118
6,911
Link-Belt Forestry Machine 3240 Operator Manual 210X4-TL-OM-LXG-04 2019
Brand: Link-Belt
Type of Machine: Forestry Machine
Model: Link-Belt 3240 TL ; 3240 RB ; 3240 PH Forestry Machine
Engine: Isuzu AR-4HK1X Engine
Book Number: 210X4-TL-OM-LXG-04
Publication Date: 2019
Number of Pages: 260 Pages
Link-Belt Technical Manuals
California Proposition 65 Warning
Chapter 1 - To The Owner
Chapter 2 - Forestry Machine Components
Engine Components
Identification Numbers
Chapter 3 - Safety, Decals, And Hand Signals
Safety Rules
Safety Area
Chain Shot
Utility Safety
Operator Precautions
Hand Signals
Steps And Access Handles
Catwalks
Position Of The Cab Controls And Accessories
Operator's Seat
Seat Controls
Right Hand Control Arm
Left Hand Control Arm
Front Right Console
Arm And Upperstructure Swing Left Hand Control Lever
Boom And Heel Right Hand Control Lever
Travel Control
Single Pedal Travel
Gate Lock
Cab Light
Coat Hanger Hook
Cup Holder
Storage Tray
Storage Compartment
Fuse Box
Radio
Air Vents
Rear View Mirrors
Mirror Installation And Adjustment
Rear View Camera
Engine Hood
Front Storage Box
Side Storage Box
Windshield Washer Reservoir
Side Door
Towing Point
Before Operating The Forestry Machine
Run-In Period
Starting The Unit
Starting The Engine
Bringing The Forestry Machine Up To Operating Temperature
Engine Operation
Stopping The Engine
Scr System
Scr Re-Gen (Scr Regeneration)
Operating The Forestry Machine In Cold Weather
Operating The Forestry Machine In Hot Weather
Basic Operation
Swing Lock
Forestry Machine Travel
Operating The Forestry Machine In Water
Parking The Forestry Machine
Operating The Forestry Machine On Sloping Ground
Towing The Forestry Machine
Lowering The Attachment In The Event Of A Forestry Machine Failure
Auxiliary Hydraulic Circuits
Chapter 6 - Servicing Intervals
Servicing Intervals
Hourmeter
Daily Inspections
Cab Lubrication Chart
Fluids And Lubricants
Sampling Procedure
Lubrication Chart
Lubrication Points
Fluid Levels
Fuel System
Def System
Bleeding Air From The Hydraulic Components
Air Cleaner
Swing Reduction Gear
Travel Reduction Gears
Tracks
Radiator And Oil Cooler
Fan And Alternator Belt
Inspecting And Cleaning The Forestry Machine
Plastic And Resin Parts
Checking For Cylinder Leakage
Protection Of Electric/Electronics System During Charging Or Welding
Air Conditioning
Inspection Of Gas Spring
Hardware Torque Inspection
Engine Troubleshooting
Forestry Cab - Polycarbonate Cleaning Instructions
Fuses
Battery Disconnect Switch
Battery
Starter Motor
Chapter 10 - Transportation & Storage Instructions
Transporting The Forestry Machine
Lifting The Forestry Machine
Disassembly Before Transport
Forestry Machine Storage
Chapter 11 - Specifications
3240 Tl
3240 Rb
3240 Ph
Remotecare
Document
Chapter 12
Index
