINER ASSY
99707781017 CHAIN ASSY carry in
99707781053 STEERING GEAR ASSY
99707781059 TORQUE STRUT ASSY
99707781092 JOINT SHAFT
99707781093 JOINT SHAFT
99707781095 JOINT SHAFT
99707781096 JOINT SHAFT
99707781121 COUPLING
99707781257 WATER SEPARATOR ASSY
99707781287 COVER ASSY
99707781288 CASE ASSY
99707781316 STEERING ROD ASSY
99707781751 CARDAN SHAFT BEARING
99707782152 PROXIMITY SWITCH ASSY
99707783582 AXIAL PISTON MOTOR ASSY
99707786051 STEERING ROD ASSY
99707787961 SOCKET PIN
99707790180 TRANSPORT SUPPORT IN ASSY
99707790483 DERRICK CYLINDER ASSY
99707791193 ROLLER RETAINER ASSY
99707791239 CHAIN ASSY extend
99707791244 CHAIN ASSY extend
99707791497 CASE ASSY
99707791500 CASE ASSY
99707792026 REMOTE CONTROL UNIT left
99707793678 LOCK VALVE TRUNK
99707796290 SHORING CYLINDER
99707796291 SHORING CYLINDER
99707797128 ANEMOMETER ASSY
99707797218 FLOW INDICATOR ASSY
99707797923 HYDRAULIC CYLINDER ASSY
99707799306 EXTENDING CYLINDER ASSY
99708408185 BALL JOINT
99708410731 BRAKE CYLINDER
99708410808 COUPLING HEAD color of cover red
99708410809 COUPLING HEAD color of cover yellow
1085 - ATC-3250 Lower Parts:
ATC-3250
TERMS/TERMINOLOGY
INDEX - KEYSHEET
0000-00 GENERAL ARRANGEMENT ASSEMBLIES
0100-05 FRAME
0100-06 FRAME ASSY
0102-01 SHORING ASSY front
0102-02 SHORING ASSY front
0103-01 SHORING ASSY rear
0103-02 SHORING ASSY rear
0105-01 SUPPORT PLATE INSTALLATION
0106-01 FASTENING PARTS
0161-01 SNATCH BLOCK HOLDER
0200-01 STEERING AXLE ASSY I 10x8
0200-02 AXLE HOUSING
0200-03 WHEEL BRAKE ASSY left
0200-04 WHEEL BRAKE ASSY right
0200-05 EXPANDER UNIT ASSY
0200-06 PLANETARY GEAR DRIVE
0200-07 AXLE DRIVE
0200-10 STEERING AXLE ASSY I 10x8
0200-11 AXLE HOUSING
0200-12 AXLE DRIVE
0202-01 STEERING AXLE ASSY II 10x8
0202-02 AXLE HOUSING
0202-03 PLANETARY GEAR DRIVE
0202-04 AXLE DRIVE
0202-10 STEERING AXLE ASSY II 10x8
0202-11 AXLE HOUSING
0202-12 AXLE DRIVE
0204-01 RIGID AXLE ASSY III
0204-02 WHEEL BRAKE ASSY
0204-03 EXPANDER UNIT ASSY
0204-08 RIGID AXLE III
0204-10 RIGID AXLE III
0288-01 DRIVE 10x8
0300-01 STEERING AXLE ASSY IV
0300-02 AXLE HOUSING
0300-03 AXLE DRIVE
0300-10 STEERING AXLE ASSY IV
0300-11 AXLE HOUSING
0300-12 AXLE DRIVE
0301-01 STEERING AXLE ASSY V
0301-02 AXLE HOUSING
0301-03 AXLE DRIVE ASSY
0301-10 STEERING AXLE ASSY V
0301-11 AXLE HOUSING
0301-12 AXLE DRIVE ASSY
0400-01 AXLE INSTALLATION
0417-01 POTENTIOMETER INSTALLATION
0600-01 RADIATOR INSTALLATION
0603-01 HYDRAULIC PLAN cooling water
0605-02 COOLING SYSTEM
0605-03 COOLING SYSTEM
0700-01 DRIVE UNIT INSTALLATION
