Link-Belt Excavator 350X4 Engine DTC Information
Brand: Link-Belt
Type of Machine: Excavator
Type of Manual: Engine DTC Information, Connector Location Harness
Model: Link-Belt 350X4 Excavator
List of Files:
350X4 Connector Location Cab Main Harness.pdf
350X4 Connector Location Engine Harness.pdf
350X4 Connector Location Main Frame Harness.pdf
350X4 Connector Location Monitor Harness.pdf
350X4 DTC 20A2 Reverting Valve GND Short.pdf
350X4 DTC 20AC Urea Solution Temperature (S-M) Sensor Abnormality.pdf
350X4 DTC 20B1 Coolant Control Valve Disconnection.pdf
350X4 DTC 20B3 Coolant Control Valve GND Short.pdf
350X4 DTC 20B4 Coolant Control Valve +B Short.pdf
350X4 DTC 20E8 Urea Injection Low Pressure Abnormality (During constant conditions).pdf
350X4 DTC 20E9 Urea Injection High Pressure Abnormality (1250 kPa or higher).pdf
350X4 DTC 20FE Urea Injection Low Pressure Abnormality (during startup).pdf
350X4 DTC 029D Communication Error Between DCU And NOx Sensor.pdf
350X4 DTC 060B Read Predefined Test Voltage Value-Read Converted A-D Value.pdf
350X4 DTC 062F DCU EEPROM Abnormality.pdf
350X4 DTC 0100 ISO-CAN Bus OFF.pdf
350X4 DTC 203B Urea Solution Level Sensor Seized.pdf
350X4 DTC 203C Level Sensor Error (Short circuit).pdf
350X4 DTC 203D Level Sensor Error (Disconnection).pdf
350X4 DTC 204B Urea Pressure Abnormality.pdf
350X4 DTC 204C Urea Pressure Sensor Low Voltage Abnormality.pdf
350X4 DTC 204D Urea Pressure Sensor High Voltage Abnormality.pdf
350X4 DTC 205C Urea Solution Temperature (tank) Sensor Error (short circuit).pdf
350X4 DTC 205D Urea Solution Temperature (tank) Sensor Error (disconnection).pdf
350X4 DTC 206A Urea Quality Sensor Reset Error.pdf
350X4 DTC 206C Urea Quality Or Temperature Sensor Short Circuit.pdf
350X4 DTC 206D Urea Quality Or Temperature Sensor Disconnection.pdf
350X4 DTC 207F Urea Solution Quality Too Low.pdf
350X4 DTC 208A Supply Module Disconnection.pdf
350X4 DTC 208B Supply Module Pump Motor Target vs. Actual RPM Comparison.pdf
350X4 DTC 208C Supply Module GND Short.pdf
350X4 DTC 208D Supply Module +B Short.pdf
350X4 DTC 208E Seized Dosing Valve.pdf
350X4 DTC 242B Diagnostic Check Of SCR Temperature Sensor Appropriateness After DOC.pdf
350X4 DTC 242C SCR Inlet Temperature Sensor Low Voltage Abnormality.pdf
350X4 DTC 242D SCR Inlet Temperature Sensor High Voltage Abnormality.pdf
350X4 DTC 0607 DCU Functional Error Not Involving Movement.pdf
350X4 DTC 0641 5V Power Supply Or Something Else Is Out Of Range.pdf
350X4 DTC 0658 SM or CCV Power Supply GND Short.pdf
350X4 DTC 0659 SM or CCV Power Supply +B Short.pdf
350X4 DTC 1462 Communication Error Between DCU And Urea Quality Sensor.pdf
350X4 DTC 2048 Dosing Module GND Short.pdf
350X4 DTC 2049 Dosing Module +B Short.pdf
350X4 DTC 2201 Diagnostic Check Of NOx Sensor Concentration Value Appropriateness.pdf
350X4 DTC 2206 NOx Sensor (disconnection).pdf
350X4 DTC 2207 NOx Sensor (short circuit).pdf
350X4 DTC 7000 Pressure Sensor P1 Abnormality.pdf
350X4 DTC 7001 Pressure Sensor P2 Abnormality.pdf
350X4 DTC 7002 Pressure Sensor N1 Abnormality.pdf
350X4 DTC 7003 Pressure Sensor N2 Abnormality.pdf
350X4 DTC 7007 Pressure Sensor Arm Cylinder Rod Abnormality.pdf
350X4 DTC 7021 Pressure Sensor Swing Pilot Abnormality.pdf
350X4 DTC 7023 Pressure Sensor Arm-In Pilot Abnormality.pdf
350X4 DTC 7040 Level Sensor Fuel Abnormality.pdf
350X4 DTC 7041 Temperature Sensor Hydraulic Oil Abnormality.pdf
