7,392
Link-Belt Excavator 600X4-MH Operator Manual 600X4-MH-OM-LXG-01 2019
Brand: Link-Belt
Type of Machine: Excavator
Model: Link-Belt 600X4-MH Excavator
Engine: Isuzu AQ-6UZ1X Engine
Part Number: 600X4-MH-OM-LXG-01
Publication Date: 2019
Number of Pages: 267 Pages
Link-Belt Technical Manuals
California Proposition 65 Warning
Chapter 1 - To The Owner
Chapter 2 - Material Handler Components
Machine Components
Engine Components
Identification Numbers
Chapter 3 - Safety, Decals, And Hand Signals
Safety Rules
Safety Area
Utility Safety
Operator Precautions
Hand Signals
Steps And Access Handles
Position Of The Cab Controls And Accessories
Operator's Seat
Seat Controls
Right Hand Control Arm
Left Hand Control Arm
Front Right Console
Arm And Upperstructure Swing Left Hand Control Lever
Boom And Attachment Right Hand Control Lever
Travel Control
Single Pedal Travel
Gate Lock
Cab Light
Coat Hanger Hook
Cab Door Windows
Cup Holder
Storage Tray
Storage Compartment
Fuse Box
Radio
Windshield
Lower Front Window
Cab Front Guard
Air Vents
Rear Window
Rear View Mirrors
Mirror Installation And Adjustment
Rear View Camera
Under View Camera (Optional)
Engine Hood
Storage Box
Windshield Washer Reservoir
Side Door
Towing Point
Cab Protection (Fops: Option)
Before Operating The Machine
Run-In Period
Emergency Lowering System
Starting The Unit
Starting The Engine
Bringing The Machine Up To Operating Temperature
Engine Operation
Stopping The Engine
Scr System
Scr Re-Gen (Scr Regeneration)
Operating The Machine In Cold Weather
Operating The Machine In Hot Weather
Basic Operation
Swing Lock
Machine Travel
Selection Of Travel Speed
Parking The Machine
Operating The Machine On Sloping Ground
Towing The Machine
Load Handling
Lowering The Attachment In The Event Of A Machine Failure
Operation Of Elevator Cab
Working With The Magnet
Operation
Engine Speed In The Magnet Mode
Auxiliary Hydraulic Circuits
Chapter 6 - Servicing Intervals
Servicing Intervals
Hourmeter
Daily Inspections
Fluids And Lubricants
Sampling Procedure
Lubrication Chart
Lubrication Points
Fluid Levels
Fuel System
Def System
Bleeding Air From The Hydraulic Components
Air Filter
Swing Reduction Gear
Travel Reduction Gears
Tracks
Radiator And Oil Cooler
Fan And Alternator Belt
Inspecting And Cleaning The Machine
Plastic And Resin Parts
Protection Of Electric / Electronics System During Charging Or Welding
Air Conditioning
Inspection Of Gas Spring
Hardware Torque Inspection
Engine Troubleshooting
Fuses
Battery Disconnect Switch
Battery
Starter Motor
Replacing A Bulb
Chapter 10 - Transportation & Storage Instructions
Transporting The Machine
Lifting The Machine
Disassembly Before Transport
Machine Storage
Chapter 11 - Specifications
Electrical Systems
Weights
Undercarriage
Capacity Of Systems And Components
Material Handler Overall Dimensions
Remotecare
Declaration Fcc & Ce
Document
Chapter 12
Index