0703-01 AIR CLEANER INSTALLATION
0703-05 DRY AIR CLEANER ASSY
0710-01 ENGINE
0714-01 DRIVE POWER UNIT ASSY
0715-01 ADDITIONAL PARTS engine
0719-01 WATER SEPARATOR INSTALLATION
0800-01 CLUTCH INSTALLATION
0900-01 POWER DIVIDER INSTALLATION
0900-02 POWER DIVIDER INSTALLATION
0910-01 POWER DIVIDER ASSY
0910-02 RETROFIT KIT radial piston pump
0910-03 POWER DIVIDER ASSY
0910-05 HYDRAULIC PLAN power divider
0910-06 HYDRAULIC PLAN power divider
0910-10 POWER DIVIDER
1010-01 TRANSMISSION ASSY
1010-02 ACCESSORIES SET
1010-03 ADDITIONAL PARTS housing
1010-04 CONTROL UNIT
1010-05 CLUTCH DISENGAGER
1010-06 CONTROL VALVE
1010-07 HEAT EXCHANGER
1100-01 STEERING INSTALLATION
1102-01 HYDRAULIC PLAN steering
1102-02 HYDRAULIC PLAN steering
1109-01 ANGLE GEAR INSTALLATION
1109-05 ANGLE GEAR INSTALLATION
1200-01 JOINT SHAFT INSTALLATION
1200-02 JOINT SHAFT INST without Telma
1200-04 JOINT SHAFT INSTALLATION 10x8
1504-01 CONTROL SYSTEM
1505-05 CONTROL SYSTEM
1600-01 BRAKE CYLINDER INSTALLATION 1.axle
1600-02 BRAKE CYLINDER INSTALLATION 2.axle
1600-03 BRAKE CYLINDER INSTALLATION 3.axle
1600-04 BRAKE CYLINDER INSTALLATION 4.axle
1600-05 BRAKE CYLINDER INSTALLATION 5.axle
1601-01 AIR RESERVOIR INSTALLATION
1601-05 AIR RESERVOIR
1601-10 AIR RESERVOIR
1601-15 AIR RESERVOIR
1612-01 PNEUMATIC PLAN TRAILER brake system
1614-01 PNEUMATIC PLAN accessories
1614-02 PNEUMATIC PLAN accessories
1615-01 BRAKES ADD PARTS
1615-10 BRAKES ADD PARTS 3. Axle
1624-01 PNEUMATIC PLAN 10x8
1626-01 PNEUMATIC CONNECTION engine
1627-01 UNDER-CARRIER BRAKE
1699-01 REPAIR PARTS
1700-01 ELECTRICAL SYSTEM
1700-05 CABLE HARNESS cab chassis
1700-06 CABLE HARNESS cab chassis
1700-07 CABLE HARNESS cab chassis
1700-10 CABLE HARNESS chassis
1700-15 RETROFIT KIT wiring
1701-01 CAB ELECTRIC SYSTEM
1702-01 DASHBOARD INSTALLATION
1702-02 DASHBOARD INSTALLATION
1702-05 DASHBOARD ASSY
1702-10 CABLE HARNESS dashboard
1702-15 DASHBOARD ASSY relay sheet I
1702-16 DASHBOARD ASSY relay sheet I
1702-20 RELAY SHEET II
1704-01 ELECTRICAL ENGINE EQUIPMENT
1713-01 PRIORITY LIGHT INSTALLATION yellow
1715-01 BATTERY AND ACCESSORIES
1716-01 RADIO INSTALLATION
1717-10 AIR CONDITIONER
1730-01 ELECTRICAL SYSTEM
1730-10 ELECTRICAL SYSTEM
1737-05 TACHOGRAPH INSTALLATION 2.driver, mph
1748-01 LIGHT CARRIER INSTALLATION
1748-05 LIGHTING SUPPORTER ASSY left
1748-10 CABLE HARNESS ASSY front/left
1748-15 LIGHTING SUPPORTER ASSY right
1748-20 CABLE HARNESS ASSY right
1748-25 COVERING PART ASSY left
1748-30 COVERING PART ASSY right
1761-01 PLUG SOCKET INST trailer 24V