350X4 DTC 7065 Pressure Sensor Boom-Up Pilot Abnormality.pdf
350X4 DTC 7067 Pressure Sensor Bucket-Close Pilot Abnormality.pdf
350X4 DTC 7068 Pressure Sensor Boom-Down Pilot Abnormality.pdf
350X4 DTC 7069 Pressure Sensor Arm-Out Pilot Abnormality.pdf
350X4 DTC 7070 Pressure Sensor Bucket-Open Pilot Abnormality.pdf
350X4 DTC 7071 Pressure Sensor Travel Right Pilot Abnormality.pdf
350X4 DTC 7072 Pressure Sensor Travel Left Pilot Abnormality.pdf
350X4 DTC 7073 Pressure Sensor Travel 1 Pedal Abnormality.pdf
350X4 DTC 7074 Pressure Sensor 1st Option Pilot (Common-Front Pedal) Abnormality.pdf
350X4 DTC 7075 Pressure Sensor Arm Cylinder Bottom Abnormality.pdf
350X4 DTC 7078 Pressure Sensor 1st Option Pilot (Rear Pedal) Abnormality.pdf
350X4 DTC 7200 Swing Brake Solenoid Abnormality.pdf
350X4 DTC 7201 Travel 2nd-speed Switchover Solenoid Abnormality.pdf
350X4 DTC 7202 Pressure Boost Solenoid Abnormality.pdf
350X4 DTC 7203 Travel Alarm Buzzer Abnormality.pdf
350X4 DTC 7206 Option Return Line Switchover Solenoid Abnormality.pdf
350X4 DTC 7207 Free Swing Solenoid Abnormality.pdf
350X4 DTC 7212 Gate Lock Solenoid Abnormality.pdf
350X4 DTC 7213 Quick Coupler Buzzer Abnormality.pdf
350X4 DTC 7214 Quick Coupler Solenoid Abnormality.pdf
350X4 DTC 7247 Boom 2-Down Pilot Proportional Valve Abnormality.pdf
350X4 DTC 7249 Bucket-Close Pilot Proportional Valve Abnormality.pdf
350X4 DTC 7250 Option Relief Pressure Proportional Valve Abnormality.pdf
350X4 DTC 7265 Arm 1 Semi-parallel Proportional Valve Abnormality.pdf
350X4 DTC 7266 Arm 2 Semi-parallel Proportional Valve Abnormality.pdf
350X4 DTC 7267 Arm 1 Regeneration Release Proportional Valve Abnormality.pdf
350X4 DTC 7270 Tilting 1 Proportional Valve Abnormality.pdf
350X4 DTC 7271 Tilting 2 Proportional Valve Abnormality.pdf
350X4 DTC 7273 Straight Travel Proportional Valve Abnormality.pdf
350X4 DTC 7400 7401 Water Temperature Overheating 1.pdf
350X4 DTC 7400 7401 Water Temperature Overheating 1-1.pdf
350X4 DTC 7404 Oil Temperature Overheating.pdf
350X4 DTC 7404 Oil Temperature Overheating-1.pdf
350X4 DTC 7405 7406 Boost Temperature Overheating 1.pdf
350X4 DTC 7405 7406 Boost Temperature Overheating 1-1.pdf
350X4 DTC 7420 Alternator Power Generation Failure.pdf
350X4 DTC 7421 Coolant Level Decrease.pdf
350X4 DTC 7422 Engine Oil Pressure Decrease.pdf
350X4 DTC 7423 Air Cleaner Clogging.pdf
350X4 DTC 7424 Return Filter Clogging.pdf
350X4 DTC 7426 Fuel Filter Clogging 1.pdf
350X4 DTC 7427 Fuel Filter Clogging 2.pdf
350X4 DTC 7428 7429 7430 Inducement (Remaining Urea Level Low).pdf
350X4 DTC 7602 ECM Communication Abnormality.pdf
350X4 DTC 7605 ECM Not-matched.pdf
350X4 DTC 7606 EEPROM Abnormality.pdf
350X4 DTC 7608 Camera Abnormality (without FVM).pdf
350X4 DTC 7612 Air Conditioner Communication Abnormality.pdf
350X4 DTC 7613 Monitor Communication (CAN) Abnormality.pdf
350X4 DTC 7618 DCU Communication Abnormality.pdf
350X4 DTC P2BA7 Urea Solution Shortage.pdf
350X4 DTC P2BAA SCR System Abnormality (With IND and no purging).pdf
350X4 DTC P06A6 5V Power Supply 1 Voltage Abnormality.pdf
350X4 DTC P06A7 5V Power Supply 2 Voltage Abnormality.pdf
350X4 DTC P06A8 5V Power Supply 3 Voltage Abnormality.pdf
350X4 DTC P06A9 5V Power Supply 4 Voltage Abnormality.pdf
350X4 DTC P06AF INJ-IC Abnormality.pdf
350X4 DTC P06D5 5V Power Supply 5 Voltage Abnormality.pdf
350X4 DTC P0016 Cam Sensor Phase Shift.pdf
350X4 DTC P20A0 Reverting Valve Disconnection.pdf
