Link-Belt Excavator LS-5800CII Shop Manual
Brand: Link-Belt
Type of Machine: Excavator
Type of Manual: Shop Manual, Hydraulic And Electrical Schematic
Model: Link-Belt LS-5800CII C Series II Excavator
Part Number: WEL5802-1E
Number of Pages: 270 Pages
Caution for Inspection and Maintenance
Basic Rules
General Rules for Disassembling
General Rules for Reassembling
Handling of the Interchangeable (Common) Parts
Hydraulic Circuit
Electric Circuit
Electric Circuit (Raised Up Type)
Performance Standards
Operating Instructions for Hydraulic Components at Starting
Measuring Pressure
Traction Motor and Reduction Gear
Traction Drive Assembly
Take-Up Roller
Structure Diagram
Tools and Jigs
Maintenance Standards
Disassembly Procedure
Reassembly Procedure
Upper Roller
Structural Diagram
Tools and Jigs
Lower Roller
Structural Diagram
Tools and Jigs
Shoe and Drive Sprocket
Structural Diagram
Tools
Disassembly and Reassembly of Shoes
Swing Motor and Reduction Gear
Turntable Bearing
Swing Motor Installation
Removal and Installation of Counterweight
Engine Mounting
Pump Installation
Air Pressure Line
Hydraulic Tank Air Pressure
Safety Valve on the Air Tank
Air Cylinder
Rotating Joint
Rotating Joint Assembly (Sectional View)
Replacing the Seal
Assembly Procedure
Special Jig
Pilot Valve
Summary/Model Code Numbers/Specifications
Construction/Fuctions
Actuation
Maintenance
Troubleshooting
Control Valve
Function Description
Disassembly
Cleaning
Inspection
Reassembly
Description of the Relief Valve
Mounting
Operation
General Specification of Control Valve
Troubleshooting and Countermeasure
Hydraulic Cylinder
Disassembly and Assembly Procedures
Weight of Components
Conversion Table
Brand: Link-Belt
Basic Rules
Hydraulic Circuit
Electric Circuit
Measuring Pressure
Take-Up Roller
Structure Diagram
Tools and Jigs
Upper Roller
Structural Diagram
Tools and Jigs
Lower Roller
Structural Diagram
Tools and Jigs
Structural Diagram
Tools
Turntable Bearing
Engine Mounting
Pump Installation
Air Pressure Line
Air Cylinder
Rotating Joint
Replacing the Seal
Assembly Procedure
Special Jig
Pilot Valve
Actuation
Maintenance
Troubleshooting
Control Valve
Disassembly
Cleaning
Inspection
Reassembly
Mounting
Operation
Hydraulic Cylinder
Conversion Table