1787-01 PLUG SOCKET INSTALLATION
1900-01 EXHAUST SYSTEM rustproof
2000-01 ENGINE HOOD INSTALLATION
2000-05 FRONT WALL ASSY
2000-10 REAR WALL ASSY
2000-15 SIDE WALL ASSY left
2000-20 HOOD COVER ASSY front
2000-25 HOOD COVER ASSY rear
2000-30 COVER ASSY
2101-01 COVER INSTALLATION
2112-01 PLATFORM INSTALLATION left
2112-05 PLATFORM INSTALLATION right
2200-01 FENDER INSTALLATION 3000 broad
2200-05 FENDER INSTALLATION 3200 broad
2202-01 FENDER INSTALLATION
2203-01 CONVERSION KIT fender 3200 broad (cab)
2208-01 MUD FLAP INSTALLATION
2320-01 FUEL TANK INSTALLATION
2320-05 FUEL TANK ASSY
2401-05 TRAILER COUPLING INSTALLATION
2407-01 COUPLING INSTALLATION front
2501-01 TIRE TYPES 16.00 VHS Bridgestone
2501-05 TIRE TYPES 16.00 R25 VHS Bridgestone
2501-12 TIRE TYPES 445/95R25 X-Crane Michelin
2501-17 WHEEL AND TIRE 445/95R25 X-Crane Micheli
2501-20 TIRE TYPES 20.50 R25VHS Bridgestone
2501-25 WHEEL AND TIRE 20.50 R25 VHS Bridgestone
2501-30 TIRE TYPES 20.50 R25 XGC Michelin
2501-35 WHEEL AND TIRE 20.50 R25 XGC Michelin
2600-01 CAB ASSY
2600-02 CAB ASSY
2600-05 CAB ASSY
2600-06 CAB ASSY
2600-15 CAB ELECTRIC SYSTEM
2600-20 GLAZING INSTALLATION
2600-22 SLIDING WINDOW ASSY left
2600-24 SLIDING WINDOW ASSY right
2600-30 CONSOLE INSTALLATION
2600-31 CONSOLE INSTALLATION
2600-35 INSIDE LINING INSTALLATION
2600-40 WIPING AND WASHING SYSTEM
2600-42 WATER TANK INSTALLATION
2600-45 STEERING INSTALLATION
2600-50 SEAT INSTALLATION
2600-55 SEAT ASSY left
2600-58 SEAT ASSY right
2600-60 DOOR INSTALLATION left/right
2600-62 DOOR ASSY left
2600-64 DOOR ASSY right
2600-70 FRONT COVERING INSTALLATION
2600-75 FRONT GATE INSTALLATION
2600-76 FRONT GATE INSTALLATION
2600-80 PEDAL ARRANGEMENT
2600-85 COVER INSTALLATION
2600-90 CAB EQUIPMENT
2604-01 CAB INSTALLATION
2620-10 MIRROR INSTALLATION
2630-01 ROOF INSTALLATION
2661-01 SWITCHBOARD INSTALLATION
2800-01 TOOLS + ACCESSORIES
2801-01 SPECIAL EQUIPMENT
2808-01 INSTRUM SUPPORT INSTALLATION
2830-01 DECAL KIT - INSTALLATION
2830-03 DECAL KIT Splash-water protection
2830-05 DECAL KIT
2830-10 DECAL KIT "USA" 20.50R25
2901-01 COVER INSTALLATION under cab
2901-05 GUARD PLATE ASSY air conditioner
2901-10 COVER INSTALLATION air conditioner
2907-01 FOOTSTEP INSTALLATION
2922-01 BATTERY BRACKET INSTALLATION
2922-02 BATTERY BOX ASSY
2960-01 LADDER INSTALLATION vehicle width 3000
2960-03 LADDER INSTALLATION
2960-05 LADDER INSTALLATION vehicle width 3200
2960-10 LADDER INSTALLATION
2960-15 LADDER INSTALLATION vehicle width 3200
3000-01 HEATING INSTALLATION
