[Linkbelt] Linkbelt Excavator 250X4 MH SL Operator Manual 250X4-MH-OM-LXG-02
Brand: Link-Belt
Type of Machine: Excavator
Type of Document: Operator Manual
Model: Link-Belt 250X4-MH Material Handler, Link-Belt 250X4-SL Scrap Loader
Number of Pages: 281 Pages
CHAPTER 1 – TO THE OWNER
LINK-BELT TECHNICAL MANUALS
CHAPTER 2 – MATERIAL HANDLER COMPONENTS
MACHINE COMPONENTS
ENGINE COMPONENTS
IDENTIFICATION NUMBERS
CHAPTER 3 – SAFETY, DECALS, AND HAND SIGNALS
SAFETY RULES
SAFETY AREA
UTILITY SAFETY
OPERATOR PRECAUTIONS
DECALS
HAND SIGNALS
CHAPTER 4 – INSTRUMENTS AND CONTROLS
CAB
STEPS AND ACCESS HANDLES
POSITION OF THE CAB CONTROLS AND ACCESSORIES
OPERATOR’S SEAT
SEAT CONTROLS
RIGHT HAND CONTROL ARM
LEFT HAND CONTROL ARM
FRONT RIGHT CONSOLE
HAND CONTROL LEVERS AND PEDALS(250X4-MH)
HAND CONTROL LEVERS AND PEDALS(250X4-SL)
TRAVEL CONTROL
SINGLE PEDAL TRAVEL
GATE LOCK
CAB LIGHT
COAT HANGER HOOK
CAB DOOR WINDOWS
CUP HOLDER
STORAGE TRAY
STORAGE COMPARTMENT
FUSE BOX
RADIO
WINDSHIELD
LOWER FRONT WINDOW
CAB FRONT GUARD
AIR VENTS
REAR WINDOW
REAR VIEW MIRRORS
MIRROR INSTALLATION AND ADJUSTMENT
REAR VIEW CAMERA
UNDER VIEW CAMERA (OPTIONAL)
FUEL TANK
ENGINE HOOD
STORAGE BOX
WINDSHIELD WASHER RESERVOIR
SIDE DOOR
TOWING POINT
CAB PROTECTION (FOPS: Option)
CHAPTER 5 – OPERATING INSTRUCTIONS
BEFORE OPERATING THE MACHINE
RUN-IN PERIOD
ANTI-INTERFERENCE SYSTEM
EMERGENCY LOWERING SYSTEM
STARTING THE UNIT
STARTING THE ENGINE
BRINGING THE MACHINE UP TO OPERATING TEMPERATURE
ENGINE OPERATION
STOPPING THE ENGINE
SCR SYSTEM
SCR RE-GEN (SCR regeneration)
OPERATING THE MACHINE IN COLD WEATHER
OPERATING THE MACHINE IN HOT WEATHER
BASIC OPERATION
SWING LOCK
MACHINE TRAVEL
SELECTION OF TRAVEL SPEED
PARKING THE MACHINE
OPERATING THE MACHINE ON SLOPING GROUND
TOWING THE MACHINE
LOAD HANDLING
LOWERING THE ATTACHMENT IN THE EVENT OF A MACHINE FAILURE
OPERATION OF ELEVATOR CAB
WORKING WITH THE MAGNET
OPERATION
ENGINE SPEED IN THE MAGNET MODE
AUXILIARY HYDRAULIC CIRCUITS
CHAPTER 6 – SERVICING INTERVALS
SERVICING INTERVALS
HOURMETER
DAILY INSPECTIONS
CHAPTER 7 – LUBRICATION, FILTERS, AND FLUIDS
FLUIDS AND LUBRICANTS
SAMPLING PROCEDURE
LUBRICATION CHART
LUBRICATION POINTS
FLUID LEVELS
ENGINE
COOLING SYSTEM
FUEL SYSTEM
DEF SYSTEM
RELEASING PRESSURE IN THE HYDRAULIC SYSTEM
HYDRAULIC SYSTEM
BLEEDING AIR FROM THE HYDRAULIC COMPONENTS
AIR FILTER
SWING REDUCTION GEAR
TRAVEL REDUCTION GEARS
CHAPTER 8 – MAINTENANCE AND ADJUSTMENTS
TRACKS
TRACK ROLLERS AND IDLER WHEELS
RADIATOR AND OIL COOLER
FAN AND ALTERNATOR BELT
INSPECTING AND CLEANING THE MACHINE
PLASTIC AND RESIN PARTS
CHECKING FOR CYLINDER LEAKAGE
FIRE EXTINGUISHER (NOT SUPPLIED)
