Link-Belt Excavator 80X3 Service Manual WLSM0806-00LX
Brand: Link-Belt
Type of Machine: Excavator
Type of Manual: Service Manual, Electrical Parts
Model: Link-Belt 80X3 Excavator
Part Number: WLSM0806-00LX
Publication Date: 2013
Number of Pages: 1129 Pages
Excavator
SAFETY
Safety, general information and standard torque data
Standard Torque Data For Cap Screws And Nuts
Specifications And Special Torque Settings
A. LOWER
Specifications
Main Equipment Table
Main Equipment Structure and Operation Explanation
Port Diagram
Basic Functions
Removal and Installation of Track
Removal and Installation of Shoe Assembly
Removal and Installation of Shoe Plate
Removal and Installation of Roller
Removal and Installation of Upper Roller
Assembly and Disassembly of Upper Roller
Removal and Installation of Lower Roller
Assembly and Disassembly of Lower Roller
Removal and Installation of the Sprocket
Removal and Installation of Take-up Roller
Assembly and Disassembly of Take-up Roller
Removal and Installation of Grease Cylinder
Assembly and Disassembly of Tension Shock Absorber
Removal and Installation of Center Joint
Assembly and Disassembly of Center Joint
Removal and Installation of Travel Motor
Assembly and Disassembly of Travel Motor
Maintenance Standards
Pressure Measurement and Adjustment Procedures
Drain Volume Measurement Procedures
Air Bleed Procedure
B. C. SWING UNIT, COUNTERWEIGHT
Specifications
Port Diagram
Basic Functions
Removal and Installation of Swing Unit
Assembly and Disassembly of Swing Motor
Assembly and Disassembly of Swing Unit
Removal and Installation of Counterweight
Air Bleed Procedure
H. ENGINE
Specifications
Basic Functions
Main Data
Function, Structure, Operation
Symptom
Functional Inspection
Maintenance precautions
Removal and Installation of Engine Assembly
Removal and Installation of Fuel Cooler, Engine Intercooler, Radiator, and Oil Cooler
Removal and Installation of Turbocharger assembly
Removal and Installation of EGR Valve
Removal and Installation of Engine Hood
Removal and Installation of Muffler
Removal and Installation of Cylinder Head Cover
Removal and Installation of Idle gear
Removal and Installation of Cylinder Block
Lubrication System
Removal and Installation of Exhaust Manifold
Disassembly, Removal and Installation of Crankshaft
Disassembly, Removal and Installation of Piston
Removal and Installation of Camshaft
Removal and Installation of Flywheel
Removal and Installation of Crankshaft front oil seal
Removal and Installation of Crankshaft rear oil seal
Removal and Installation of Rocker arm shaft
Removal and Installation of Valve spring
Removal and Installation of Valve stem oil seal
Removal and Installation of Intake chamber
Removal and Installation of Integrated oxidation catalyst silencer
Removal and Installation of Generator
Removal and Installation of Fuel Tank
Removal and Installation of Fuel Supply Pump
Removal and Installation of Common Rail Assembly
Removal and Installation of Injector
Removal and Installation of Starter Motor
Removal and Installation of Alternator
Preheating System
Introduction to the trouble diagnosis
J. HYDRAULIC EQUIPMENT (PUMP, OPERATION SYSTEM VALVE)
Specifications
Basic Functions
Port Diagram
Hydraulic Device
Control Valve
3 Stack Solenoid Valve Operation Explanation
Upper Pilot Valve (remote control valve)
Travel Pilot Valve (remote control valve)
Cushion Valve
Removal and Installation of Hydraulic Tank
Removal and Installation of Hydraulic Pump
Removal and Installation of Pump Coupling
Removal and Installation of Control Valve
Removal and Installation of Pilot Blocs
Removal and Installation of Travel Remote Control Valve
Removal and Installation of Operation Remote Control Valve
Removal and Installation of 3 Stack Solenoid
Removal and Installation of Cushion Valve
Reverse Prevention Valve
Procedures for Assembly and Disassembly of Hydraulic Pump Main Unit
Pump Main Unit Maintenance Standards
Procedures for Assembly and Disassembly of Control Valve
Procedures for Assembly and Disassembly of Operation Remote Control Valve
Procedures for Assembly and Disassembly of Travel Remote Control Valve
Assembly and Disassembly of Cushion Valve
Hydraulic Equipment Layout
Overall View
N. CAB
Removal and Installation of Operator's Seat
Removal/installation of the KAB Seat
Removal and Installation of Cab Assembly
Removal and Installation of Wiper
Removal and Installation of Cab Front Glass
Window Lock Adjustment Procedures
Tightening torque
R. ELECTRICAL PARTS
Electrical and Engine Functions and Service Support
Basic Functions
Battery Disconnect Switch
Milli-amp List
Safety
Service Support
Setting
Connection Connector Pin Layout
Sequence Circuit Diagram
Electrical Equipment Layout Diagram
Removal and Installation of Wiper Controller
Removal and Installation of Wiper Motor
Removal and Installation of Monitor
Air Conditioner Overall Diagram
Assembly and Disassembly of Unit
Removal and Installation of Compressor
Removal and Installation of Condenser
Removal and Installation of Receiver Dryer
Work Precautions
V. ATTACHMENTS
Removal and Installation of Bucket Cylinder
Removal and Installation of Arm Cylinder
Removal and Installation of Boom Cylinder
Removal and Installation of Boom Swing Cylinder
Procedures for Operation/Assembly and Disassembly of Hydraulic Cylinder (made by KYB)
Removal and Installation of Bucket Link
Z. OTHER
Specifications
Main Unit Weight
Bolt Size and Torque Table
Overall View
WORK RANGE DIAGRAM
New Machine Performance Judgment Table
FLUIDS AND LUBRICANTS
Main Unit-side Diagnostic Trouble Code List
Main Unit-side Trouble
List of special tools