3000-02 HEATING INSTALLATION
3000-05 HEATER
3020-01 AIR CONDITIONER INSTALLATION
3020-02 AIR CONDITIONER INSTALLATION
3020-03 AIR CONDITIONER INSTALLATION
3020-05 COMPRESSOR INSTALLATION
3020-10 CONDENSER INST air conditioner
3020-11 CONDENSER INSTALLATION air conditioner
3020-12 CONDENSER INST air conditioner
3020-13 CONDENSER INSTALLATION air conditioner
3020-15 CONDITIONER
3110-01 CENTRAL LUBRICAT INSTALLATION 38 point
3110-05 CENTRAL LUBRICAT 38 point
3110-06 CENTRAL LUBRICAT 38 point
3200-01 HYDRAULIC SYSTEM
3205-01 OIL RESERVOIR INSTALLATION
3205-05 OIL RESERVOIR ASSY
3205-06 OIL RESERVOIR ASSY
3205-10 HYDRAULIC PLAN oil reservoir
3205-11 HYDRAULIC PLAN oil reservoir
3213-01 PUMP INSTALLATION
3213-05 HYDRAULIC PLAN pump installation
3299-01 HOSE ACCESSORIES
3380-02 HYDRAULIC PLAN fan drive
5801-01 COVERING INSTALLATION left 3000 broad
5801-05 COVERING INSTALLATION left 3200 broad
5802-01 INSULATING-MAT SET
5909-01 SLIP RING ASSY
1085 - ATC-3250 Upper Parts:
ATC-3250
INDEX
CRANE
0107-01 COUNTERWEIGHT INSTALLATION
0107-05 COUNTERWEIGHT INSTALLATION
0604-01 OIL COOLER INSTALLATION
0605-01 COOLING SYSTEM INSTALLATION
0605-05 COOLING SYSTEM delivery scope
0606-01 OIL COOLER INSTALLATION auxiliary
0606-05 HYDRAULIC PLAN auxiliary oil cooler
0700-01 POWER PACK INSTALLATION
0710-01 ENGINE-SPARE PARTS
1300-01 PEDAL ARRANGEMENT
1700-05 CABLE HARNESS ASSY
1700-06 CABLE HARNESS ASSY
1700-10 CABLE ASSY ASLI-crane boom
1700-15 CABLE ASSY telescopic control sys
1700-20 CABLE ASSY telescopic control sys
1700-25 CABLE ASSY transmitter ASLI
1700-30 CABLE ASSY transmitter ASLI
1700-35 CABLE ASSY slip ring
1700-40 CABLE ASSY generator
1701-05 CAB ELECTRIC SYSTEM central electric
1701-10 CABLE HARNESS central electric
1701-15 CAB ELECTRIC SYSTEM standard equiment
1702-05 DASHBOARD ASSY I
1702-10 DASHBOARD ASSY II
1702-15 DASHBOARD ASSY III
1702-20 DASHBOARD ASSY IV
1702-25 CABLE HARNESS dashboard I
1702-30 CABLE HARNESS dashboard II
1702-35 CABLE HARNESS dashboard III
1702-40 CABLE HARNESS dashboard IV
1709-01 WORKING LIGHT INST basic boom
1710-01 ELECTRICAL SYSTEM crane boom
1710-10 ELECTRICAL SYSTEM delivery scope
1711-01 CAB ELECTRIC SYSTEM seat
1711-05 CABLE HARNESS ASSY seat
1713-05 PRIORITY LIGHT INSTALLATION 2.lamp
1716-01 RADIO INSTALLATION "CD"
1721-01 CAB ELECTRIC SYSTEM AML timing
1727-01 FAN INSTALLATION fan cab
1730-05 CABLE ASSY
1731-01 CAB ELECTRIC SYSTEM
1731-05 CAB ELECTR SYSTEM
1777-01 VIDEO ISTALLATION
2305-01 FUEL SYSTEM
2600-01 CRANE CAB
2600-03 CRANE CAB ASSY