350X4 DTC P20A3 Reverting Valve +B Short-circuit.pdf
350X4 DTC P20AD Validity Diagnosis of Urea Solution Temperature (S-M).pdf
350X4 DTC P20C9 SCR System Abnormality (With IND).pdf
350X4 DTC P20EA DCU Power Supply Was Cut Before Completion of Emptying.pdf
350X4 DTC P041C EGR Cooler Outlet 1 Gas Temperature Sensor Abnormality (Low voltage abnormality).pdf
350X4 DTC P041D EGR Cooler Outlet 1 Gas Temperature Sensor Abnormality (High voltage abnormality).pdf
350X4 DTC P042C Exhaust Temperature Sensor 2 Abnormality (DOC inlet) (Low voltage abnormality).pdf
350X4 DTC P042D Exhaust Temperature Sensor 2 Abnormality (DOC inlet) (High voltage abnormality).pdf
350X4 DTC P0045 VNT Turbo Abnormality.pdf
350X4 DTC P060A CPU Monitoring IC Abnormality.pdf
350X4 DTC P060C A-D Conversion Abnormality.pdf
350X4 DTC P0087 Pressure Limiter Open.pdf
350X4 DTC P0089 Common Rail Pressure Abnormality (Excessive pumping).pdf
350X4 DTC P0091 SCV Drive System Disconnection, GND Short-circuit.pdf
350X4 DTC P0092 SCV Drive System +B Short-circuit.pdf
350X4 DTC P0097 Manifold Temperature Sensor Abnormality (Low voltage abnormality).pdf
350X4 DTC P0098 Manifold Temperature Sensor Abnormality (High voltage abnormality).pdf
350X4 DTC P0102 Airflow Sensor Abnormality (Low voltage abnormality).pdf
350X4 DTC P0103 Airflow Sensor Abnormality (High voltage abnormality).pdf
350X4 DTC P0112 Intake Air Temperature Sensor Abnormality (Low voltage abnormality).pdf
350X4 DTC P0113 Intake Air Temperature Sensor Abnormality (High voltage abnormality).pdf
350X4 DTC P0117 Water Temperature Sensor Abnormality (Low voltage abnormality).pdf
350X4 DTC P0118 Water Temperature Sensor Abnormality (High voltage abnormality).pdf
350X4 DTC P0122 Intake Throttle Position Sensor Abnormality (Low voltage abnormality).pdf
350X4 DTC P0123 Intake Throttle Position Sensor Abnormality (High voltage abnormality).pdf
350X4 DTC P149C DCU Was Not Powered Off Properly.pdf
350X4 DTC P149D Urea Solution Temperature Overheating in Tank.pdf
350X4 DTC P160B ADIC Abnormality.pdf
350X4 DTC P160C ADIC2 Abnormality.pdf
350X4 DTC P0182 Fuel Temperature Sensor Abnormality (Low voltage abnormality).pdf
350X4 DTC P0183 Fuel Temperature Sensor Abnormality (High voltage abnormality).pdf
350X4 DTC P0192 Common Rail Pressure Sensor Abnormality (Low voltage abnormality).pdf
350X4 DTC P0193 Common Rail Pressure Sensor Abnormality (High voltage abnormality).pdf
350X4 DTC P0201 Injection Nozzle #1 Drive System Disconnection.pdf
350X4 DTC P0202 Injection Nozzle #2 Drive System Disconnection.pdf
350X4 DTC P0203 Injection Nozzle #3 Drive System Disconnection.pdf
350X4 DTC P0204 Injection Nozzle #4 Drive System Disconnection.pdf
350X4 DTC P204F SCR System Abnormality (No IND).pdf
350X4 DTC P0205 Injection Nozzle #5 Drive System Disconnection.pdf
350X4 DTC P205B Validity Diagnosis of Urea Solution Temperature Against Intake Air Temperature.pdf
350X4 DTC P0206 Injection Nozzle #6 Drive System Disconnection.pdf
350X4 DTC P206B Urea Sensor Unit High Temperature Abnormality.pdf
350X4 DTC P0217 Overheating.pdf
350X4 DTC P0219 Overrun.pdf
350X4 DTC P0234 Boost Pressure Exceeded.pdf
350X4 DTC P0237 Boost Pressure Sensor Abnormality (Low voltage abnormality).pdf
350X4 DTC P0238 Boost Pressure Sensor Abnormality (High voltage abnormality).pdf
350X4 DTC P0335 Crank Sensor Abnormality (No signal).pdf
350X4 DTC P0336 Crank Sensor Abnormality (Signal abnormality).pdf
