118
6,429
Link-Belt Multi-Processor LMT 210 to LMT 700 Safety Operator And Parts Manual
Brand: Link-Belt
Type of Machine: Multi-Processor
Type of Manual: Safety Operator And Parts Manual
Model: Link-Belt LMT 210 ; LMT 350 ; LMT 490 ; LMT 700 Multi-Processor
Number of Pages: 79 Pages
Preface
Important
Manual Replacement
Registration Form
Possible Variations
Public Notice
Warranty
Safety Statements
Operational Safety
Read Manual Before Operating Or Maintaining The Tool
Personal Protection
Know Your Equipment
Before Operating
Check The Equipment
Stability
Know The Work Area
Starting Procedure
Place The Load Safely
Safely Operate Equipment
Transporting The Tool
Equipment Condition
Working Overhead
Power Lines
Use Care With Hydraulic Fluid Pressure
Prioritized Oil Flow
Emergency Situations
Unsafe Conditions
Crystalline Silica Dust
Process Material Safely
Lift The Load Safely
Processor Markings
Processor Installation
Installation Procedure
Rotator Installation
Rotation Circuit
Lock Pin Electrical Installation
Hydraulic Start-Up
Start-Up Procedure
Jaw Set Change-Over
Maintenance Safety
Maintenance Schedule
Four-Hour Checklist
Eight-Hour Checklist
Long-Term Maintenance
Lubrication Points
Shear Jaw Set Maintenance
Blade Bolts
Piercing Blades
Replacement
Guide Blades
Shimming
Rotation
Replacement
Adjustment Plates
Primary And Secondary Blades
Removal
Adjustment Plates
Rotation
Blade Gap
Blade Gap Measuring Procedure
Shimming
Razor Blade
Cracker Jaw Set Maintenance
Concrete Cracking Tips
Cutting Blades
Blade Removal
Blade Rotation
Blade Gap
Shimming Procedure
Pulverizer Jaw Set Maintenance
Pulverizing Teeth
General Welding Guidelines
Welding Ground Clamp
Welding Rules
Hard-Surfacing
Shear Jaw Build-Up
Shear Jaw Hard-Surfacing Patterns
Cracker Jaw Welding Maintenance
Build-Up
Pulverizer Jaw Welding Maintenance
Build-Up
Notes
Hydraulic/Rotation Maintenance
Hydraulic Requirements
Rotation Valve Input
Rotation Valve Settings
Regeneration Valve
Regeneration Valve Adjustment
Regeneration Valve - How It Works
Regeneration Valve
Svx00888
Svx00875
Slewing Ring Maintenance
Gearbox Maintenance
Planetary Gearbox Lubrication
Gearbox Lube Change-Out Procedure
Rotation Circuit
Auxiliary Valve Rotation
Gear Pump Rotation
Trouble-Shooting Guide
Processor
Rotator
Lock-Pin
Warranty And Parts Information
Parts
Third-Member Mount Upper Head
Multi-Processor Body
Shear Jaw Set Pivot Group
Concrete Cracker Jaw Set Pivot Group
Concrete Pulverizer Jaw Set Pivot Group
Hydraulics
Shear Jaw Set
Rotation Drive System Lmt 210/350
Rotation Drive System Lmt 490/700
Electrical
Wear Parts Kits
Tool List