2600-06 PLATE INSTALLATION
2600-09 ROCKER operator´s panel
2600-12 SLIDING DOOR rigid
2600-15 WIPING AND WASHING SYSTEM
2600-16 WIPING SYSTEM
2600-18 OUTER DOOR PANEL ASSY
2600-21 WINDOW PANE
2600-22 WINDSHIELD
2600-24 REAR PANE
2600-27 COVER ASSY loudspeaker
2600-30 ADDITIONAL PARTS
2600-33 INTERIOR EQUIPMENT
2600-36 HEATER
2600-39 ACTUATING ELEMENT
2600-99 PARTS KIT key
2604-01 CRANE CAB INSTALLATION
2620-01 MIRROR INSTALLATION
2620-05 MIRROR INSTALLATION shoring
2622-01 SEAT INSTALLATION
2622-05 SEAT ASSY
2803-01 DECAL KIT
2815-01 FIRE-EXTINGUISH INSTALLATION
2922-01 BATT BRACKET INSTALLATION
3000-01 HEATING INSTALLATION Thermo 90ST
3000-05 HEATER Thermo 90 ST delivery scope
3020-10 RETROFIT KIT air conditioner
3020-20 AIR CONDITIONER INSTALLATION
3020-25 COMPRESSOR INSTALLATION
3020-30 RETROFIT KIT air conditioner
3020-35 AIR CONDITIONER INSTALLATION
3020-37 COMPRESSOR INSTALLATION
3020-39 RETROFIT KIT air conditioner
3110-05 CENTRAL LUBRICAT 12 point
3110-10 CENTRAL LUBRICAT 1 point
3110-99 CENTRAL LUBRICAT ACCESSORIES
3210-01 HYDRAULIC PLAN pump installation
3210-05 HYDRAULIC PLAN pump installation
3211-01 VALVE GROUP
3211-02 VALVE GROUP
3211-03 VALVE GROUP
3211-04 VALVE GROUP
3211-10 VALVE GROUP delivery scope
3213-01 HYDRAULIC PLAN slewing gear drive
3213-02 HYDRAULIC PLAN slewing gear drive
3213-05 HYDRAULIC PLAN slewing gear brake free
3213-06 HYDRAULIC PLAN slewing gear brake free
3213-07 HYDRAULIC PLAN slewing gear brake free
3213-08 HYDRAULIC PLAN slewing gear brake free
3213-09 HYDRAULIC PLAN slewing gear brake free
3215-01 HYDRAULIC PLAN hoisting winch
3215-05 HYDRAULIC PLAN hoisting winch
3216-01 HYDRAULIC PLAN derrick cylinder
3216-05 HYDRAULIC PLAN derrick cyl free
3216-06 HYDRAULIC PLAN derrick cyl free
3216-07 HYDRAULIC PLAN derrick cyl free
3216-08 HYDRAULIC PLAN derrick cyl free
3216-09 HYDRAULIC PLAN derrick cyl free
3217-01 HYDRAULIC PLAN Telescopic Cyl
3217-05 HYDRAULIC PLAN telescopic cyl lock
3217-06 HYDRAULIC PLAN telescopic cyl lock
3218-01 HYDRAULIC PLAN counterweight
3218-03 CONVERSION KIT counterweight-hydraulic
3218-05 HYDRAULIC PLAN counterweight
3218-10 HYDRAULIC PLAN counterweight
3222-01 OIL RESERVOIR INSTALLATION
3222-06 OIL RESERVOIR ASSY
3222-07 OIL RESERVOIR ASSY
3222-10 HYDRAULIC PLAN oil reservoir
3222-11 HYDRAULIC PLAN oil reservoir
3222-12 HYDRAULIC PLAN oil reservoir
3251-01 MEASURNEMENT TRANSDUCER INST
3252-01 DOLLY SELECTION INSTALLATION
3252-05 DOLLY SELECTION INSTALLATION
3255-01 DERRICK CYLINDER INSTALLATION
5901-01 CRANE UPPERSTRUCTURE INSTALLATION