350X4 DTC P0340 Cam Sensor Abnormality (No signal).pdf
350X4 DTC P0380 Glow Relay Abnormality.pdf
350X4 DTC P0401 EGR Flow Abnormality.pdf
350X4 DTC P0404 EGR Valve Control Abnormality.pdf
350X4 DTC P0409 EGR Position Sensor Abnormality (Brushless type).pdf
350X4 DTC P0427 Exhaust Temperature Sensor 1 Abnormality (DOC outlet) (Low voltage abnormality).pdf
350X4 DTC P0428 Exhaust Temperature Sensor 1 Abnormality (DOC outlet) (High voltage abnormality).pdf
350X4 DTC P0522 Engine Oil Pressure Sensor Abnormality (Low voltage abnormality).pdf
350X4 DTC P0523 Engine Oil Pressure Sensor Abnormality (High voltage abnormality).pdf
350X4 DTC P0545 EGR Cooler Inlet 1 Gas Temperature Sensor Abnormality (Low voltage abnormality).pdf
350X4 DTC P0546 EGR Cooler Inlet 1 Gas Temperature Sensor Abnormality (High voltage abnormality).pdf
350X4 DTC P0560 12V Circuit Abnormality.pdf
350X4 DTC P0563 Battery-system High Voltage Abnormality.pdf
350X4 DTC P0601 ROM Abnormality.pdf
350X4 DTC P0602 QR Code Abnormality.pdf
350X4 DTC P0604 RAM Abnormality.pdf
350X4 DTC P0606 CPU Abnormality.pdf
350X4 DTC P0615 Starter Relay Circuit Error.pdf
350X4 DTC P0638 Intake Throttle Control Abnormality.pdf
350X4 DTC P0685 Main Relay System Abnormality (Not enabled).pdf
350X4 DTC P0687 Main Relay System Abnormality (Not disabled).pdf
350X4 DTC P1076 Intercooler Inlet Temperature Sensor Abnormality (Low voltage).pdf
350X4 DTC P1077 Intercooler Inlet Temperature Sensor Abnormality (High voltage).pdf
350X4 DTC P1093 Common Rail Pressure Decrease (Insufficient pumping).pdf
350X4 DTC P1097 Boost Temperature Sensor Abnormality (Low voltage abnormality) (Intercooler outlet).pdf
350X4 DTC P1098 Boost Temperature Sensor Abnormality (High voltage abnormality) (Intercooler outlet).pdf
350X4 DTC P1236 Intercooler Performance Deterioration.pdf
350X4 DTC P1261 Charge Circuit Abnormality (Bank 1).pdf
350X4 DTC P1262 Charge Circuit Abnormality (Bank 2).pdf
350X4 DTC P1404 EGR 0-point Learning Abnormality.pdf
350X4 DTC P1464 Early Open Error-Sticking Error of Main Relay.pdf
350X4 DTC P1468 DCU Internal Temperature Is High.pdf
350X4 DTC P1491 Urea Injection High Pressure Abnormality (1050 KPa or more).pdf
350X4 DTC P1493 Temperature Error of Driver IC.pdf
350X4 DTC P1606 SWIC-1 Abnormality.pdf
350X4 DTC P1621 EEPROM Abnormality.pdf
350X4 DTC P2000 Monitoring the NOx Efficiency.pdf
350X4 DTC P2146 Injection Nozzle Common 1 Drive System Abnormality.pdf
350X4 DTC P2149 Injection Nozzle Common 2 Drive System Abnormality.pdf
350X4 DTC P2210 Reading the Error(open) Information Detected by Rr NOx Sensor.pdf
350X4 DTC P2211 Reading the Error(short) Information Detected by Rr NOx Sensor.pdf
350X4 DTC P2228 Atmospheric Sensor Abnormality (Low voltage abnormality).pdf
350X4 DTC P2229 Atmospheric Sensor Abnormality (High voltage abnormality).pdf
350X4 DTC P2457 EGR Cooler Performance Deterioration.pdf
350X4 DTC P2458 Excessive PURGE Time-outs.pdf
350X4 DTC P3093 Common Rail Pressure Decrease (Insufficient pumping @ low fuel temperature).pdf
350X4 DTC U0002 DCU-ECM Communication Error.pdf
350X4 DTC U010E ISO-CAN DCU Communication Abnormality.pdf
350X4 DTC U029E CAN Communication Error Between DCU and Rr NOx Sensor.pdf
350X4 DTC U0073 CAN Bus Abnormality.pdf
350X4 DTC U0101 CAN Time-Out Abnormality.pdf
350X4 DTC U0110 CAN VNT Time-Out Abnormality.pdf
350X4 DTC U0411 VNT Communication Abnormality.pdf