PROTECTION OF ELECTRIC / ELECTRONICS SYSTEM DURING CHARGING OR WELDING
AIR CONDITIONING
INSPECTION OF GAS SPRING
HARDWARE TORQUE INSPECTION
ENGINE TROUBLESHOOTING
CHAPTER 9 – ELECTRICAL SYSTEMS
FUSES
BATTERY DISCONNECT SWITCH
BATTERY
CONNECTING ONE OR TWO BOOSTER BATTERIES
ALTERNATOR
STARTER MOTOR
REPLACING A BULB
MAGNET SYSTEM MAINTENANCE SPECIFICATION
CHAPTER 10 – TRANSPORTATION & STORAGE INSTRUCTIONS
TRANSPORTING THE MACHINE
LIFTING THE MACHINE
DISASSEMBLY BEFORE TRANSPORT
MACHINE STORAGE
CHAPTER 11 – SPECIFICATIONS
ENGINE
ELECTRICAL SYSTEMS
HYDRAULIC SYSTEM
WEIGHTS
UNDERCARRIAGE
CAPACITY OF SYSTEMS AND COMPONENTS
EXCAVATOR OVERALL DIMENSIONS
WORKING RANGE
LIFTING CAPACITIES – ISO RATINGS
RemoteCARE
DECLARATION FCC & CE
DOCUMENT
CHAPTER 12 INDEX
Brand: Link-Belt
MACHINE COMPONENTS
ENGINE COMPONENTS
SAFETY RULES
SAFETY AREA
UTILITY SAFETY
DECALS
HAND SIGNALS
CAB
OPERATOR’S SEAT
SEAT CONTROLS
FRONT RIGHT CONSOLE
TRAVEL CONTROL
SINGLE PEDAL TRAVEL
GATE LOCK
CAB LIGHT
COAT HANGER HOOK
CAB DOOR WINDOWS
CUP HOLDER
STORAGE TRAY
STORAGE COMPARTMENT
FUSE BOX
RADIO
WINDSHIELD
LOWER FRONT WINDOW
CAB FRONT GUARD
AIR VENTS
REAR WINDOW
REAR VIEW MIRRORS
REAR VIEW CAMERA
FUEL TANK
ENGINE HOOD
STORAGE BOX
SIDE DOOR
TOWING POINT
RUN-IN PERIOD
STARTING THE UNIT
STARTING THE ENGINE
ENGINE OPERATION
STOPPING THE ENGINE
SCR SYSTEM
BASIC OPERATION
SWING LOCK
MACHINE TRAVEL
PARKING THE MACHINE
TOWING THE MACHINE
LOAD HANDLING
OPERATION
SERVICING INTERVALS
HOURMETER
DAILY INSPECTIONS
SAMPLING PROCEDURE
LUBRICATION CHART
LUBRICATION POINTS
FLUID LEVELS
ENGINE
COOLING SYSTEM
FUEL SYSTEM
DEF SYSTEM
HYDRAULIC SYSTEM
AIR FILTER
TRACKS
AIR CONDITIONING
FUSES
BATTERY
ALTERNATOR
STARTER MOTOR
REPLACING A BULB
LIFTING THE MACHINE
MACHINE STORAGE
ENGINE
ELECTRICAL SYSTEMS
HYDRAULIC SYSTEM
WEIGHTS
UNDERCARRIAGE
WORKING RANGE
RemoteCARE
DOCUMENT
CHAPTER 12 INDEX
- Linkbelt LS108C Parts, Operation Maintenance and Load Chart Manuals
- Linkbelt Greer BBTM-508/BB-509 ANTI TWO-BLOCK ALARM SYSTEM – HYDRAULIC CRANE SYSTEM LAYOUT
- Link Belt 350X3 Excavator Schematic Service Manual
- Linkbet LS 118 Operator's Manual
- Link Belt 145X3 Hydraulic Excavators Operator's Manual
- Link Belt 3400 Quantum Excavator Schematic Shop Manual
- Link Belt HTC86100 Operator's Manual
- Link Belt RTC80130 Parts Manual
- Linkbelt RTC-8065 II Operator's Manual (Spanish)
- Link Belt 2800 Quantum Excavator Shop Manual
- Link Belt RTC-80130 II Operator's Manual
- Linkbelt LS 98 Operator's Manual
- Link Belt 210X2-EX Excavators Parts Manual
- MicroGuard 404 Trouble Shooting Manual
- Linkbelt LS-278 Rated Capacity Limiter Operators Manual