5903-01 TELESCOPIC BOOM ASSY
5903-05 BASIC BOOM ASSY
5903-06 BASIC BOOM + BOOM ADD-PARTS
5903-10 BOOM ASSY 1
5903-15 BOOM ASSY 2
5903-20 BOOM ASSY 3
5903-25 BOOM ASSY 4
5903-30 BOOM ASSY 5
5903-35 BOOM ASSY 6
5903-36 CRANE BOOM 6 + Welding Parts
5903-40 TELESCOPIC CYL ASSY delivery scope
5905-01 SLEWING GEAR INSTALLATION
5906-01 SWIVEL BEARING INSTALLATION
5921-01 FOLDING JIB INSTALLATION 5,6m
5921-05 FOLDING JIB delivery scope 5,6m
5921-10 FOLDING JIB ASSY 5,6m
5921-15 FOLDING JIB ASSY 5,6m elektic
5922-01 PULLEY CARRIER INSTALLATION
5922-05 PULLEY CARRIER delivery scope
5922-10 PULLEY CARRIER ASSY
5923-01 SECTION INSTALLATION 6m
5923-05 SECTION ASSY 6m
5923-10 SECTION ASSY 6m electric
5924-01 JIB POINT INSTALLATION 7,5m
5924-05 JIB POINT 7,5m delivery scope
5924-10 JIB POINT ASSY 7,5m
5924-15 JIB POINT ASSY 7,5m electric
5924-20 GUIDE FRAME ASSY
5924-25 TRANSPORT SUPPORT ASSY
5928-50 RETROFIT KIT quick-coupler for tele
5928-60 BASIC BOOM Modification
5941-05 LMB INSTALLATION AML "USA"
5992-01 HOOK BLOCK 25t single hook
5992-02 HOOK BLOCK 25t single hook
5992-10 HOOK BLOCK 80t single hook
5992-15 HOOK BLOCK 80t double hook
5992-20 HOOK BLOCK 125t double hook
5993-01 CRANE HOOK 10t
5994-01 FRONT BUILD PULLEY INSTALLATION
5994-05 FRONT BUILD PULLEY ASSY
5994-10 FRONT BUILD PULLEY ASSY electric
5994-15 FRONT BUILD PULLEY INST without pulley
6020-01 HOISTING WINCH INSTALLATION
6020-05 HOISTING WINCH INSTALLATION
6021-01 HOISTING WINCH INSTALLATION 2.winch
6021-05 HYDRAULIC PLAN 2.winch
6021-10 HOISTING WINCH INST electric 2.winch
6022-01 HOISTING WINCH INST 2.winch without winc
6022-05 HYDRAULIC PLAN 2.winch without winch
6034-01 PULLEY INSTALLATION
Brand: Link-Belt
List of Files:
Detail Contents:
ATC-3250
INDEX
ANNEX
ATC-3250
TERMS/TERMINOLOGY
INDEX - KEYSHEET
0100-05 FRAME
0100-06 FRAME ASSY
0200-07 AXLE DRIVE
0200-12 AXLE DRIVE
0202-04 AXLE DRIVE
0202-12 AXLE DRIVE
0288-01 DRIVE 10x8
0300-03 AXLE DRIVE
0300-12 AXLE DRIVE
0710-01 ENGINE
2000-30 COVER ASSY
2600-01 CAB ASSY
2600-02 CAB ASSY
2600-05 CAB ASSY
2600-06 CAB ASSY
2830-05 DECAL KIT
3000-05 HEATER
3020-15 CONDITIONER
ATC-3250
INDEX
CRANE
1730-05 CABLE ASSY
2305-01 FUEL SYSTEM
2600-01 CRANE CAB
2600-21 WINDOW PANE
2600-22 WINDSHIELD
2600-24 REAR PANE
2600-36 HEATER
2622-05 SEAT ASSY
2803-01 DECAL KIT
3211-01 VALVE GROUP
3211-02 VALVE GROUP
3211-03 VALVE GROUP
3211-04 VALVE GROUP
5903-10 BOOM ASSY 1
5903-15 BOOM ASSY 2
5903-20 BOOM ASSY 3
5903-25 BOOM ASSY 4
5903-30 BOOM ASSY 5
5903-35 BOOM ASSY 6
