702,019
Link-Belt Hydraulic Excavator 145X4 Operators Manual 145X4-OM-LXG-00
Brand: Link-Belt
Model: Link-Belt 145X4 Hydraulic Excavator
Part Number: 145X4-OM-LXG-00
Publication Date: 2017
Number of Pages: 251 Pages
Operator's Manual
Chapter 1 - To The Owner
Link-Belt Technical Manuals
Engine Components
Identification Numbers
Chapter 3 - Safety, Decals, And Hand Signals
Safety Rules
Safety Area
Utility Safety
Operator Precautions
Hand Signals
Steps And Access Handles
Position Of The Cab Controls And Accessories
Operator's Seat
Seat Controls
Right-Hand Control Arm
Left-Hand Control Arm
Front Right Console
Control Pattern Selector Valve
Arm And Upperstructure Swing Left-Hand Control Lever In Pattern D
Boom And Bucket Right-Hand Control Lever In Pattern D
Arm And Upperstructure Swing Left-Hand Control Lever In Pattern C
Boom And Bucket Right-Hand Control Lever In Pattern C
Blade Operation (For Blade Specification)
Travel Control
Gate Lock Lever (Safety Bar)
Cab Light
Coat Hanger Hook
Cab Door Windows
Cup Holder
Magazine Rack
Fuse Box
Radio
Windshield
Lower Front Window
Air Vents
Rear Window
Rear View Mirrors
Mirror Installation And Adjustment
Rear View Camera
Engine Hood
Front Storage Box
Windshield Washer Reservoir
Side Door
Towing Point
Lifting Eyes
Anti-Vandal Cover
Cab Protection (Rops And Fops)
Before Operating The Excavator
Run-In Period
Starting The Unit
Starting The Engine
Bringing The Excavator Up To Operating Temperature
Engine Operation
Stopping The Engine
Scr System
Scr Re-Gen (Scr Regeneration)
Operating The Excavator In Cold Weather
Operating The Excavator In Hot Weather
Basic Operation
Swing Lock
Blade Interference (Blade Type)
Excavator Travel
Operating The Excavator In Water
Parking The Excavator
Operating The Excavator On Sloping Ground
Towing The Excavator
Operating The Bucket
Load Handling
Lowering The Attachment In The Event Of A Excavator Failure
Auxiliary Hydraulic Circuits
Hydraulic Excavator Quick Coupler Operation
Long Front Attachment Operation
Chapter 6 - Servicing Intervals
Servicing Intervals
Hourmeter
Daily Inspections
Fluids And Lubricants
Sampling Procedure
Lubrication Chart
Lubrication Points
Fluid Levels
Fuel System
Def System
Bleeding Air From The Hydraulic Components
Air Filter
Swing Reduction Gear
Travel Reduction Gears
Tracks
Radiator And Oil Cooler
Fan And Alternator Belt
Inspecting And Cleaning The Excavator
Plastic And Resin Parts
Checking For Cylinder Leakage
Replacing A Bucket
Protection Of Electric/Electronics System During Charging Or Welding
Air Conditioning
Inspection Of Gas Spring
Hardware Torque Inspection
Engine Troubleshooting
Fuses
Battery Disconnect Switch
Battery
Starter Motor
Replacing A Bulb
Chapter 10 - Transportation & Storage Instructions
Transporting The Excavator
Lifting The Excavator
Disassembly Before Transport
Excavator Storage
Chapter 11 - Specifications
Electrical Systems
Weights
Undercarriage
Capacity Of Systems And Components
Digging Force
Excavator Overall Dimensions
Working Range
Remotecare
Declaration Fcc & Ce
Document
Chapter 12
Index
